Toytec BOSS Suspension Review (Aluma Coilovers)
Discussion in 'Suspension' started by RevTheTundra22, Jan 30, 2020.
  1. Apr 23, 2020 at 10:20 AM
    Any advice for the UCAs? My Alumas come in today and some guys said they had one hell of a time with removing the UCA bolts. Thanks.
  2. Apr 23, 2020 at 11:42 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Getting them loose be prepared with a large breaker bar as they are on tight. There is some finagling around wires and hardlines on both sides. On the passenger side I unclipped several wire harnesses from the engine compartment side wheel well area. You will get an idea of which ones pretty quick just by looking where the bolt needs to go.. On the drivers side you have some hard lines an stuff to maneuver around. Make sure you have a few different extensions handy.. Both side are not bad just take your time to look around an move what you need to move. They really are not bad..
  3. Apr 23, 2020 at 11:44 AM
    Thanks for the tips. So really it's just maneuvering once you break the torque? Some were talking like they couldn't get the bolt to slide out of the UCA itself.
  4. Apr 23, 2020 at 11:46 AM
    Johnders2586
    Well I could see that as being a possibility. I have a 17 up in rust country an had no issues with them being stuck in there(rust). It's a long a$$ bolt which just makes snaking it in an out a bit of a PITA.
  5. Apr 23, 2020 at 11:47 AM
    Ketchumj
    Ketchumj New Member
    South Texas
    2020 Tundra SR5 4x4 Double Cab
    2020 Tundra 4x4 SR5 Magnetic Grey – TSS Off Road Toytec Complete performance 3” Lift kit with Aluma Series 2.5 Coilovers, SDP Upper Control Arms, Black Rhino 18” Gauntlet Wheels - +12 Offset, Nitto Terra Grapplers – 295/70R18, Victory 4x4 strike Front Bumper, Fab Fours Premium Rear Bumper, Smittybilt X20 12k Winch
    Exactly - maneuvering that damn bolt.
  6. Apr 23, 2020 at 11:56 AM
    Thanks fellas. I haven't looked over the instruction sheet for the SPC's yet, but I would pop the upper ball joints and remove the UCA with just the wheels removed and then after installing the SPC and balljoint to the spindle I can move to the coilover process?
  7. Apr 23, 2020 at 12:04 PM
    Johnders2586
    Yep you got it. Also don't expect any install instructions in the box.. SPC had some minimal info, coilovers had nadda .. YouTube is your friend .
  8. Apr 23, 2020 at 12:37 PM
    Yeah I installed the spacer kit that is in it now so I'm familiar with that portion of it. Loosening the LCA makes a world of difference.
  9. May 5, 2020 at 4:24 PM
    Those bolts were tight but they came right out after I broke the torque loose. It was harder to separate the ball joint from the spindle. The only issue I have now is trying to get the SPC ball joints to take grease. I don't know if it's the fitting on the grease gun that I bought at Autozone. Can I remove the zirk fitting and fill it that way?
  10. May 5, 2020 at 4:36 PM
    Johnders2586
    Um I don't think so but a standard grease gun should work. Sometimes on mine if I have the "tip" of the grease gun to tight it won't snap onto the zerk so maybe try loosening it a little?
  11. May 5, 2020 at 4:42 PM
    I'll try that and see what happens. The grease just seeped from under the tip.
  12. May 25, 2020 at 9:18 AM
    I probably have about 400 miles on mine now. So much better than the spacer kit. I had the Readylift 3/2.
    Aluma 2.5 coilovers
    SPC upper control arms
    Boss rear with resis
    Toytec shackles at 1.5
    1/2 inch rear axle shims
    TRD sway bars front and rear
    18x9 on 0 offset with 285/70/18 Ridge Grapplers
    Pretty close to dead level. 41.5 on all four corners from ground to the bottom of the flares.
  13. Jun 15, 2020 at 6:31 PM
    Hey if I send you a quote sheet that I received, can you look at it and see if it's a descent deal or not? My 13 is the 4.6 with 95,000 miles.
