Toyota Motor oil add pack formula change?!
Discussion in '2.5 Gen Tundras (2014-2021)' started by WiscoWalleye, Mar 24, 2024.
  1. Mar 24, 2024 at 11:49 AM
    WiscoWalleye
    WiscoWalleye [OP] New Member
    I just watched this video and either he got a hold of counterfeit Toyota motor oil or they have changed their formula. They used to historically have 500+ppm of moly! Looks like this is gone! Anyone have any info on this.
    Attached are add pack screenshots from the video of pack reading from fresh oil he sent in to be tested.
    https://youtu.be/k60C6WYyvtU?si=XWRvemYedvGD43S0
  2. Mar 24, 2024 at 5:47 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    So much more goes into formulating motor oil than what is shown on an inexpensive oil analysis. Don’t worry about that video if the Toyota oil is your preferred oil.
  3. Mar 24, 2024 at 5:57 PM
    Pgain88
    Pgain88 Just Keep Truckin
    Valparaiso Indiana (Chicago)
    2024 Tundra
    How much did he end up paying? I might want to run some tests myself
  4. Mar 24, 2024 at 6:00 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Prices vary, but average around $30.
    speediagnostix
    ALS (NAPA and Wix kits)
    Blackstone Labs
    OilAnalyzers / Polaris Labs (Amsoil kits)
    Pgain88[QUOTED] likes this.
  5. Mar 24, 2024 at 6:55 PM
    WiscoWalleye
    I agree his test is a poor way to test oil. No engine gets up to 400 degrees. I’m just concerned because I used Toyota oil for its high moly content. However this can result in pre-ignition in newer high compression turbo engines. Ford had this issue early on in the eco booste engines and changed the oil formula specs. I’m just wondering if Toyota did the same for the new engines they are now building. If so I won’t be spending the premium for Toyota oil anymore.
  6. Mar 24, 2024 at 6:58 PM
    WiscoWalleye
    I sent in some Toyota 0W-20 oil to blackstone this week for testing. I’ll report back with the results. However they say they are back logged months!
  7. Apr 10, 2024 at 8:16 AM
    WiscoWalleye
    I got my results back. As suspected the add pack has changed. I’ll probably no longer spend the money on this oil. Probably switch to Valvoline extended protection as others have suggested.
    Pgain88 and nobodyintexas like this.
  8. Apr 10, 2024 at 8:28 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I switched to Valvoline for this oil change
    5w-30. Extended/hi miles version
    for grins
    it has a decent add pack
  9. Apr 10, 2024 at 8:30 AM
    WiscoWalleye
    Nice! That’s what I’ve been reading. I’ll do the same next change.
  10. Apr 10, 2024 at 3:16 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    Valvoline EP is what I run in my Tundra. 5W-30.
  11. Apr 10, 2024 at 4:07 PM
    AZBoatHauler
    So.Arizona
    ryanwgregg[QUOTED] likes this.
  12. Apr 10, 2024 at 4:39 PM
    737fixer
    737fixer New Member
    I saw the same thing you saw OP and was also curious. I realize Mobil 1 has made Toyota's oil for a long time with Toyota's own additives but this seems to be just a much closer reflection of standard Mobil 1.
    AZBoatHauler likes this.
  13. Apr 10, 2024 at 5:39 PM
    WiscoWalleye
    Agreed seems to be the case. And not worth the premium price they are charging.
  14. Apr 10, 2024 at 5:51 PM
    AZBoatHauler
    So.Arizona
    I get 5qt jugs of M1 at Wally World for $26.
  15. Apr 10, 2024 at 5:55 PM
    WiscoWalleye
    Oh I was referring to the Toyota branded stuff. Sorry wasn’t very clear.
    AZBoatHauler[QUOTED] likes this.
  16. Apr 10, 2024 at 6:04 PM
    AZBoatHauler
    So.Arizona
    I understood- just making the point you can get 5qts of the M1 for what Toyota charged for 2.
