Toyota spray-in bedliner question
Discussion in '2.5 Gen Tundras (2014-2021)' started by j2007, Aug 25, 2018.
  1. Aug 25, 2018 at 9:31 PM
    j2007
    j2007 [OP] New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    I have the Toyota spray-in bedliner that came on my 2017. The front pair of fixed tie down hooks (on sides of bed, not on rails) are covered in bedliner, the rear pair were left painted body color for some reason. Now that I’ve had it a little over a year, the paint is really coming off the painted ones from being used with tie down straps. Not a huge deal but it’s ugly and I don’t want rust.
    Is this normal or did Toyota just forget to spray my rear tie downs?
    Has anyone found a good matching DIY bedliner material I could use to coat the rear tie downs?
    Thanks.
  2. Aug 25, 2018 at 9:33 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Most bed liner places remove these before spraying. You're good dont worry
    15whtrd likes this.
  3. Aug 25, 2018 at 9:45 PM
    It's normal. Same issue here.
  4. Aug 25, 2018 at 10:03 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Toyota only sprayed the front ones on mine too. The paint is also chipping. I plan on using the bedliner spray.
  5. Aug 26, 2018 at 3:47 AM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I've got linex and they did the same thing. All my paints gone and its just rusty now lol.
  6. Aug 26, 2018 at 5:51 AM
    j2007
    VA
    Thanks for the replies. It’s just weird to me they did one set and not the other. I’ll take them off and hit them with something sometime soon. A can of Rustoleum bed spray is $5 on Amazon. Not great reviews but this is for such a small part it’s probably ok.
  7. Aug 26, 2018 at 6:10 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    My bed hooks were sprayed from the factory. If you want to spray the hooks. I would use this bed coating for the hooks.DCB0C7E6-F1D6-4489-B565-C7FF5E9343CE.jpg
    Black Wolf and j2007[OP] like this.
  8. Aug 26, 2018 at 6:16 AM
    Adam New Member
    Take them off and drop them at your nearest linex. Should be able to do for under 20 bucks. There is a guy at work here that takes his steel toes in to linex the toe to keep them from wearing through. Costs him $20.
    j2007[OP], Pudge and 1UPPER like this.
  9. Aug 26, 2018 at 7:05 AM
    j2007
    VA
    Thanks. That’s good to know they’ll take small jobs. There’s one not far from me. This is my first truck so I keep learning things.
  10. Aug 26, 2018 at 8:19 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    It’s normal same deal here.
  11. Aug 26, 2018 at 8:40 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I’m glad they don’t spray them. It was easy to unscrew them when I installed my swing box.
  12. Aug 26, 2018 at 3:08 PM
    j2007
    VA
    That makes sense. Maybe people are more likely to remove the rear ones.
  13. Aug 29, 2018 at 8:59 AM
    SKRAM
    SKRAM New Member
    Scott
    2018 TRD Sport Storm Trooper
    TRR Dual Exhaust TRD Air Intake Spray in bed liner BakFlip tonneau cover 2 Way remote starter. 3M tape on leading edges.
    This is what I'ma do once I replace the front and rear bolts with D-rings. Then ima do everything at once. The white square rings on the sides looks really really stupid haha.
    That is a really good question tho man it had me stumped.
