OEM bed step install without changing out the bracket
Discussion in 'General Tundra Discussion' started by lehminh, Mar 26, 2017.
  1. Mar 26, 2017 at 1:59 PM
    lehminh
    lehminh [OP] New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    image.jpg image.jpg image.jpg image.jpg Story: I bought a Toyota bed step on CL. The guys isn't realize the bumper bracket us different than stock. Rather than drive an hour back to him and pay bridge toll, I decided to cut the bracket where it hindered the step from extending. I compared the stock bracket vs the replacement and it's just a cut version. Any hoot the benefit of doing it this way is you don't have to remove the bumper to install, just take a saw to the three thin metal sections. Here's the pic. Note a better handyman could make nicer cuts.
  2. Mar 26, 2017 at 2:38 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Sweet mod and great skills!!
  3. Jan 26, 2019 at 8:39 AM
    Jaime
    Jaime New Member
    James
    2018 Tundra Limited
    Great job, can you send me some photos showing just where you made the cuts. It is unclear in the photos on the forum. I just received the bed step and can see no reason not to use your modifications. Thanks a lot
    jkuykendall1@stx.rr.com
  4. Jan 26, 2019 at 9:58 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I too would be interested in knowing exactly where you cut. Great pics just a little unclear what to look for...
  5. Jan 26, 2019 at 10:39 AM
    lehminh
    Facing the drivers side rear of truck, cut the metal bracket forms a triangle opening. Cut the metal bridge that forms the base of the triangle. I think if you cut it all the way to the end it’ll look cleaner than cutting it part way, prob safer too (accidental cuts if you get caught).EB7EBD64-CFF1-420E-90D9-BF382D748D2A.jpg984C6B0B-F6C4-46B7-84F3-AB6730C36D33.jpgD9DC804E-6837-42F8-8B16-BA5BC241B52D.jpg237ABEF5-9A67-4EAF-AF44-7EA03788C354.jpg
  6. Jan 26, 2019 at 10:47 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  7. Jan 26, 2019 at 4:07 PM
    Jaime
    Jaime New Member
    James
    2018 Tundra Limited
    Thanks a lot. I will use this information and install the bed step. Looks just as strong as the replacement that came with the accessory.
  8. May 13, 2019 at 10:27 AM
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    So if you had followed the instructions you would have replaced that bracket with one that didn't get in the way of the step, or would there not be a new bracket?
  9. May 13, 2019 at 11:09 AM
    lehminh
    Following the instructions you’d have to take off the bumper and replace the bracket with one that came with the step, then put the bumper back.
  10. Mar 20, 2020 at 7:21 PM
    torkman
    torkman New Member
    2020 Tundra 4x4
    Lehminh: Thank you very much! I just received my step for my 2020 and saw your post/pics. I used a cutoff wheel, took my time, filed off cut edges to smooth finish and painted satin black to keep area from rusting. I had the step installed 15 minutes after that with no disassembly of anything else. I did use the one angled bracket that comes in the kit and connected under one of the top bolts on the step hinge. The place that it attaches to the truck is where the existing brace that you cut still has a bolt at the bottom corner of the chrome bumper. I just put the bracket on top of the bolt sticking up and put a nut on the bolt. Probably not needed since the existing bracket was never removed, but it does provide a bit of extra support.
    Anyway, I would NEVER recommend anyone go through all of the hassle of taking the OEM bracket off. Just cut it as he says and if you do a nice job of the cut and finish you will not even know it was fabricated. So easy!
    Step works great. Easy in and out of bed.
    lehminh[OP] and Boerseun like this.
  11. Mar 20, 2020 at 7:35 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I did the same. Much easier than to take the bumper apart to replace the bracket, which looked like it might be flimsier than the OEM one anyway.
    There was a smaller strap bracket with the kit that bolts to the top of the step bracket and to the side of the bumper bracket that I used. It required a little more cutting on the OEM bumper bracket, but that thing is now very sturdy.
