Toyota Oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by SDNY, Jan 4, 2017.
  1. Jan 4, 2017 at 5:42 AM
    SDNY
    SDNY [OP] New Member
    Castleton NY
    2024 Sequoia Sonic Red
    Ok, i am this is somewhere on some foroum page. But lets see what everyone thinks. So here goes the question.
    Toyota synthetic oil is made by what manufacture, is it mobil 1, penzoil or other. Any documentation whould be great.
  2. Jan 4, 2017 at 5:52 AM
    Mobil. Says right on the bottle.
    joonbug, Wvmoonshiner and GNTundra like this.
  3. Jan 4, 2017 at 2:29 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Depends on the dealerships,
    they have a spec they need to meet,
    not every dealership uses the same oil - as long as it meets specs, no one cares.
    Dealerships buy in bulk so save money, cheapest offer comes in the shop.
    NVM,
    I believe I misread this...
    In any case,
    my local dealership uses "Toyota" synthetic that comes in a Valvoline labeled bottle and has "Toyota" written on it.
    On that note,
    "Toyotas" oil will change with time as well,
    cheapest bidder to meet specs wins the deal.
  4. Jan 4, 2017 at 2:31 PM
    Dealer I go to says Mobil 1
  5. Jan 4, 2017 at 2:31 PM
    SDNY
    Castleton NY
    Thanks, the dealer ship told me it is a toyota oil. I change it religiously so I should be fine anyway.
  6. Jan 4, 2017 at 2:33 PM
    Yeah stick with OW-20 oil n OEM toyota oil filter
  7. Jan 4, 2017 at 4:27 PM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    Speaking of oil.......I heard its a pain to change the filter on the Tundras. Is that true? I have a 2015, thats just about out of the factory free oil changes. And I would like to do them myself after that.
  8. Jan 4, 2017 at 7:59 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    It's not too bad. Depending on what skid plate you have installed you'll have to take it off. I have the TRD Pro skid plate that has an access hole. The previous owner or shop that worked on my truck jammed the drain plug in the filter cap, causing me to replace the cap and plug so I could actually use the filter drain.
  9. Jan 4, 2017 at 8:46 PM
    Ther bunch of YouTube posts on how to do give em a look at
