TOYTEC 1''-1.5'' REAR SHACKLES WITH BILSTEIN 4600'S
Discussion in '2.5 Gen Tundras (2014-2021)' started by CHESSIEMAN, Jun 14, 2016.
  1. Jun 14, 2016 at 4:58 PM
    CHESSIEMAN
    CHESSIEMAN [OP] New Member
    STEVE
    PA
    2025 ICE CAP RALLY CREWMAX
    JUST RECENTLY HAD BILSTEIN 5100'S INSTALLED ON MY 15 TRD CREWMAX. WAS GOING TO ADD THE TOYTEC 1-1.5'' SHACKLES FOR SOME ADDED LIFT IN THE REAR. MY QUESTION IS, CAN I STILL USE THE 4600'S THAT CAME WITH THE TRUCK, OR DO I NEED 5100'S FOR THE REAR????
  2. Jun 14, 2016 at 6:07 PM
    Probably need to use 5100's
  3. Jun 14, 2016 at 6:12 PM
    The shackles can replace ur rear block (If u have one) if not, it should work fine with the bilisteins
  4. Jun 14, 2016 at 6:53 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yes however the 5100s are extended length giving you more travel with the rear lift.
  5. Jun 14, 2016 at 7:10 PM
    Inferno16
    Inferno16 New Member
    Accoring to Many professional shops and manufacrtures i spoke to, they highly redommend that you replace the rear to match the front. csuviper is absolutely correct. they all said the same thing. And believe me it wasn't to try to sell me more product.
    I am getting ready to pull the trigger and purchase 5100 all around with Coachbuilder shackles +2 with 1 shim for the front left.
  6. Jun 15, 2016 at 4:25 PM
    CHESSIEMAN
    STEVE
    PA
    THANKS FOR THE REPLIES, SHACKLES WILL BE HERE FRIDAY, WILL BE ORDERING THE REAR 5100'S SOON.
