Toyota SUCKS!
Discussion in '2.5 Gen Tundras (2014-2021)' started by bensky, Mar 30, 2022.
  1. Mar 31, 2022 at 5:40 PM
    #121
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    So here's my thoughts. You knew about this a year before the recall. You used light meters, etc to verify light output. You knew it wasn't up to DOT standards, you replaced your bulbs with new bulbs on the suggestion of the dealership. Fair enough
    But here's my issue, you say you verified this with light meters, it wasn't up to DOT standards, and you never posted a thread about it to bring it anyone's attention, raise awareness, see if it was a one off problem, contact toyota immediately (not years later), etc. Especially since it's not up to DOT standards. I woulda jumped on the opportunity to contact toyota corporate, make a thread on it with evidence, proceed to get that thread stickied once enough people also verify the issue, and raise as much awareness as possible.
    Bitching about it now is kinda useless. You coulda made a thread years ago before you bought the LEDs and probably got some good feedback. We have plenty of knowledgeable people on this forum, engineers and electricians included.
    In the end $175 bucks isn't the end of the world. You found a solution to your issue (which you kept to yourself, until now :rolleyes:) and your blinkers are working good now. Call it win and don't expect anything from toyota.
  2. Mar 31, 2022 at 6:02 PM
    #122
    2mchfun
    If OP can verify against DOT standards where was the Toyota QC while these units were rolling off the line??
    panicman and Mater like this.
  3. Mar 31, 2022 at 6:18 PM
    #123
    Yawning now.... :burp:
    Jaypown, Mater and jhardy1979 like this.
  4. Mar 31, 2022 at 6:36 PM
    #124
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    OP says he discovered this in 2019. He has a 2018 according to his profile. One would have to look and see if the standards changed in that timeframe
    2mchfun[QUOTED] likes this.
  5. Mar 31, 2022 at 6:42 PM
    #125
    2mchfun
    Would they have issued a recall if they passed at time of production? I doubt it.
    Mater[QUOTED] likes this.
  6. Mar 31, 2022 at 8:28 PM
    #126
    bensky
    bensky [OP] PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Maybe read the post more carefully next time. I did report it to Toyota. Who knows, maybe that helped spark an investigation. The service manager at the dealer hadn’t seen this on any other trucks, so yes a one off problem as far as I knew at the time. So why the hell would I post the problem here? I first found out that others had this problem too on this forum. By then, someone smarter than me and my dealer figured out the wiring issue. So you think I should post every problem I have and contact Toyota corporate? I have a cab mount that only squeaks when the temperature is between 40-50 degrees. Should I start a thread for that?
    Black Wolf likes this.
  7. Mar 31, 2022 at 8:55 PM
    #127
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    This is the thread that keeps giving and giving
    Black Wolf, FlyingWolfe and PomDad like this.
  8. Mar 31, 2022 at 9:06 PM
    #128
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Make sure its not the condensor bushing.
  9. Mar 31, 2022 at 9:32 PM
    #129
    SAGE63
    San Diego County
    Boo that.... Mercedes owners are ok just ask me I will tell you I am... 8>)
  10. Mar 31, 2022 at 10:36 PM
    #130
    Blue By U
    Blue By U New Member
    [QUOTE="bensky, post: 2708784, member: 2163
    I have a cab mount that only squeaks when the temperature is between 40-50 degrees.[/QUOTE]
    Try some dry lube.
  11. Mar 31, 2022 at 10:37 PM
    #131
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    No kidding. Say anything bad about Toyota and 200 replies for the next month.
    Black Wolf, T-Rex266 and 2mchfun like this.
  12. Mar 31, 2022 at 10:43 PM
    #132
    Blue By U
    200 by Sunday.
    2mchfun and alb1k like this.
  13. Apr 1, 2022 at 1:55 AM
    #133
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    i think the point is that you shouldn’t go out and buy a 24k gold plated cab mount and expect Toyota to reimburse you in the future if it becomes a recall.
  14. Apr 1, 2022 at 2:45 AM
    #134
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    My Toyota's would have to give me a lot of grief before I said they suck. After owning GM, Ford, and a Jeep, I'm pretty happy with my 7 Toyotas.
    14burrito and Black Wolf like this.
