Toyota and their cheap interiors UPDATE IN FIRST POST.
Discussion in '3rd Gen Tundras (2022+)' started by RLHULK, Nov 16, 2022.
  1. Nov 22, 2022 at 10:59 AM
    #181
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    The town I live in has one stop light, and I will not even see it for weeks at a time as I have no reason to drive in that part of town.
    From my house to work I have exactly one yield sign, and two stop signs. Then it’s 24 miles of highway one way.
    My other regular route to run errands, do major shopping etc has two stop signs, and then 50 miles or so of highway one way.
    The vast majority of my annual mileage is driven at highway speeds.
    As others have pointed out the price difference in diesel and gasoline, eats into or potentially eliminates any fuel cost saving of the 3.0L Duramax. Within reason I can accept that since I value fuel range more than outright cost savings.
    The problem with any of the GM 1/2 tons regardless of engine choice I would consider, is that I’m forced to budget large sums of money to correct deficiencies the trucks have. Namely a tiny fuel tank, and if I bought a 6.2L the variable displacement system would need to be deactivated and I would replace all of the lifters.
  2. Nov 22, 2022 at 11:03 AM
    #182
    RLHULK
    RLHULK [OP] Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    lol
    No idea if there is one but it does have a transmission temp gauge
  3. Nov 22, 2022 at 11:10 AM
    #183
    For you it obviously makes sense due to all the long driving periods.
    Diesel won’t always be more expensive. Not long ago premium was more than Diesel by a fair amount. Use the Upside app and save a good amount of savings. I have been getting .25 cents back per gallon lately. Today I’m going to fill my Jerry cans and diesel truck up. I have 1.45 per gallon off for 35 gallons (almost 50.00 in savings).
  4. Nov 22, 2022 at 11:16 AM
    #184
    Coal Dragger
    Kung Fu Dick
    For what it’s worth the new LZ0 3.0L Duramax oil pump belt service interval is now 200,000 miles. At the rate I accumulate miles that is somewhere around the 16 year mark of ownership.
    If you haven’t already seen it the revised 3.0L Duramax also makes 305 horse power, and 495ft-lbs of torque thanks to changing over to steel pistons along with some other revisions. The cooling system was also simplified.
    The long crank no start issue has been solved with software to make the crank position sensor read two full rotations of the reluctor gear in question to determine timing.
  5. Nov 22, 2022 at 11:19 AM
    #185
    Coal Dragger
    Kung Fu Dick
    It might make sense. I am still skeptical, but open to considering it.
    Burning over $1K on an aftermarket fuel tank chaps my ass though.
    Plus in the winter the truck would sit down in the Cheyenne River valley for 24-36 hours at a time cold soaking in -30F before I get a return train and go home. I am leery of diesel cold starts in those conditions.
  6. Nov 22, 2022 at 11:24 AM
    #186
    Wow. That’s not bad having a 200k belt swap. Like you, it would take 16+ years for this guy as well. Hell, my truck is 6 years old and has 84500 miles. Now if it was my daily…it would take about 8-9 years to be close to 200k.
    I bet that little d-max scoots then. I know my 7600 lb truck will surprise people (I’m over 500/1050).
  7. Nov 22, 2022 at 11:27 AM
    #187
    Cycle the glow plugs 2-3 times and fire it up.
    Ensure the DEF tank is only 50% full. Urea freezes around 11*F. The truck will bypass emissions until the tank heater warms up the DEF.
    JLS in WA likes this.
  8. Nov 22, 2022 at 11:34 AM
    #188
    Coal Dragger
    Kung Fu Dick
    Makes me wonder what a mild tune, and some simple bolt on parts like a true cold air intake could do for the LZ0.
    Surprised Gale Banks never did much with the LM2, but maybe the 1/2 ton world isn’t his thing.
  9. Nov 22, 2022 at 11:44 AM
    #189
    Gale Banks does a pretty good job on efficiency and his tunes are ok.
    This is the way:
    https://duramaxtuner.com/
    I have ran both and I can’t say enough good things about calibrated power. Go with the Auto Agent EZ Lynk. You won’t regret that choice.
  10. Nov 22, 2022 at 11:46 AM
    #190
  11. Nov 22, 2022 at 11:47 AM
    #191
    Ullose272
    Ullose272 New Member
    Boise, Id
    22 Tundra SR5 TRD OR
    I loved my 3.0 it was super smooth and got great mpg especially in the 50-60 mph range. round trip to my cabin was 30-32 mpg when it was stock and 26ish with 3.5 lift and 35s. they also come with 5 yr 100k powertrain warranty. it kinda lacked some horsepower when trying to pass someone, but had a ton of torque for towing. the transmission was great but some people were having some issues and sometimes it was a month out or 2 for parts. oil change kits on Amazon were like $65 but have gone up some. for the first year and a half i owned it 87 and diesel were about same price so it really saved some money, but now its about $1.60 difference, so not so much. i may go back to a 3.0 in a couple years. we will see
  12. Nov 22, 2022 at 11:52 AM
    #192
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I believe the 10 speed transmission was designed by ford for both manufacturers . Gm designed the transmission for the transverse engines in both platforms that use v6 . Maybe why the transmissions is out minimum 3-5 months in my area
    ColoradoTJ likes this.
  13. Nov 22, 2022 at 12:09 PM
    #193
    Damn. Probably a lot faster to just have it rebuilt…if parts are available.
