Toytec Lift Top plate spacers
Discussion in 'Suspension' started by Toytec Lifts, Feb 21, 2019.
  1. Feb 21, 2019 at 10:30 AM
    Toytec Lifts
    Toytec Lifts [OP] New Member
    Denver, CO.
    Hey guys!
    Just wanted to relay a couple products that most may not of known about that we offer here at Toytec Lifts!
    1/4'' Shim/ spacer to help compensate for driver side lean!
    1/2'' front top plate spacers top help gain more clearance for larger tires!
    Both products will NOT require longer studs, just a simple unbolt and bolt back in application! [​IMG][​IMG]
    Shoot me a message anytime!
  2. Feb 21, 2019 at 10:40 AM
    Lambeau
    Lambeau New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    The Toytec Boss instructions say spacers or shims should not be installed or warranty will be voided. Is that still the case?
    Rica25 likes this.
  3. Feb 21, 2019 at 10:45 AM
    YZTundy
    YZTundy New Member
    Denver, Co
    2011 Crewmax Rock Warrior
    These are for non adjustable coilover set ups
  4. Feb 21, 2019 at 10:47 AM
    Toytec Lifts
    Denver, CO.
    It is yes, since you have an adjustable coilover system you can adjust up to the 3'' mark.
    Rica25 likes this.
  5. Feb 21, 2019 at 11:48 AM
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    What are your thoughts about adjusting the coilover down to 2.5" and then adding a spacer in order to achieve the same overall height but to lessen the preload a little to soften the ride?
  6. Feb 21, 2019 at 2:05 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Aren’t they needed mostly with new coilovers? Spacer lifts don’t have the lean problem since you’re using the stock setup that already compensates for it.
  7. Feb 21, 2019 at 2:06 PM
    Toytec Lifts
    Denver, CO.
    We have seen a pretty wide variation of leaning/ not leaning Tundras, both stock and aftermarket.
    Rica25 and 040Tundra like this.
  8. Feb 22, 2019 at 3:33 PM
    Jebell4747
    Jebell4747 New Member
    2018 Tundra TSS
    I did a rough country 3.5” lift. I added a heavy bumper and winch and use these to level the from back out. Works great!
    Berdine likes this.
  9. Apr 8, 2019 at 1:42 PM
    Aiforever55
    Aiforever55 New Member
    05 Tundra Limited 4x4 DC
    Can you use the 1/2” if your running the Bilstein 5100’s? I’m looking for 3” of lift and already have the Bilstein 5100’s. Thanks
  10. Apr 8, 2019 at 2:44 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Yes
    Aiforever55[QUOTED] likes this.
  11. Apr 8, 2019 at 3:29 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    can you use the 1/2" spacer up front on a 3" BDS leveling kit ?
  12. Apr 8, 2019 at 7:09 PM
    Aiforever55
    Does toytect make the 1/2-3/4” for the 00-06 tundras?
  13. Apr 8, 2019 at 7:16 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    That wouldn’t work at all.....
  14. Apr 9, 2019 at 6:34 AM
    Toytec Lifts
    Denver, CO.
    Absolutely we do! :D
  15. Apr 9, 2019 at 8:48 AM
    Aiforever55
    Ordered. Thanks again!
  16. Apr 9, 2019 at 8:53 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    If your lift is coilovers, not a spacer lift
  17. Apr 9, 2019 at 2:12 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    its a spacer lift
  18. Apr 9, 2019 at 4:09 PM
    Berdine
    Binghamton, NY
    I wouldn't, too much stress on your stock coils with stacking spacers
    2010bigdog[QUOTED] likes this.
  19. Apr 9, 2019 at 10:37 PM
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    Do you care to expand on this??
    My thoughts are that adding a spacer on top of the coilover doesn't change the stroke length of the shock but just shifts it down relative to the frame and changes the angle of the control arms and CVs. I guess this could cause issues at full compression or full droop. I would be worried about the CV binding.
    That being said, I had a suspension parts manufacturer suggest putting a spacer on top of the coilover and adjusting the coilover down to soften the preload. This person has tons of experience with Tundra suspensions but I have never heard of anyone actually doing this.
  20. Apr 10, 2019 at 6:28 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Sure,
    For one, stacking lifts is NEVER a good idea regardless of anyone telling you differently.
    The coil has certain parameters and anything outside of its manufactured capabilities will put you at risk as well as others.
    If it’s adjustable, it makes no sense to slap on a spacer, shortening its travel path for a lift that’s higher.
    Your coil is set at 2” but have a lift of 3”, this increases preload and shortens travel, making it easier to bottom out and break your shocks, as well as top out
    Besides this, Toytec shocks are valved especially for our tundras. Why mess with a good thing?
  21. Apr 10, 2019 at 6:36 PM
    Jebell4747
    2018 Tundra TSS
    I have a RC 3.5” lift. I installed my winch/bumper and the front started dropping. Installed the 1/2” spacer and everything is fine. I’m up grading to adjustable coil over soon just to get the spacers out
  22. May 27, 2023 at 9:01 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Have an 18 stock OR. Will soon replace stock tires (low miles since not dd). Just planning for 275/70/18, likely duratrac Ds.
    looking at one of these just to bump up slightly but keeping majority of rake. Can’t find install instructions. Most instructions are for the in coil that requir spring compressor . Can someone describe what the simple unbolt and bolt back in details?
    basically seeing if this is much easier otherwise will just do 5100
  23. Sep 11, 2023 at 8:57 AM
    RockyMtnTundra
    RockyMtnTundra New Member
    2020 SX Crew Max 4X4
    Did you end up going with this? Curious to see how it turned out as I'm looking to do something similar.
  24. Sep 11, 2023 at 4:51 PM
    pro2amendment
    Indiana
    Bullet liner
    No, it looks like it’s the same/similar process as putting on 5100s. I might be wrong but that's how it appeared to me. Assuming I’d rather do 5100s
    RockyMtnTundra likes this.
