**** Toytec Lifts SALE****
Discussion in 'Suspension' started by Toytec Lifts, Feb 7, 2017.
  1. Jan 2, 2018 at 11:39 AM
    #151
    Toytec Lifts
    Toytec Lifts [OP] New Member
    Denver, CO.
    We are working on updating all install instructions as we speak.
    I do apologize for any inconvenience this may have caused.
    T-Rex266 and BlueBottle like this.
  2. Jan 2, 2018 at 11:56 AM
    #152
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @HBdirtbag only got his coilovers installed backwards because of it...
    :D
  3. Jan 2, 2018 at 12:29 PM
    #153
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    https://www.tundras.com/threads/diy-front-coilover-install-completed-with-toytec-radflo-2-5.12941/
    Your welcome :D
  4. Jan 2, 2018 at 12:41 PM
    #154
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    homer simpson "doh"
    I am curious when I get them switched around if it is the reason that the one side is so far cranked down.
  5. Jan 9, 2018 at 2:07 PM
    #155
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    @ToyTec Lifts
    Alright, so the saga continues. And I think I've come to the conclusion that from Toytec one of the coilovers was installed backwards on the top hat. But here's where I'd like to get some clarity on things and would rather put it out in the public so no one runs into hiccups going forward.
    Took the truck back to the shop to have him shave a little more off the lower control arm as well as shave a bolt off the back body bolts that was rubbing against the shackle and squeeking. Reversing the coilover was also something we were going to do. Now, keep in mind I trust this shop owner, he owned up to fucking up by having a new tech in and doing the initial install. But i've had numerous recommendations for him as well as the dude has solid 40+ 5 star reviews on yelp.
    So, i told him we needed to reverse it and he swore that it could only be installed one way (now we are referencing the top hat). He called toytec and spoke to two different techs who confirmed One flat side of the top hat will be facing forward on one side, and the flat side will be facing backwards on the other side. Well, this would lead to having the nitrogen port facing inward on one side since they are set up the same, unless mine came with one reversed. This would also lead to believing there is a proper left and right side. If you look at the picture toytec shows on the first page, the top hats are facing the same direction with the nitrogen port not visible. But if you were to install, one would be exposed and one not visible.
    Now, the shock itself should be ambidextrous, so it truly shouldn't matter which way the shock goes in onto the top hat. Unless i'm missing something. For me, i don't care if the nipple is exposed or not as I'll never service these. But the toytec techs didn't seem to think it would matter.
    What i'd like is for someone to tell me if i'm completely off base and how this is going to affect fitment and performance....
    Toytecs photo:
    my driver side (bolt facing forward):
    my passenger side (bolt facing backwards):
    dcsleeper408 likes this.
  6. Jan 9, 2018 at 3:29 PM
    #156
    csuviper
    Broomfield, CO
    Here is mine, both ports facing out.
    Drivers
    Passenger
  7. Jan 9, 2018 at 3:41 PM
    #157
    Toytec Lifts
    Denver, CO.
    The top mounts can only go on 1 way, the 4 bolts are not chimerical, the shock will operate the same way as long as it is bolted in correctly and the lower mis-alignment heims are in correctly.
    If you want to service/ charge the shocks on the truck you would need to droop out suspension and hook up accordingly, but honestly everything is tight and good, then there would be no reason to worry about it.
    Thanks
    David
  8. Jan 9, 2018 at 3:43 PM
    #158
    csuviper
    Broomfield, CO
    Agree. The drivers side top mount is mounted to the truck correctly. The shock is just rotated 180.
  9. Jan 9, 2018 at 4:38 PM
    #159
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Here’s mine. This look right @ToyTec Lifts ?
    Driver
    Passenger
  10. Jan 9, 2018 at 5:17 PM
    #160
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Rock and roll pismo here I come
  11. Jan 9, 2018 at 5:18 PM
    #161
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Videos catching air testing out he shocks or else it never happened!!!!
  12. Jan 10, 2018 at 7:05 AM
    #162
    Toytec Lifts
    Denver, CO.
    Looks good!
    BlueBottle[QUOTED] likes this.
  13. Jan 10, 2018 at 7:36 AM
    #163
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Even though its just a cosmetic issue, what would be the resolve to fix @HBdirtbag 's issue?
    -remove coilover, remove top hat, rotate coilover, and reinstall top hat?
    Also these are serviceable at home? How do we service them when needed?
    @ToyTec Lifts
    Toytec Lifts[OP] likes this.