  14. Jun 15, 2020 at 8:07 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Quote sheet for what?
  15. Sep 4, 2020 at 2:43 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Interested to see more Aluma 2.5 Kits posted on here. Keep them coming.
  16. Sep 4, 2020 at 2:45 PM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Truck looks absolutly awesome!Love that Red with the red shocks!
  17. Mar 30, 2021 at 8:07 AM
    Krom81
    Krom81 New Member
    2014 Tundra 4x4 DC
    Front: ICON 2.5 c/o w/o res, ICON tubular UCA, Rear: ICON progressive rear leaf pack, ICON 2.0 shocks
    Looking at the Aluma series for my next coil over. Looking like it would fit my needs great but curious if anyone has input on how the Aluma c/o's handle the "Tundra Lean"? I've been running ICON 2.5s for a while and they need to be cranked an additional ~1/3 inch vs passenger side. Would like to avoid that if possible any input would be great, thx
  18. Mar 30, 2021 at 8:09 AM
    They are adjustable so you can even it out if you need to.
    81 TOY likes this.
  19. Mar 30, 2021 at 9:18 AM
    #49
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Bought the Aluma 2.0 3inch lift and am waiting for the rears and the SPC UCA's to come in from back order. Hoping to do the work myself.
  20. Mar 30, 2021 at 9:59 AM
    #50
    This will make life a lot easier for swapping out the UCA's. I would recommend reading the instructions now so that you can post any questions that you have. You will need to loosen the lower control arm cam bolt so that it drops down far enough to swap the coilovers. If you have no experience with suspension, do NOT get your fingers between the spring and the UCA when the arms drops and you remove the bolts and lower the coil. It will hurt like a mother.
    https://www.amazon.com/GearWrench-8...+Ratcheting+Wrench&qid=1587770319&s=hi&sr=1-2
  21. Mar 30, 2021 at 10:05 AM
    #51
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    Thanks for the heads up. I've been watching videos hoping to to pick up some tips .
  22. Mar 30, 2021 at 10:13 AM
    #52
    Not a problem. The written instructions do pretty much cover everything but there are some things that some of us had to do such as put a slight bend in the ABS bracket on the UCA to take the tension off of it. Many of us have done our own installs so we are here to help. Some say you have to remove the battery and washer tank to get the UCA bolts out....the battery and tank do not have to be removed. There is 1 bolt on the frame on the drivers side, and the rest is just popping the harnesses out of the plastic retaining clips. We can cover that when you get ready for your install.
    81 TOY[QUOTED] likes this.
  23. Mar 31, 2021 at 8:21 AM
    #53
    COTundra23
    COTundra23 New Member
    Lookin good. Are these rebuidable? If so, how often does Toytec recommend?
  24. Mar 31, 2021 at 9:15 AM
    #54
    Zed
    Zed New Member
    Houston Texas
    2017 Brown 1794 Tundra
    I am planning to go with this kit since every other kit is backed for months.
    81 TOY likes this.
  25. Mar 31, 2021 at 9:39 AM
    #55
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    Being in stock is a big plus.
  26. Apr 15, 2021 at 4:44 PM
    #56
    cain0725
    cain0725 New Member
    i didnt see any rears with the resis
  27. Apr 15, 2021 at 5:33 PM
    #57
    Toytec did away with the Boss with resis when they got the rear 2.0's. I have the resis on mine.
  28. Apr 15, 2021 at 10:36 PM
    #58
    cain0725
    cain0725 New Member
    that suckz
  29. Apr 16, 2021 at 2:06 AM
    #59
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    I agree, sux without resi, Looks killer with them, but performs top notch as the newer improved 2.0 rears without!!
    Skew12 likes this.
  30. Apr 16, 2021 at 3:19 AM
    #60
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    they said if you're like a city driver, these probably last you about 40k to 50k miles. Off roading to aggressive off roading, probably about 35k miles. I'm hoping that mine will last me a few years until it needs a rebuild cause by then, I'm upgrading to Elka's Performance suspension or something even better
    COTundra23[QUOTED] likes this.
