Toyota batteries suck
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stumpjumper, Jun 7, 2019.
  1. Jun 8, 2019 at 10:56 AM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    This is very, very true at all factories. It doesn't matter if it's a new location or the engineers are just trying something to make the product better. Lot's of adjustments in the manufacturing process. Ask the factory workers in automobile plants, there are still calibration specialists working during the shutdown.
  2. Jun 8, 2019 at 11:01 AM
    We sell new test equipment too. Example>>>Fluke makes THE best hand held digital multimeter. Still made here in US. I've seen them fail calibration right out of the box. Doesn't happen often but it does happen.
    nvrgvup444[QUOTED] likes this.
  3. Jun 8, 2019 at 2:33 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Two things:
    1. Would you buy one if you don't have one already?
    2. Is there a date/year when the batteries went back to being good batteries again? Like I said, the one in my old truck lasted 10 years and never let me down. I hope they are back to being that reliable again.
  4. Jun 8, 2019 at 2:40 PM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Hmmm. Mine is over two years and still works. Must be about time I guess for a decent battery if that’s the case
  5. Jun 8, 2019 at 3:59 PM
    Two Things
    1. I bought a Yellow Top three years ago because I have absolutely no qualms at all with Optima along with millions of other happy Optima owners.
    2. Aurora plant was closed at the end of 2009. From what I was told was that it took Johnson Control several months to get the kinks out of the Mexican production line. 2010 was not a good year for JC. There were some quality issues that had to be addressed. Since then, Optima sales speak for them self and the internet complaints early on after the relocation were highly exaggerated, anecdotal, and based mostly on hearsay which still continues. I'm sure Optima has batteries that fail. I am also 100% certain I can find negative reviews /experiences with Northstar, Odyssey, and quite frankly with any make of battery for that matter. I've seen Consumer Report battery tests for brands who do quite well overall but for some reason a individual group size will do poorly.
    What's crazy is I found numerous anti Optima battery posts in 2009 and 2010 and the "posters" were claiming that their Mexican made Optima's were dying after only 2 years. PROBLEMO>>>>>Mexican plant hadn't even been open a year. Rumor has it that Optima quality started going downhill after the relocation was announced to the Colorado employees. Didn't sit well with them at all. Can't blame them. Just sayin.
    Baja Mike[QUOTED] likes this.
  6. Jun 8, 2019 at 4:30 PM
    Was this recently or not long after the move down south in 2009? Did you take advantage of the 3 year warranty? Should have been able to get yours replaced for free. The tire store down the street that I got my Yellow Top can't keep them in stock. I was getting my tires rotated Wed and they were installing a duel Yellow Top setup in a new RV.
    15Yota likes this.
  7. Jun 8, 2019 at 6:12 PM
    Hard to find knowledgeable help nowadays at auto parts stores.
    15Yota likes this.
  8. Jun 9, 2019 at 5:19 AM
    soobaroo
    soobaroo New Member
    Gene
    2019 Tundra SR5
    Too soon for any battery issues in my Tundra but the battery in my new Forester went dead in a year. It was made by Panasonic. They don’t even make a good flashlight battery. Wonder how many of them Subaru has had to replace?
    Black Wolf likes this.
  9. Jun 9, 2019 at 7:28 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Get a Northstar and grow old with your battery.
    Luckydog and 15Yota like this.
  10. Jun 9, 2019 at 7:44 AM
    ktmsmitty
    ktmsmitty New Member
    Ed
    Murfreesboro, TN
    2019 Toyota Tundra SR5
    Coming REAL soon.............
    This thread jinxed me! Haha I was reading this thinking that I had been lucky then go out yesterday and the battery in the wife’s Sienna was dead as a door nail. LOL
    At least it was 4 years old.....
    Baja Mike, JH5370 and ManoTundra like this.
  11. Jun 9, 2019 at 9:23 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    To the OP: If you are measuring 12.8 volts, generally that means you have a healthy, fully charged battery. You said you had "no amps." Where did you measure amperage? If you used a clamp multi-meter over the battery cable, you may simply have a bad connection from the cable to the battery terminal(s).
