Toyota Accessories for 2021 Tundra TRD Pro that are "worth it"
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by j0wpa, Apr 12, 2021.
  1. Apr 12, 2021 at 6:39 PM
    j0wpa
    j0wpa [OP] New Member
    2021 Lunar Rock Tundra TRD Pro, 2020 Army Green Sequoia TRD Pro
    *Edit Update*
    Spray on Bedliner and Remote Tailgate lock will most likely be all I ask for. Going to do everything else myself after I take delivery.
    *Edit Update*
    I was lucky enough to be able to reserve a Super White 2021 Tundra TRD Pro from a dealer. They are asking if I wanted to add any accessories.
    Currently it has:
    Spray-On Bedliner
    Center Console Tray
    considering adding:
    Bed Step
    Console Safe
    Predator Steps
    Remote Tailgate Lock
    Black Tailgate Badge
    Tonneau Cover
    Can anyone share the pro/cons of getting these done on the initial build vs doing them myself afterwards vs getting something aftermarket? Thanks!
    Shamrock92 and Txstan like this.
  2. Apr 12, 2021 at 6:55 PM
    baron
    baron New Member
    Brett
    2021 TRD Pro
    Pro: It's done when you get it.
    Con: It's way more expensive than doing on your own after the fact. Look up the prices of those items on Sparks and compare to what the dealer/port will charge.
    For me, it's a convenience decision. I added some things to mine that I could've done myself like the Tailgate Lock because I'd rather it already be done.
  3. Apr 12, 2021 at 7:00 PM
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
    Possible pro: if you are financing, the cost of those accessories can be rolled into the monthly payment.
    I also believe that Toyota accessories that are purchased and installed by dealer are covered under full factory warranty.
    Not sure either of those are enough to justify the increased cost as @baron mentioned above though.
    j0wpa[OP] and baron like this.
  4. Apr 12, 2021 at 7:02 PM
    biebs96
    PA
    Add what comes with a warranty, keep in mind that now you are financing add-ons as well.
    That list of accessories are all very easy things to add on after the fact.
    Also there are hundreds of options for covering the bed. The factory cover...works, but is far from the most functional.
    j0wpa[OP] likes this.
  5. Apr 12, 2021 at 7:02 PM
    JohnsCreekTRDPro
    JohnsCreekTRDPro New Member
    Craig
    2021 Midnight Black TRD Pro
    Definitely consider some kind of step rails .. they’re useful for most people, especially kids and smaller adults. I got the stealth running boards on mine, mostly because they’re flat, not an eye sore, and very easy for my kids. I’m not personally a fan of the predators.
    and ya gotta have the TRD PRO bed stamp! Come on man!
    Wgusler and j0wpa[OP] like this.
  6. Apr 12, 2021 at 7:05 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    If you’re patient and can wait a little while, you can get deals on all of those add ons and at a significantly cheaper rate. I personally wouldn’t add the dealer mark ups on all those to a financing.....
    Patch999 and j0wpa[OP] like this.
  7. Apr 12, 2021 at 7:09 PM
    CENAIR
    CENAIR New Member
    PAUL
    I went with the spray bed liner from Zebart and think its the Rhino brand and came out awsome and its about 1/4" thick, very hard surface and great slip resistance and would recommend it highly and was about 500.00
  8. Apr 12, 2021 at 7:30 PM
    j0wpa
    Remote Tailgate Lock seems like the only option that would be a simple time saver from the get go. Would like to get some side rails so the kids can use them right away until i get something I actually like.
    Patch999 and TaquitoBandito like this.
  9. Apr 12, 2021 at 7:32 PM
    TaquitoBandito
    Joel (AKA Bif)
    I'd probably get the tailgate lock and maybe the side steps for the convenience of not having to do it myself. The badge would be nice too. I'd have to see what their markups are for everything else.
  10. Apr 12, 2021 at 7:43 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    It’s quite a bit more expensive at the dealer. Rolling it into your monthly payment makes it even more expensive over the long-term as you’re paying interest on the more expensive way to do it.
    But that might be worth it to you if you’d rather have it all up front and don’t look forward to doing that kind of stuff yourself.
    The DIY route avails you to far more aftermarket options, but you could still purchase OEM parts for cheaper and install them yourself. There are several dealers who sell online for decent prices. McGeorge Toyota and Lewis Toyota seem to usually have the cheapest prices online. Sparks is another option.
  11. Apr 12, 2021 at 9:54 PM
    TRDSnowInTX
    TRDSnowInTX New Member
    Ryan
    Do your own console safe. Mine had it already in when I got it and there isn't a tray that will fit. There are aftermarket ones you can install yourself that have the tray as part of the unit. I would say most of your list is stuff you can DIY for cheaper.
    j0wpa[OP] and TheBubbaDude like this.
  12. Apr 13, 2021 at 1:44 AM
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    Do you have a link to any safes that will accommodate a tray? I have the OEM safe that was installed by the dealer and hate that there are no organizer trays that work with it.
  13. Apr 13, 2021 at 3:04 AM
    shawn474
    MoCo, Maryland
  14. Apr 13, 2021 at 4:25 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  15. Apr 13, 2021 at 5:56 AM
    j0wpa
    Biggest issue right now is finding running boards that look similar to the TRD ones that come with the TRD Pro Sequoia my wife has... The kids have a real easy time with them.
    Badknees likes this.
  16. Apr 13, 2021 at 6:12 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Go Rhino - RB10
    j0wpa[QUOTED][OP] likes this.
  17. Apr 13, 2021 at 6:56 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I installed the bed step and it was well worth it as these truck beds are difficult to climb into without some type of assist.
