Toyota Tundra 2.5’’ Shocks from Elka Suspension
Discussion in 'Elka Suspension' started by Elka Suspension, Apr 8, 2019.
  1. Feb 24, 2021 at 1:49 PM
    #61
    Gumby
    Gumby New Member
    Taylor
    2021 Tundra SR5 Off Road (4X4)
    Do you think this could be avoided with an aftermarket lower control arm?
  2. Feb 24, 2021 at 2:38 PM
    #62
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Yes. I heartily endorse overkill, but have you priced those?
    TFTundra likes this.
  3. Feb 24, 2021 at 6:49 PM
    #63
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I had to do this with the 2.5” Radflos
    EDDO[QUOTED] likes this.
  4. Feb 25, 2021 at 2:41 PM
    #64
    Gumby
    Gumby New Member
    Taylor
    Nope, sure didn't. After seeing that, they can go piss up a rope. Ill cut mine when the time comes if need be..
    EDDO[QUOTED] and memario1214 like this.
  5. Mar 3, 2021 at 6:43 AM
    #65
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    How have they worked out for you? I’m considering the 2.5 non resi’s
  6. Sep 26, 2022 at 11:20 AM
    #66
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Was this the 2-3" lift"
  7. Sep 26, 2022 at 11:23 AM
    #67
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I can confirm that the 2-3" lift version requires clearance of the lower arm a little bit.
    BCTRD[QUOTED] likes this.
  8. Sep 26, 2022 at 12:01 PM
    #68
    BCTRD
    BCTRD New Member
    B.C.
    In my case the 0-2" seems fine at full droop.
  9. Sep 29, 2022 at 5:28 PM
    #69
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I had to trim mine as well.
    at what point does a fellow look at rebuilding these shocks? I’ve had them on for well over 50k miles and haven’t noticed any leaking or diminishing ride quality.
    although I may look at a softer spring for the front. The coil over springs at 700 pounds are very firm
  10. Oct 14, 2022 at 5:29 PM
    #70
    BCTRD
    BCTRD New Member
    B.C.
    Depending on when the dampening quality starts to diminish.
    A dealer in Canada I've spoke with suggested the bushings tend to go 1st.
    Cheap to replace and you can press them in and out easily with the correct tools and procedure.
    I'll probably run mine for several years and do periodic inspections before deciding when to ship them in. Would really depend on the usage and overall conditions. I like to inspect monthly and try to keep the shafts clean if possible. During the winter I wipe them down with a light rust preventative compound or wax if they look grungy.
    My truck runs empty 90% of the time and I love the handling with 700lb springs. Find they help prevent leaning and assist in preventing the shocks from blowing through the stroke in higher speed or rough cornering.
    TruckyTruck[QUOTED] likes this.
  11. Oct 23, 2022 at 1:15 PM
    #71
    TruckyTruck
    Gary
    Thanks, I appreciate the info!