    Did you check voltage at the battery terminals while cranking the engine over? If you do not have a drop in voltage while cranking, there is something else wrong other than the battery. There are several possibilities.
    If the voltage at the battery terminals drops to 11.5 or less while cranking the engine over, then you are correct that the battery is gazooched, but it is unlikely it would measure 12.8 volts in a resting state if there are bad cells.
    Good luck.
    JH5370 likes this.
  12. Jun 10, 2019 at 9:16 AM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Checked by Auto Zone. Voltage was perfect but not enough juice to crank truck or power anything. New battery and all is well. Same thing happened a month ago on lawn tractor. Same thing happened years ago on both Tacomas. I have owned boats with multiple batteries most of my life so I have some experience with them.
  13. Jun 10, 2019 at 10:03 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    6 years on my wifes Rav 4 and i replaced it because I remembered.
    Nothing wrong with it but was taking a chance and I don't take those with the wifes car.
    Mine lasted 5 years on an 2012 Tacoma.
    I live in NY where the winter is brutal.
  14. Jun 10, 2019 at 10:34 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    The last Fluke I bought was made in China and failed after the second use, which was too bad since the headquarters is/was right down the road from me. I had to ask myself, replace with another one for $150 or buy a $25 chinesium one. I think like most other good quality companies that get bought by massive multinational conglomerates, the products start getting built to a cost rather than longevity/quality. I just ended up replacing my fluke with another used (pre-conglomerate) fluke unit.
    /end rant
  15. Jun 10, 2019 at 10:49 AM
    Yep, Made overseas now and "assembled in USA" We literally sell thousands of Fluke DMM's each year among other brands. Fluke still the best over all. There's some real crap dmm's out there. We still get in the old Series I 70's made in Everett that usually pass calibration after all these years. We still stock parts to fix them which is usually a damaged case or display. Tough buggers!
  16. Jun 10, 2019 at 12:08 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My factory 2016 battery was getting to the point that I couldn’t leave my rock lights on for 15-20 min w/o it dying. Fixed it with a yellow top.
    JH5370[QUOTED] and Black Wolf like this.
  17. Jun 10, 2019 at 12:58 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Heat is harder on them from what I have read
  18. Jun 10, 2019 at 1:03 PM
    Extreme cold just as bad.
  19. Jun 10, 2019 at 5:36 PM
    #49
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Just now ordered one of these, thanks for the photo! 2018 Tundra, year and a half old, 33,000 miles. I'll replace mine when it arrives (6-17 delivery date). Made in the United States of America.
    I ran AGM batteries on my motorcycles (Kawasaki and Yamaha) and they are bullet-proof.
    Tierhog[QUOTED] and Black Wolf like this.
  20. Jun 11, 2019 at 11:45 AM
    #50
    Dead Eye
    Dead Eye New Member
    Charles
    2017 Tundra SR5
    Funny my battery in my 2017 just took a dump this past weekend and of all places on the boat ramp! No signs it was going bad. Tried to jump with a cheap set of cables and no go. Go ride home and got my cables and started right up. I think maybe the Texas heat might have gotten to it. Anyway the dealer said a replacement battery is covered since the vehicle is less than 24 months and 24K miles. All my other Toyota vehicles 2004 and 2012 4Runner never had this issue. Maybe 2017 was a bad year for batteries?
  21. Jun 11, 2019 at 12:00 PM
    #51
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    2016 was too :rofl:
  22. Jun 11, 2019 at 1:59 PM
    #52
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    Most battery’s that i see have gone bad due to zero maintenance. Most battery’s go completely neglected until the vehicle won’t start. Check the water level in your battery every 6 months. Add distilled water if needed. You’ll be surprised how long a wet cell battery will last.