    Tundra805, Beesta and lehminh[OP] like this.
  12. Mar 23, 2020 at 7:26 PM
    Sparky619
    Sparky619 New Member
    2019 TRD Pro Storm Trooper
    I installed one on my previous Tundra and it was a pain in the ass. If I ever have to install another one, I will use the cut method.
    Ernie68 and Boerseun like this.
  13. Mar 26, 2020 at 2:05 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    SC_TRD likes this.
  14. Mar 28, 2020 at 6:52 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Gotta love the “Search” function! Found this thread and saved a ton of time and headache! I saw a video on YouTube where a guy did the bracket replacement and what a PITA!
    Took 5 min to cut the factory bracket, spray some black paint and 10 min to install the bed step! Great mod and thanks the @lehminh and @torkman for the tips!
    80DA9C65-C0E4-48A1-ADD1-AB79F3CFAE7C.jpg 586F97D9-B60E-41DC-B967-CEFE8E16F80D.jpg EA878F58-908F-46A6-8775-D590FAF31077.jpg
  15. Jun 2, 2020 at 5:47 PM
    gegs310314
    gegs310314 New Member
    St. Louis
    2019 Platinum
    Hi all.
    So I bought the AMP step and took it to my dealership for install while getting the standard service.
    Dealer called and said they can’t Instal the step... they retried and “it just didn’t look right” and the box says it’s for a 2016.
    after some great customer sevice form RealTruck, I find out that the step “can not” be installed on resin bumpers. (Have a 2019 platinum)
    has anyone else had this problem?
    any recommendations on alternative steps or even ladder?
    appreciate and help.
  16. Jun 2, 2020 at 5:57 PM
    lehminh
    I wouldn’t think it matters because it installs on the frame and doesn’t even touch the bumper. I would see it it fits closed and the opened, if so cut that thin piece out as it shouldn’t affect much. Sometimes part say it’s not made for certain year but it fits fine. Good luck, I use my bed step every time I open the truck bed.
    glowblue likes this.
  17. Jun 2, 2020 at 6:33 PM
    glowblue
    VA
    No need to have a dealer install - it’s super easy. If they can’t do it, find a new dealer to have service done.
  18. Jun 5, 2020 at 8:49 AM
    Boerseun
    Ferdie
    Sarasota Florida
    The dealer doesn't know what they are talking about. The resin bumpers require an extra step ; either replace the bumper bracket, which is a pain in the rear, and you have to order the model number that includes the bracket, or, what most of us do, is cut the existing bracket - only a small piece needs to be cut out to allow the step to fold down. If you do not have the tools (grinder) and due to inexperience don't want to cut on your truck, then you can order the correct step that includes the bracket, and try that. However, keep in mind that there is a model that folds open to the side, instead of diagonally backwards. This was done to avoid the bracket issue, but it is not ideal. The step ends up on the side of the truck (below the end of the bumper) instead of at the back where you can easily step on the tailgate.
    But, to answer your question, it can be installed on your truck. See first few posts of this thread
  19. Aug 6, 2020 at 4:49 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    This thread was just what I needed. I tried installing thr AMP bed and as I was removing the rear bumper brackets I realized the whole bumper needed to come off in order to remove the whole bracket. I will definitely try this method when I get a chance. Thank yoi everyone!
    Boerseun likes this.
  20. Sep 27, 2020 at 11:41 AM
    TundraCowboy88
    TundraCowboy88 New Member
    Ben
    2020 Cavalry Blue Tundra Crewmax
    I just installed this and went with the cutting method rather than replacing the bracket. Cutting was easy... hardest part for me was unscrewing the 2 bolts where the step attaches to the truck. The space in there is so limited it was hard for me to get enough leverage but i finally did with my 19 mm combination wrench. Pretty tough install considering all factors, but the bed step is awesome and I know I’m going to be using it all the time. Pretty pumped.
