Toyota Tundra TRD PRO Fox Shocks
Discussion in 'Suspension' started by jackburton, Jan 1, 2019.
  1. Jan 1, 2019 at 6:58 PM
    jackburton
    jackburton [OP] New Member
    2019 Tundra TRD PRO
    Do the Toyota TRD Pro Shocks need to be rebuilt after a certain amount of miles or time?
    Thanks!
  2. Jan 1, 2019 at 7:00 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    All shocks have a lifespan. From what I've read, generally 70k is about when you can expect to replace/rebuild shocks.
    joonbug, Vizsla and jackburton[OP] like this.
  3. Jan 1, 2019 at 7:00 PM
    Maybe try contacting Fox?
    jackburton[OP] likes this.
  4. Jan 1, 2019 at 7:09 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    By that time I would replace them with Kings, Fox or ADS. ADS shocks are a work of art and tough as shit!
  5. Jan 1, 2019 at 7:14 PM
    jackburton
    2019 Tundra TRD PRO
    Cool, sounds like 70k is where Ill mod my wagon then
    OR18TRD likes this.
  6. Jan 1, 2019 at 7:17 PM
    Vizsla
    Vizsla 2 = 2.5
    The Fox Pro shocks are not rebuildable, same as the previous Bilstein Pro version. They are throw away and replace.
    Toyotoholic, OR18TRD, joonbug and 4 others like this.
  7. Jan 1, 2019 at 8:00 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I was wondering but assumed, being Fox, that they'd be rebuildable.
    joonbug, Vizsla[QUOTED] and Rica25 like this.
  8. Jan 1, 2019 at 10:39 PM
    Vizsla
    Vizsla 2 = 2.5
    If someone was hellbent, you could in theory add a nitrogen fill port, but parts would be a big problem.
  9. Jan 2, 2019 at 2:56 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Not according to Fox. I emailed them a few months ago and they said they are rebuildable and the cost will comparable to 1st gen Raptor suspension
    15whtrd likes this.
  10. Jan 20, 2020 at 4:59 PM
    TRDPROSean
    TRDPROSean New Member
    Hattiesburg, MS
    2017 CM TRD PRO
    275/70r18 Nitto Ridge Grapplers, TRD rear bar and intake, Coachbuilder +2 shackles, Corsa 14916 exhaust, UWS lo pro toolbox, Craven Speed stubby, tint
    I know this is an old thread but I didn't want to start a new one. My 2017 is getting close to the 70k mark. I'm not sure if it is actually riding different or if I'm telling myself it is to justify swapping out parts. Can I buy a new set of the TRD Pro Fox stuff from some vendor? If I can, I swear I can't find it and I can usually find anything. I've also toyed with the idea of 6112/5160??? I'm just not sure the high end suspension(King, ADS, etc.) is the way I want to go. When I swap it out, I don't want leaks or have to take them off and have a nitrogen fill done. Maybe I've just read only the bad posts about those particular ones, and they are in fact the way to go. I'm not as concerned about the price as I am the ease of replacement. If it is as good as or a little better than what I have now, I'm happy. I just want to swap and go another 70k before I do this again. Thanks for any advice/help
  11. Jan 21, 2020 at 1:03 PM
    alpinepro4
    Pat
    Yes you can buy Pro shocks using your pro vin#. They are not cheap.
    TRDPROSean likes this.
  12. Jan 21, 2020 at 4:00 PM
    TRDPROSean
    Hattiesburg, MS
    2017 CM TRD PRO
    WOW!! That's pretty pricey. I appreciate that. Not real sure why I couldn't find that. I guess the reading and research begins now to come up with the best option.
  13. Jan 21, 2020 at 7:06 PM
    alpinepro4
    Pat
    If you want to keep is OEM I say buy a set. I have been thinking about getting a set when my pro shocks go. I like the thought of OEM bolt on that rip off road.
  14. Jan 23, 2020 at 12:33 PM
    TRDPROSean
    Hattiesburg, MS
    2017 CM TRD PRO
    Yeah I do too. Like I said, I just want something as good as what I have now with no headaches. There are lots of other choices out there but when I read about someone having to take them back off after 3 days of running because they are leaking...... or, something is off with the nitrogen fill that needs to be corrected?? Maybe those are isolated cases but I'm not sure I want to venture down that road.
