Toyota Tundra dirty little towing secret
Discussion in 'Towing & Hauling' started by Markbvbb, Jun 22, 2019.
  1. Jun 23, 2019 at 1:01 AM
    #61
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This will be my last post in this thread.
  2. Jun 23, 2019 at 1:51 AM
    #62
    I’m not sure about how some people use CC, but for me it isn’t like sitting at home watching TV.
    I still hover the skinny pedal like if CC is off. In the event you have a tire blowout on the service vehicle, this can be the difference between just changing out a tire or being in the ditch all wadded up.
  3. Jun 23, 2019 at 3:22 AM
    #63
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    So color me curious, your first choice was a ram but you thought what? For shits and giggles I’ll go with my second choice to mix it up?
    Boerseun, Ostrich, Sunnier and 13 others like this.
  4. Jun 23, 2019 at 3:34 AM
    #64
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    @hagrid -- you have a ballpark on weight on that load/trailer (guessing electric brakes also..)? Just looking to get idea of what others find works for them. Find myself using 7.5 gain also with my TT with factory BC works well also.
    Sorry to interject... everyone else, carry on with the RAM loving :curls:
    15whtrd and Black Wolf like this.
  5. Jun 23, 2019 at 4:17 AM
    #65
    Nice Nautique. No it doesn't disable it on the 7 pin on the 2nd hen.
    Black Wolf and 15whtrd[QUOTED] like this.
  6. Jun 23, 2019 at 5:22 AM
    #66
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Ostrich, Adam, YeeYeeTundra and 4 others like this.
  7. Jun 23, 2019 at 5:31 AM
    #67
    Elevatormatt
    Elevatormatt New Member
    19 cement crewmax
    How heavy is your RV? Sounds like you may not have your WDH set up properly. Take a measurement from the ground to the top of your bumper, before hooking up the rv. Then hook it up and measure again. If that number gets any bigger than an inch, you are not set up properly. Raising the front of the truck does strange things to the TSS syste . It also makes the truck very unstable and hard to drive. If you are driving around with your front lifted and cruise control on while towing, you are lucky you haven't been in an accident yet. If you get your set up right all your issues should correct themselves, and you will be amazed at how well these trucks can tow
    15whtrd likes this.
  8. Jun 23, 2019 at 6:45 AM
    #68
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Exactly right Sir. Although I use CC quite often, when it gets "hilly", I'll grab a gear that I know is best to keep the Torque Converter locked and avoid constant shifting. Just because our Tundras have automatic transmissions, doesn't mean we have to drive them like we drove our '83 Reliants:D
    Sunnier and Rex Kramer[QUOTED] like this.
  9. Jun 23, 2019 at 7:59 AM
    #69
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I probably should of stated in my original post that if I hit a steep hill, the cc will indeed cancel out. But it don’t matter, dude is gonna buy a Ram.. lol
    Is it ok to post ? Or do I need to get authorization from the chain of command ! Lmfao
  10. Jun 23, 2019 at 10:54 AM
    #70
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I’ve never tried cruise control while towing I feel like I pay more attention when I don’t use cruise control. Sorry your upset get used to it because you’ll have it for a few hundred thousand miles with little maintenance :bananadead:
    Sunnier and Migraine like this.
  11. Jun 23, 2019 at 12:52 PM
    #71
    CMB
    CMB New Member
    Cecil County MD.
    On my 2010,the CC Control Stalk is right at my right hand finger tips, a simple pull-back and CC is off. Just as, if not faster than tapping the brake pedal, of course this doesn't mean much when we're 'posing', with our wrist/forearm so causally draped over the steering wheel... being so cool and all. I'm told fingernail polish takes some time to dry and we wouldn't want to mar those beauties by holding the steering wheel
    Yep, I can see your point but I don't use my truck in 'D', so shifting for myself most of the time, keeps me in touch and involved:thumbsup:
  12. Jun 23, 2019 at 2:33 PM
    #72
    PinoyRN
    PinoyRN Manila Gorilla
    Sammy
    Phoenix, AZ
    ‘06 Tundra
    :help:
    Migraine likes this.
  13. Jun 23, 2019 at 3:24 PM
    #73
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I don't really care what any manufacturer says. I'll never use cruise control while towing ever again.
    I almost had a trailer jack-knife on me just after cresting a hill the first and only time I used cruise control while towing. I was only going about 40 mph. It was a pure miracle that I was able to get it all back under control without rolling the truck.
    You don't go through that and then take a chance on it happening again.
    Boerseun likes this.
  14. Jun 23, 2019 at 3:27 PM
    #74
    15whtrd
    15whtrd Mr. Blonde
    Not trying to sound snarky, but do you think that may have had more to do with the tongue weight and the weight in the trailer improperly distributed. I don’t disagree with you about being hesitant to use cruise control but something doesn’t sound right if your truck tried to jackknife just from cresting the hill.
    jeremyd and careyrob[QUOTED] like this.
  15. Jun 23, 2019 at 3:54 PM
    #75
    careyrob
    Carey
    Massachusetts
    Weight distribution on the trailer probably was a factor that made it more prone to instability. It was a tandem axle flatbed trailer full of fire wood. Someone else loaded it and I wasn't towing it very far for them so I didn't inspect it as closely as I should have.