  14. Jan 10, 2018 at 7:40 AM
    #164
    Toytec Lifts
    Denver, CO.
    That would be the correct way to fix it, yes.
    We do not recommend "servicing" them on your own to insure nothing gets messed up, or over pressurized. If they need to b e serviced just let me know and I can help assist you in getting them done properly and in a timely manner.
    Thanks
  15. Jan 10, 2018 at 8:07 AM
    #165
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Got ya!
    So we would just send out like most other coil overs to get rebuilt or serviced. Radflo being in Cali, can locals bring vehicle to them to service them while mounted still?
  16. Jan 10, 2018 at 8:09 AM
    #166
    Toytec Lifts
    Denver, CO.
    That is correct, I would assume that you can call them ahead of time to insure that it would be okay that you stop by.
    Thanks!
  17. Jan 12, 2018 at 6:11 PM
    #167
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    FYI - use the tundras.com discount with your order at the time of the order because if you order first and then try to have Toytec apply the code after the fact...even a day or so after the order just they ignore you....no matter the only reason you found them is here and the timeframe is close....I tried and tried and nothing but crickets and this after they made the 15% restock fee on a return.....don’t get me wrong, I’m happy with the product I kept so far but F minus on the customer service. Includes PM with @ToyTec Lifts
  18. Jan 12, 2018 at 6:16 PM
    #168
    BlueBottle
    '16 Platinum 4x4
    See fine print
    That sucks @4Runner
    I have had only pleasant experiences with toytec so that really seems odd. They have always been pretty responsive either through here and/or phone calls. I thought they were very responsive as a company compared to others. Did you try calling them? Sometimes calling fixes a lot of things.
    T-Rex266 likes this.
  19. Jan 12, 2018 at 6:21 PM
    #169
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    X2. Though I didn't have to ask them much during my buying experience.
  20. Jan 12, 2018 at 6:21 PM
    #170
    4Runner
    4Runner New Member
    Columbia, SC
    Next stop....again, love my setup...just didn’t see the discount since I’m so new here and thought this would be a slam dunk.
  21. Jan 12, 2018 at 6:23 PM
    #171
    I’ve only had A+ experiences with Toytec. I’m sorry you feel that way, but they’ve treated myself and everyone I know with top notch service.
    ColoradoTJ and 4Runner like this.
  22. Jan 12, 2018 at 6:23 PM
    #172
    Toytec Lifts
    Denver, CO.
    I do apologize about that!
    Let me know next time before you order and I’ll personally take care of you.
    Thanks!
  23. Jan 12, 2018 at 6:25 PM
    #173
    Curious- how did you try and contact Toytec?
    zcarpenter92 likes this.
  24. Jan 12, 2018 at 6:26 PM
    #174
    4Runner
    4Runner New Member
    Columbia, SC
    One of the reasons I ordered from them vs the TRD is from here so it’s not a feeling..just think think discount is warranted in my case even after the order. No a big deal for me and certainly not for them...just a bad taste in my mouth. Oh well.
  25. Jan 12, 2018 at 6:37 PM
    #175
    I don’t think they can modify the order to apply a discount once it’s been placed. Granted it’s 5%, but I’m sure if you call next time and speak with David he’ll get you squared away in the future.
  26. Jan 12, 2018 at 6:45 PM
    #176
    4Runner
    4Runner New Member
    Columbia, SC
    Yawn...it’s a credit back to my card. 101 these days. Simple. Yes, I get that it is immaterial but just a point for ,e and these days with my company being purchased every $$$$ counts. Moving on.
  27. Jan 12, 2018 at 6:48 PM
    #177
    I would have called asking about a forum discount. But hey, it’s 2018 and nobody picks up a phone to call anyone, right? :notsure:
    ColoradoTJ and zcarpenter92 like this.
  28. Jan 12, 2018 at 6:51 PM
    #178
    4Runner
    4Runner New Member
    Columbia, SC
    That is next...but nobody calls anyone since 2010...at least.
  29. Jan 12, 2018 at 7:17 PM
    #179
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Including me
  30. Jan 12, 2018 at 7:31 PM
    #180
    4Runner
    4Runner New Member
    Columbia, SC
    Just a fact that I haven’t received a credit, which is my expectation, or a reply as to why I would not receive a credit on my order..nothing about feelings or past experiences here...this is just plain and simple. This isn’t about the reliability of a product, just a story about my experience and business transaction. Again, I’m happy with what is installed product and delivery was fast...just thought they would honor discount.