  21. Sep 27, 2020 at 3:52 PM
    glowblue
    VA
    Nice job I love my bed step and the bracket mod is the way to go!
  22. Oct 5, 2020 at 5:34 PM
    aark12
    aark12 AARK12 - Hello All
    New Mexico
    2020 Tundra Limited TRD
    Bilstein 6112, Pedal Commander, TRD Pro BBS Wheels, Gator Tonneau Cover, Bed Step, TRD Pro Grill, Mirror Caps, Grab Handle, Dirty Deeds 10in System, rear bumper step, dash cam
    7EF696B1-E387-4C3A-8FB6-2ABF187CF74C.jpg A312A4E7-2873-4DFA-AB19-3B10D0B9FA43.jpg Thanks for the posts. I decided to do the same thing and it came out great. No bumper disassemble required!
  23. Oct 5, 2020 at 6:24 PM
    lehminh
    Now that I’m looking at the sharp shaved edge, I have some of those door edge guards that can fit over the metal to protect against my clumsy butt from cutting myself on the future.
    kakav likes this.
  24. Nov 18, 2020 at 9:50 PM
    yodanadane
    yodanadane New Member
    Thanks for the write up , I added OEM bed step without removing the factory bracket also without using the shim and it was a breeze .
    lehminh[OP] likes this.
  25. Nov 28, 2020 at 9:24 AM
    Talkdirttome
    Talkdirttome Dad
    Jon
    So Cal
    2018 Silver Tundra CM 4x4
  26. Nov 28, 2020 at 11:25 AM
    glowblue
    VA
    Link doesn’t work for me but there should be no reason why the bed step won’t work for a 2018. Must be a website glitch.
  27. Apr 29, 2021 at 1:35 PM
    kakav
    kakav New Member
    Kay
    Toyota Tundra SR5 DoubleCab 6'"6 bed, Cavalry Blue, Model 2020
    Undercover Armor Flex Tonneau, 5" Stainless step bars, Opti-Coat, Offroad Desert Eagle Cat Protection
    I added the edge guard I had from the motorcycle fairing and it made it much safer to work.
  28. Jul 17, 2021 at 9:32 AM
    Tarheel4life
    Tarheel4life New Member
    David
    2021 Cement Tundra 4x4 SR5
    Lehminh, what a great mod! I just traded my Taco for a 2021 SR5 and knew I had to get a bed step. Dealership was about $60 cheaper than AMP Research site, but no instructions in the box. Google gave me the AMP instructions and the youtube video of the guy who went by the instructions and removed the bumper cap. Looked like a real PITA. Then I saw this thread. 10 minutes with the angle grinder, file and paint the exposed metal and the step went on perfectly. Even used the support strap. Great idea for an easy install!
    Boerseun and lehminh[OP] like this.
  29. Jul 22, 2021 at 6:23 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    @aark12 Is your step the OEM Toyota version?
    I also wanted to ask, if not to much trouble could you post a pic with the step in the up position? It seems I remember seeing pics of some trucks with the step looking a bit low and crooked.
  30. Oct 8, 2021 at 10:11 AM
    STLRFAN4
    STLRFAN4 New Member
    2023 SR5 TRD TUNDRA - MGM
    Adding Weathertech Alloy Tonneau Cover.
    I ordered the OEM step for my 2019 Tundra and downloaded the installation instructions. After reading thru the instructions I got under the truck and quickly realized/decided that the mod of the existing factory bracket was the way to go. I used my sawzall with a thick metal cut blade and it worked perfect. I then filed down the sharp edges and applied a coat of flat black rustoleum to protect. All said and done in about 45 minutes or so. Definitely the way to go. Here are some pics: 00F83727-ADDF-445C-B945-487169609E9A.jpg C286A1D2-B83D-4D32-A6A0-F576B4473490.jpg 33E28171-9877-46B7-96A9-EA6DDC8F4E0C.jpg 9F3D9E0E-593F-499B-9E4D-B688F2FDFBF7.jpg
