toyota tundra 2007 no me funciona el piloto automatico
Discussion in 'New Member Introductions' started by renzo457, May 13, 2021.
  1. May 13, 2021 at 5:40 PM
    renzo457
    renzo457 [OP] New Member
    Renzo Linares
    toyota tundra 2007 2wd
    The toyota tundra 2007 speed cruise does not work for me
  2. May 13, 2021 at 5:42 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Cruise control not working?
  3. May 13, 2021 at 5:45 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Da fuck??
    68 RS/SS and Dr Doobie like this.
  4. May 13, 2021 at 5:50 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    spanish to english - Bing
    translation:
    "hello good night, I'm new to this forum, I have a toyota tundra 2007 2wd, recent buy it and I don't work the automatic pilot, change the control and it still doesn't work, if someone can help me thanks"
    BlackSheep likes this.
  5. May 13, 2021 at 5:50 PM
    renzo457
    Renzo Linares
    [QUOTE = "TunBrun, publicación: 2236281, miembro: 60183"] ¿El control de crucero no funciona? [/ QUOTE]
    no funciona
  6. May 13, 2021 at 7:24 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    No SE habla Espanol
    Dose cerveza por favor,
    that's about all I know! Lol
    Welcome from Alaska
    YardBird and 1lowlife like this.
  7. May 13, 2021 at 7:26 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    Nosotros no hablamos espanol. Lo siento. Buena suerte.
  8. May 13, 2021 at 7:28 PM
    renzo457
    Renzo Linares
  9. May 13, 2021 at 7:38 PM
    Welcome from NY.
    Did you check the fuse?
  10. May 13, 2021 at 7:43 PM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Make sure the fuse is good and also recommend you to check the clockspring, if you replaced the switch must be done using the same part
  11. May 13, 2021 at 7:48 PM
    renzo457
    Renzo Linares
    [QUOTE = "iHacker, post: 2236484, member: 2962"] Asegúrate de que el fusible esté en buen estado y también te recomiendo que revises el muelle de reloj, si reemplazaste el interruptor, debes hacerlo usando la misma pieza [/ QUOTE]
    Muchas gracias, ¿dónde ubico esa pieza de resorte del reloj?
  12. May 13, 2021 at 7:49 PM
    renzo457
    Renzo Linares
    Thank you very much, where do I locate that spring piece of the clock?
  13. May 13, 2021 at 7:49 PM
    iHacker
    iHacker SW TRD PRO
    El Clockspring es el encargado de hacer funcionar todos los mandos en el volante para acceder a el clock spring es el mismo proceso que se hizo para reemplazar el cruise control stall
    cctxquicksand likes this.
  14. May 13, 2021 at 7:52 PM
    iHacker
    iHacker SW TRD PRO
    El proceso es algo tedioso ya qué hay que desmontar el airbag en el volante no es complicado pero se requiere de precaución ya que cualquier energía electrostática pudiese desplegar la bolsa de aire si no se manipula con precaución
    Aquí un buen video que muestra el proceso
    https://youtu.be/REeTx2oL5lY
  15. May 13, 2021 at 8:03 PM
    iHacker
    iHacker SW TRD PRO
    Ohh casi lo olvido, Bienvenido al foro my friend :D
    SoCalTundy and cctxquicksand like this.
  16. May 13, 2021 at 8:07 PM
    iHacker
    iHacker SW TRD PRO
    To test a clock spring the easy way solo necesitas un multimeter y chequea la continuidad y resistencia en todos los contactos en el clock spring
  17. May 13, 2021 at 8:12 PM
    renzo457
    Renzo Linares
    gracias
    iHacker likes this.
  18. May 14, 2021 at 12:37 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Buenos dias y Aloha
    iHacker likes this.
  19. May 14, 2021 at 4:47 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! My Spanish has 35 years of rust on it.
    iHacker and ZappBrannigan like this.
  20. May 14, 2021 at 7:23 AM
    Bienvenidos!
    iHacker likes this.
  21. May 14, 2021 at 1:18 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  22. May 14, 2021 at 1:23 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    All i need to know is burrito and taco...
  23. May 14, 2021 at 4:41 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix
  24. May 14, 2021 at 6:17 PM
    SoCalTundy
    SoCalTundy Member since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    It’s Spanish. Can’t help the man? Ignore it and move on.
  25. May 14, 2021 at 7:12 PM
    Roborob70
    Robert
    Well maybe we need to make a spanish forum seeing how they don't want to assimilate.... when you have 4 different ways to say 2 to,too and two...its confusing....LOL