    Durtywrench[QUOTED] likes this.
  14. Nov 22, 2022 at 12:15 PM
    #194
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Good news, they at least extended that recommended service interval to 200k.
    Edit: I see my failure to load the page for 2 hours before commenting has its consequences, as this was already mentioned lol
  15. Nov 22, 2022 at 12:23 PM
    #195
    Durtywrench
    Lou
    23 Tundra platinum
    None
    That was my first question . Why not rebuild it ? Remind me of CVT . No repair just throw a new part !
  16. Nov 22, 2022 at 12:32 PM
    #196
    Dealerships love doing R&R only. Big money.
  17. Nov 22, 2022 at 12:35 PM
    #197
    Coal Dragger
    Kung Fu Dick
    Yeah. Plus at some point the aftermarket will be making all sorts of beefed up parts for the Ford/GM 10 speed because there are going to be millions of them.
    So a guy can probably have one rebuilt to be very very stout should they be willing to open their check book.
  18. Nov 22, 2022 at 12:40 PM
    #198
    pursuit2550
    pursuit2550 New Member
    This post went from cheap interior to mpg to engines to transmission parts. Lol
  19. Nov 22, 2022 at 12:42 PM
    #199
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    My father in law picked up a trail boss it’s an impressive ride I really enjoyed it myself. Think you made the right choice.
    RLHULK[OP] likes this.
  20. Nov 22, 2022 at 1:11 PM
    #200
    mass-hole
    mass-hole New Member
    Yeah, the DexosD is expensive. I dont know that I would run that though. I would probably run some 5W30 diesel oil.
  21. Nov 22, 2022 at 2:02 PM
    #201
    RLHULK
    Rich
    2022 Silverado LT.
    Yup its one of things I love about this place.
    pursuit2550[QUOTED] likes this.
  22. Nov 22, 2022 at 4:29 PM
    #202
    mass-hole
    Banks is working on a derringer for the lm2. S&B and AFe has an intake. The exhaust is already straight piped from the dpf back.
    Durtywrench likes this.
  23. Nov 23, 2022 at 8:29 AM
    #203
    PwrMMA
    PwrMMA New Member
    2022 Toyota Tundra SR5 TRD Offroad
    How exactly would you "account" for that? Foam wears down. And leather and fake leather also wear down. You can't "account" for wear and tear. I am not saying poor quality is excusable, but you have to take care of your shit too. lol
    Minarets likes this.
  24. Nov 23, 2022 at 9:48 AM
    #204
    mass-hole
    My F150 seats have held up FAR better than the seats in my Lexus GX460. The GX leather looks terrible and the foam is collapsing while my F150 seats look almost like new with a few small wrinkles. Both are leather and both have ~100k miles. The GX seats look terrible when I bought it at 60k and I've managed to keep them from degrading as fast with leather conditioner but they arnt good.
    There is wear and there is Toyota wear.
    DFS likes this.
  25. Nov 23, 2022 at 9:57 AM
    #205
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Closed cell foam.
  26. Nov 23, 2022 at 8:32 PM
    #206
    pursuit2550
    Well first you learn from the million mile tundras and work from there. There is a very good YouTube video on how Toyota came to be. Let's just say that they, alone with MANY other companies are only chasing the bottom line nowadays. You might not want to hear it but , Toyota dropped the ball on this gen. Mike Sweers FUBARed the tundra. For me to get a comparably equipped tundra like mine, it about $10-11k more. No way in hell is there that much upgrade money in the new gen. So yeah if the new gen is going to cost that much more, it better be GREAT. Eventually I will buy one so I hope Toyota gets their shit together. I really don't care for any of the BIG 3. Been there, done that, not happening again.
  27. Nov 23, 2022 at 10:35 PM
    #207
    RLHULK
    Rich
    2022 Silverado LT.
    I honestly believe Toyota peaked with the 2.5 gen. I really wanted to like the 3rd gen I had, but I just could not.
    Cpl_Punishment likes this.
  28. Nov 23, 2022 at 10:36 PM
    #208
    Durtywrench
    Lou
    23 Tundra platinum
    None
    More than likely not going to happen . Banks been postponing it . Now the LZO is out they might not even touch it .
  29. Nov 24, 2022 at 4:48 AM
    #209
    pursuit2550
    I think when Toyota brought out the 2nd gen(07+), they put the big 3 to shame. It was a huge improvement over the 1st gen. The 3rd gen not so much, matter of fact not even close to the 1-2 gen jump. It was a beast of a truck. Highest HP/TQ, huge diff, 4piston calipers and largest rotors, reliable AF 6 speed, etc. The big 3 had their job cut out for them. It was by all means a work truck and Toyota was proud of that, all the commercials were base on how tough it was. Now they proud themself with the Jones commercial and the capstone metrosexual commercial. They went from a bullet proof 5.7 to a V6 TT that is ridiculously over complicated. That thing has sensors for everything in that engine. To me that doesn’t scream long term reliability. And to not offer another engine, when the rest are was also a stupid move. And I know they will never sell as much as the big 3, but now I believe they sell even less. Time will tell though.
  30. Nov 24, 2022 at 5:25 AM
    #210
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I drove a diesel truck from 2008 until last month. There were exactly 2 short periods over 14 years when diesel was the same cost or less . There is concern the current $2 a gallon premium is here to stay for a while.