  23. Jun 11, 2019 at 2:11 PM
    #53
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    I had my Tacoma for 13 years and went through 4 batteries in that time. Got an average of about 3.5 - 4 years on each one. Our Lexus uses a Panasonic battery and I have never had to change one on any of the 3 Lexus cars that I have owned over the past 9 years or so ( my first Lexus was used and the battery was still going strong after 7 years). I tried to find a Panasonic battery for my Taco once but it appears that they only sell direct to manufacturers. The dealer did not have any and no one sells them on the Internet.
    I do maintain my batteries so that probably helps. Also most of those batteries made in the US come one manufacturer and are just re-branded and sold by the battery companies so you really don't get any different technology by buying a Delco or a WalMart battery. I have not heard of Northstar before but it appears that a lot of posters like them. I may try one of them once my Tundra battery is EOL.
  24. Jun 11, 2019 at 2:30 PM
    #54
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    Batteries these days don't really give any warning that they are going to go. One day went out to parking lot, moved my truck to the front door of the office, and turned off the truck. Loaded some equipment which took 5 minutes. Went to start the truck and leave and it was dead. No clicking, dash lights nothing. Would not even jump. Luckily the company had a fleet of truck and extra batteries in the warehouse. I put one in to get home and got a new battery that evening. Since then it seems every battery I've had goes in the 4th year. If I get to 5 years I just replace it before I am stranded. Use the old one around the farm in a tractor or something until it dies.
  25. Jun 11, 2019 at 3:05 PM
    #55
    soobaroo
    soobaroo New Member
    Gene
    2019 Tundra SR5
    Maybe Panasonic makes luxury batteries for Lexus and low end for Subaru. Or maybe I just got a bad one.
  26. Jun 12, 2019 at 9:23 AM
    #56
    lamikela1
    Michael
    I can't say but the ones in Lexus cars seem to be pretty good. With all the accessories in my GS it puts a pretty good load on the battery but it does have a pretty good alternator so maybe that is part of the equation. On the GS forum there are many users who report the same performance from their batteries.
    Boosted4runner likes this.
  27. Aug 15, 2019 at 12:01 AM
    #57
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Agreed! My 2007 Lexus IS350 lasted 7, yes, 7 years! After it went dead, I replaced with a factory Toyota battery in 2014. I sold the car in maybe 2015-2016, buyer was having all sorts of electrical problems - VSC lights flashing and whatnot. He called me out of the blue knowing I was a car buff. Told him to swap the battery, he said he had it tested. Swapped the battery - hasn’t had one issue with the car in over a year. (Toyota battery sucked) He still sends me pictures after he details is because the fucking thing has been Uber reliable, quick, and comfy. He loves it. I miss it.
    My Tundra battery is factory 2015, so I’m going to be swapping it out tomorrow LMFAO. :D
    My Lexus GS is 2014, factory battery. I’ll plan on swapping out in 2021 :D
    I went through 3 Optimas red tops in the 4runner. 1st one in 2010, lasted 8 years. Next one which was MFG in 2015ish, lasted 1 year. Replacement, another 1 year. After that I said fuck it and moved to a Napa Gold and it lasted a year then sold the rig.
    Not an optima fan anymore.
  28. Aug 15, 2019 at 1:59 AM
    #58
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Odyssey is where it's at. Tons of cranking amps. I have a decent number of lights, compressor, and winch drawing from it and never had a lick of trouble.
  29. Aug 15, 2019 at 8:57 AM
    #59
    The wifes '17 4Runner came with that battery from the factory.
    Edit - I have a 4 year old Interstate in mine but the pos terminal is leaking and corroding like crazy. I cleaned it and sprayed it with the Castle neutralizer and protectant. That lasted for about 2 weeks until the battery said "Hold my beer and watch this" so now I am needing a replacement due to the corrosion.
  30. Aug 15, 2019 at 9:06 AM
    #60
    What the!?
    What the!? New Member
    2017 Pro
    The OEM on my 2017 lasted a year and a half. I didn’t want the hassle of going through it again so I replaced it with a X2 (Northstar) from Batteries Plus. Great warranty and there was a sale on it too.
    Boosted4runner and dorkinatundra like this.