    Also, not sure if the TRD Pros come with the TRD front and rear sway bars, but the added handling benefits are well worth the investment IMO. (but not so great if doing serious off-roading). Bed Step Closed.jpg Bed Step Open.jpg :
    EN2TUNDRA and j0wpa[OP] like this.
  18. Apr 13, 2021 at 6:58 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    I personally wouldn’t have the dealer do any add ons because they’ll upcharge it plus if you’re financing that’ll be more in interest that you’d be paying for. Save up, buy aftermarket parts (new or used) in the future. Just my .02, congrats on the upcoming purchase!
  19. Apr 13, 2021 at 8:56 AM
    bjfogal
    bjfogal MN Truckin'
    Ben
    Minnesota
    2021 MGM TRD Pro
    DiamondBack HD bed cover UpTop Overland Truss rack RCI rock sliders Coachbuilder lift and shackles Nitto Ridge Grapplers AJT mods Console Vault Carhartt seat covers Valhalla’s Shield Demello bumpers with Baja Designs lights (S8 bar, S2 Pro, Squadron Pro, S2 Sport) Auxbeam 6gang Switchpanel Superwinch SX10 Rago dash mount and bed stiffeners Pelican cargo cases (BX140R) RotoPax Matt Gecko LED bed lights AmsOil MP HD underspray
    On my PRO I had some essentials installed right away: Tailgate lock (dealer), window tint fronts (dealer), PPF (dealer), console safe (I'm CCW permit holder, so critical; installed myself), DiamondBack tonneau (I'm in MN...so snow, and able to secure belongings in bed), Amsoil MP spray (again...MN with salt; applied myself to undercarriage) and black accent badges (did myself).
    Steps or rock sliders are not *essential* but are nice, both for ease of access (kids/pets) and prevent door dings in parking lots: I went with RCI and love 'em (installed myself). AJT chrome delete package...recommended.
    That's a start. :)
    JohnsCreekTRDPro and j0wpa[OP] like this.
  20. Apr 13, 2021 at 12:15 PM
    Shamrock92
    Shamrock92 New Member
    Worth it - depends on the user...but knowing most everything can be added after delivery and at a lower cost or with greater options/selection makes me want to go aftermarket.
    One thing that was mentioned today to me by dealer - Bedliner.
    On the Toyota it will have the raised "TUNDRA" spelled out - if you like that look the Toyota is only way to add...but going AM gives you options on texture and color at around same price point.
  21. Apr 13, 2021 at 12:24 PM
    shawn474
    MoCo, Maryland
    Branden and j0wpa[QUOTED][OP] like this.
  22. Apr 13, 2021 at 12:40 PM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    The only thing I would do is bedliner and running boards....
  23. Apr 13, 2021 at 12:41 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    If I could go back and do it again...I wouldn't get any OEM accessories from my dealer.
    We negotiated 1/2 price accessories, but many are still overpriced.
    Bed Steps - removed
    Tundra Tailgate letters - removed as they started peeling off
    Bug Deflector - removed
    Rear Step - we got our OEM 1/2 price, installed, so I'm fine with this one.
    Line-X Premium - same as above.
  24. Apr 13, 2021 at 12:42 PM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Raptor has some very nice step bars and running boards. I founds my step boards very easy to install and the packaging was great. I bought the 4" wide step bars and the pads are very sturdy for both kids and Grandparents. I think you can get running boards as wide as 6". Definitely worth taking a look at. I have had mine over two years and have no issues with the step pads and the black paint has no fade or any problems.
  25. Apr 13, 2021 at 12:56 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    For me the only things I'd do at a dealer prior to buying would be stuff that requires the vehicle for a day or 2 - bed liner is a good example. Sure you can get it cheaper later but the convenience of not having to drop the vehicle off later is nice. Anything I can do in my driveway I'll do myself. With that in mind it changes from person to person - I'm perfectly fine to crawl under my truck to put on running boards, sway bars, exhaust - but I can see others that would much rather someone else do those things at a premium cost.
    One more caveat is the dealer may be maxed out on negotiating cost of the truck, it won't go any lower, but they still have room to negotiate accessories. I did this with the wife's Ram - they just kept coming back with either no change or tiny increments, so asked for ~$600 running boards instead and they came back at $300 on the boards. Would have cost me that to go aftermarket but now I get someone else to install them.
  26. Apr 13, 2021 at 1:01 PM
    j0wpa
    Everyone has brought up good points. I definitely feel comfortable under a truck. Not happy with the stock choices for running boards so I will probably have something aftermarket waiting to be put on when I go to pick up the truck. Spray on bed liner is an easy choice for me, so is the remote tailgate so there will be no warranty issues with it. Everything else I will do myself. Good excuse to spend time working on the truck anyways!
  27. Apr 13, 2021 at 11:22 PM
    TRDSnowInTX
    Ryan
    Just the one that was posted above. You will find various versions of that safe in these forums and they all come with a tray.
  28. Apr 14, 2021 at 6:29 AM
    Wgusler
    Wgusler New Member
    2021 TRD Pro
    Front and rear TRD sway bars were the best thing I added, huge improvement driving and towing.
  29. Apr 14, 2021 at 7:05 AM
    TheBubbaDude
    2020 Tundra TRD Pro
    Had my front installed 3 weeks ago. The handling is MUCH better. The rear was a game changer for sure.
    Badknees and j0wpa[OP] like this.
  30. Apr 14, 2021 at 8:16 PM
    j0wpa
    I just assumed the TRD Pro came with all the TRD stuff. Definitely looking into the sway bars.
    TheBubbaDude likes this.