    I was also young and didn't want to insult someone I respected by scrutinizing their loading job too closely. I've since realized that I would have been personally more respectable if I had inspected it and reloaded it properly.
    But I don't know exactly how it was loaded because a lot of the wood fell off the trailer when it started swaying really badly. That's why I was able to get it back under control without rolling the truck.
    The cruise control continued to hold the throttle as I crested the hill (as CC is prone to do even while not towing). Then after it overshot the speed setting it cut the throttle abruptly and the sway started immediately.
    As you suggested, other factors likely contributed, but the unsteady throttle behavior from the cruise control is what kicked off the trailer sway. So "no CC while towing" is one of a few things I decided that day.
  16. Jun 23, 2019 at 5:14 PM
    #76
    15whtrd
    15whtrd Mr. Blonde
    Hey man we all learn somewhere. I’m sure on your short drive you weren’t thinking it was going to go down the way it did! I could see that happening to me as well.
  17. Jun 23, 2019 at 5:57 PM
    #77
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    If this is what it actually says in the owners manual, if so, it does not say it will not work (as many have pointed out it will work)
    It simply states not to. Why? Something those nasty wormy lawyers said to put in the manual so Toyota doesn't loose a court battle. It's as simple as that.
    As for the OP worried about CC and toeing, why not worry about driving stress while not in toe and CC on???? Hell, even while not in toe on a trip, I hardly use CC and I'm 62 YO.
    15whtrd likes this.
  18. Jun 23, 2019 at 7:33 PM
    #78
    jeremyd
    NV
    2014 SR5 CM 4X4
    Forget about that Cruise Control ! And just crack one of these..
    Ostrich, YeeYeeTundra and ColoradoTJ like this.
  19. Jun 23, 2019 at 7:36 PM
    #79
    Sunnier
    Sunny
    San Diego, CA
    Me too. :rolleyes:
    Migraine, Ericsopa and Alexstundra like this.
  20. Jun 23, 2019 at 7:59 PM
    #80
    Ericsopa
    Ericsopa Old man and the sea
    You're good! Took me two days. :D
  21. Jun 23, 2019 at 8:25 PM
    #81
    Sunnier
    Sunny
    San Diego, CA
    LOL! :fistbump: Rick-rolled!
  22. Jun 23, 2019 at 8:29 PM
    #82
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The trailer weighs 1200lbs and the Q-bota weighs 1800lbs. Trailer has 'lectric brakes on both axles.
    YeeYeeTundra[QUOTED] likes this.
  23. Jun 23, 2019 at 10:59 PM
    #83
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    :rofl::rofl::rofl::rofl::rofl:
  24. Jun 24, 2019 at 9:47 AM
    #84
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Not a true statement. This is standard for all manufacturers. Towing a trailer adds too many variables that makes it unsafe for you to use CC. You can still use it if you want to, Toyota just warns against it.
    15whtrd, 4x4_Angel and Rex Kramer like this.
  25. Jun 24, 2019 at 11:33 AM
    #85
    15whtrd
    15whtrd Mr. Blonde
    I think what his problem is, is that his trucks cruise control won’t work for him at all when towing. He thinks it’s because he’s towing and Toyota won’t let him do it. I think the dealer told him that as well. It sounds like this is not the case. The truck should be able to engage cruise control when towing even though Toyota advises against it. Something is wrong with his TSS system. Probably because the weight in the back of the truck is changing the angle of the sensor.
  26. Jun 24, 2019 at 12:18 PM
    #86
    Boerseun
    Ferdie
    Sarasota Florida
    I hear you, but the way the TSS works, is that you can hold the button for a few seconds and it turns on the regular CC instead of Dynamic CC. I would never tow using Dynamic CC. Probably not using regular CC either, but at least it would work if you turn it on.
    I can only make an assumption on the Dynamic CC not working - and that is that the trailer puts too much tongue weight on the truck and then the sensor is not aimed right. Again, I would rather have the system shut it down than to let me use it and cause an unsafe situation. I doubt that there is anything wrong with the system - it is just being used outside the safe parameters. Just my guess though since I don't have all the details. Based on OP's remarks about no other trucks prohibiting the use of CC, while it is in fact in every other manufacturer's manual, I suspect some ignorance and therefor user error rather than system error. I say that respectfully though - just saying that's what I see.
    15whtrd[QUOTED] likes this.
  27. Jun 24, 2019 at 12:21 PM
    #87
    15whtrd
    15whtrd Mr. Blonde
    I completely agree with everything you said!
    Boerseun[QUOTED] likes this.
  28. Jul 25, 2019 at 5:25 PM
    #88
    Dunchues
    Dunchues New Member
    New Brunswick
    You're a hero.
    I drive a semi and I use it 95% of the time, youdont impress me.
  29. Jul 25, 2019 at 5:29 PM
    #89
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Wow! You are a legend...
    in your own mind.
  30. Jul 25, 2019 at 5:55 PM
    #90
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    That was a good 1st message he had