  15. Apr 1, 2022 at 4:14 AM
    #135
    Mohoman
    Mohoman TTC 165
    Ima need some new popcorn.
  16. Apr 1, 2022 at 4:15 AM
    #136
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    That's not true! That's not true at all.
    I said the transmissions would explode with the power of one thousand suns, the force of which would rend the fabric of space/time and bring about a new Big Bang, thereby renewing the cycle of our universe.
    THAT is what I said.
    .... runny goo indeed. We should be so lucky.
  17. Apr 1, 2022 at 5:52 AM
    #137
    Sumo91
    TN
    You reported it to the service manager of a toyota dealership who probably could care less, not toyota corporate. For something that you supposedly tested and found wasn't up to DOT standards, I woulda brought it up to more peoples attention than just the service manager. A squeaky cab mount isn't a DOT issue and is irrelevant to this post, keep your post on topic :thumbsup:
    Cpl_Punishment likes this.
  18. Apr 1, 2022 at 5:55 AM
    #138
    2mchfun
    Pretty sure he did report it to Toyota corp., and that might have been why they actually looked into it. At least that is what I saw in his posts.
  19. Apr 1, 2022 at 6:03 AM
    #139
    Sumo91
    TN
    From what I read, he only passed the info to the service manager, who suggested he change the bulbs. Then he submitted a claim to Toyota Corp years later after he already changed his bulbs. Now he is upset that they haven't gotten back to him in 8 weeks and refunded the $175 he spent 2 years ago.
  20. Apr 1, 2022 at 6:04 AM
    #140
    2mchfun
    As for waiting to submit the claim, at the time of applying the band aid, OP might not have known about or maybe Toyota didn't have the dept. that owners can easily submit their claims to for reimbursment. I know many were shocked to hear of it in the LED headlight replacement thread and it is buried pretty deep on the website as well.
  21. Apr 1, 2022 at 6:24 AM
    #141
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    Sorry, you can't take all the credit as others were already on it as of Jan of 2019.
    https://www.tundras.com/threads/my-front-blinkers-anger-me.37861/
  22. Apr 1, 2022 at 6:33 AM
    #142
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    I put VLEDs in my truck 2 years ago because the signals were too dim. When I installed them, they didn't work, because of the wiring issue. A few minutes with a multimeter, and bending a wire from one side of the bulb connector to the other, they worked perfect. Toyota issued the recall shortly after and have been bugging me ever since to fix, even though I tell them I replaced them with aftermarket lights and not to touch them. Do I feel Toyota owes me anything? Absolutely not.
  23. Apr 1, 2022 at 6:36 AM
    #143
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Throw one of these on your truck…
    that’ll show em!
  24. Apr 1, 2022 at 7:01 AM
    #144
    Huckwheat
    Huckwheat New Member
    Scott
    Adirondacks
    2025 MGM Platinum Hybrid TRD
    OP, I feel for you.
    I remember how psyched you were when you were transforming your Platinum into a PRO. You have a sweet truck. Remember that and hang in there.
  25. Apr 1, 2022 at 7:06 AM
    #145
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    There are always exceptions. Tundra owners are nice folks. I am an asshole. That makes me the exception. Kinda exactly the same only opposite.
  26. Apr 1, 2022 at 7:17 AM
    #146
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I think OP came posted this thread just out of pure frustration. Understood that. But unfortunately, this is the wrong crowd to complain about Toyota.
    OP, you won't change majority of people's opinion on here, including mine. I think your best bet is to leave this thread to the graveyard and continue your fight with Toyota if you feel you should be reimbursed. If they don't reimburse, I won't be shocked. If they do reimburse, I'm happy for you that it got resolved!
    Black Wolf and 2mchfun like this.
  27. Apr 1, 2022 at 7:40 AM
    #147
    timsp8
    NY
    You had no issue making a post about noisy blinkers, but you couldn’t be bothered to make a post about a safety issue?
    https://www.tundras.com/threads/noisy-blinker.34979/
    Maybe take your own advice to stop complaining or get a different vehicle.
    https://www.tundras.com/threads/gas-mileage-posts-are-killing-me-how-about-you.62729/
  28. Apr 1, 2022 at 7:54 AM
    #148
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  29. Apr 1, 2022 at 8:53 AM
    #149
    cctxquicksand
