Toyota OEM Running Boards don't completely span both doors
Discussion in '3rd Gen Tundras (2022+)' started by ewarren423, Mar 23, 2024.
  1. Mar 23, 2024 at 10:18 AM
    ewarren423
    ewarren423 [OP] New Member
    Eric
    Hi All
    Just installed the PT92534223 running boards
    two things I thought were odd:
    1) the alignment of the brackets was off so I had to loosen the board mounts and adjust
    2) the running boards don't cover the full width of the doors but are a few inches short
    I double checked and the part # is correct
    Weird or normal?
    thanks!
  2. Mar 23, 2024 at 10:46 AM
    Regiuleather
    Regiuleather New Member
    Reg
    2024 SR5 TRD Sport, Advanced Tech Pkg, grey
    KBS roll-on bed liner
    Normal. They appear to be curved toward the front and rear and stick out more right in the middle pillar…
  3. Mar 27, 2024 at 12:11 PM
    ewarren423
    Eric
    ok...figured it out....the actual part # for the crew cab is PT92534222 (not xxx3)
    the website is very misleading as the different lengths are labeled wrong.
    the right part # solved both of the above problems!
  4. Mar 27, 2024 at 7:27 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    That sucks and yes it is misleading:
    A Cab = Regular Cab
    B Cab = Access Cab
    C Cab = Double Cab
    D Cab = Crew Cab
  5. Mar 28, 2024 at 5:12 AM
    CMikeB
    CMikeB New Member
    I searched Running Board Warehouse when I bought my bars. Along with all the "oem" models listed, I found the wtw style I was after.
