Toyomafia - The Clubhouse. Balls and Burgers Summer 2025
  1. Oct 30, 2021 at 10:29 AM
    Outbound
    Aaron
    Northern Alberta
    Oh perfect! We have a crew member already established in a FOB. Commence supply drops!
  2. Oct 30, 2021 at 10:32 AM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    What’s about Wyoming?
  3. Oct 30, 2021 at 10:34 AM
    Outbound
    Aaron
    Northern Alberta
    We'll take it too.
  4. Oct 30, 2021 at 10:35 AM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Ok, good, @AzureNightmare is there so it’s probably already a done deal.
  5. Oct 30, 2021 at 10:46 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    wtf
    um, ok.
    Yeah, if y’all ever need any advice on mechanical fastening, nails, anchors or pretty much anything used to put shit together, I sold construction fasteners and products for 18 years.
    I assisted with R&D at the company I worked for, Conducted in the field testing and submitted tons of information for approvals on many of the screws you see being used today. If any of you crew have a question, Feel free to hit me up. I also did commercial construction previous to that and I currently build shit.
    If it goes above my head I’m sure @RainMan_PNW Would be happy to assist with any questions as well.
  6. Oct 30, 2021 at 10:48 AM
    Outbound
    Aaron
    Northern Alberta
    So what you're saying is...you know how to screw.
  7. Oct 30, 2021 at 10:49 AM
    Hightide
    Abalama
    Magic School Bus
    exactly.
    Plus I was a gigolo at one point.
  8. Oct 30, 2021 at 10:55 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s just temporary! The final will be a bigger slap!!
    I know how to screw, but time got the best of me.
    jewsNbrews, gosolo, NWPirate and 3 others like this.
  9. Oct 30, 2021 at 10:57 AM
    FrenchToasty
    Mo
    Bone stock
    Slap central organized a little better. Pretty sure I have a sticker thief in the house. 415FA05D-4CA6-4514-91EC-669B327B9937.jpg
  10. Oct 30, 2021 at 10:58 AM
    Hightide
    Abalama
    Magic School Bus
    Uh oh.
    Inside jobs are the worst
  11. Oct 30, 2021 at 11:00 AM
    Hightide
    Abalama
    Magic School Bus
    No no…
    I was referring to the guy replying to Joel.
    I can’t help your situation.
    That requires a professional.:p
    jewsNbrews, gosolo, Barrett50 and 2 others like this.
  12. Oct 30, 2021 at 11:05 AM
    FrenchToasty
    Mo
    Bone stock
    Haha ok, it took about 13 minutes before I head the “ew wtf is this?”
    That could be lots of stuff in this house and I didn’t know which room it came from. Then I knew she was in the bathroom, I fixed the hole didn’t I?!
    The ew wtf is this, i had early this morning walking back to bed I step on something cold and wet and juicy…….. usually it’s cat vomit……. It was the cats but not vomit. The big cat LOVES tomatoes, he stole two actually and half ate one in the hallway by my door for me to step on.
  13. Oct 30, 2021 at 12:43 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If it’s okay to kick out all the current residents, I want southern Italy
  14. Oct 30, 2021 at 12:44 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    There’s nothing quite like stepping on a grape in the dark middle of the night, half asleep…
    Ask me how I know….
  15. Oct 30, 2021 at 12:53 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Okay, here’s one that always bothered me;
    Some concrete jobs specify epoxy coated rebar. They even make you use coated tie wire and epoxy paint any cut rebar ends.
    We all know that the concrete binds to the deformed bumps on the rebar.
    On other jobs with regular rebar, when you get a little form oil overspray on the steel, the engineers and inspectors go apeshit about the oil and make you sandblast it spotless.
    WTF?
  16. Oct 30, 2021 at 1:04 PM
    NWPirate
    Zach
    WA
    I've got a roll of that green coated tie wire, good for a thousand things!
    jewsNbrews and gosolo[QUOTED] like this.
  17. Oct 30, 2021 at 1:09 PM
    Hightide
    Abalama
    Magic School Bus
    Ive highlighted your issue.
    This one may be more up Casey’s ally.
    I’ve found this to be a regional thing.
    At times based on local codes and at times based on the design and engineering firms on the project.
    Some would say, it’s a safety thing.
    Some would say, it’s just extra reassurance.
    Some would say, it’s redundant overkill done purposely.
    I will say though, in concrete failures, it can often be traced back to contamination of the inner rebar that was the cause of failure.
    I was on a job where there were instructions to clean every bit of manufacturing oil off of the corrugated metal decking before welding to the red iron.
    Over 250,000 sqft cleaned by hand. Both sides.
    It really boils down to that safety divisor.
    Fotnot, jewsNbrews and gosolo[QUOTED] like this.
  18. Oct 30, 2021 at 1:10 PM
    Have you ever brined a pork belly and smoked your own bacon? If so what brine do you use?
  19. Oct 30, 2021 at 1:10 PM
    Hightide
    Abalama
    Magic School Bus
    Cat tomato vomit has got to rank pretty highly on the, ew chart.
  20. Oct 30, 2021 at 1:19 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Most failures I have seen are the result of insufficient coverage; having the steel too close to the surface or form. Road chemicals or ocean salts penetrate due to porosity and the rebar completely corrodes leaving little tunnels or else the thin cover of concrete spalls and cracks.
  21. Oct 30, 2021 at 1:25 PM
    Hightide
    Abalama
    Magic School Bus
    Absolutely.
    Even sufficient coverage can be affected by other issues.
    When firing a powder tool, a gas tool or drilling for an anchor into the concrete, can leave little areas of vulnerability allowing penetration.
    gosolo[QUOTED] and jewsNbrews like this.
  22. Oct 30, 2021 at 1:28 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    This. I've done it with turkey also. Hours later and still too hot to handle.
  23. Oct 30, 2021 at 1:28 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I am good with this plan as well.
    Black Wolf, gosolo, Barrett50 and 3 others like this.
  24. Oct 30, 2021 at 1:31 PM
    Hightide
    Abalama
    Magic School Bus
    We need to layout location and plans for the 2nd complex.
  25. Oct 30, 2021 at 1:33 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Oh, hey, it's Europe too now. @gosolo If you need a neighbor, I might like to find myself on the other coast of the Adriatic. The whole thing, if that's fine with the rest of you guys. Whatever clearing mechanism we were using for N.A., let's adjust settings so that only the other men get gone. I could dig an eastern european harem...
  26. Oct 30, 2021 at 1:42 PM
    Azblue
    The Dirty T ( ^_^)_且
    Black Wolf, NWPirate, gosolo and 6 others like this.
  27. Oct 30, 2021 at 1:47 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Farragut State park. Already has old foundation we can throw in the plans.
    Black Wolf, NWPirate, gosolo and 4 others like this.
  28. Oct 30, 2021 at 1:49 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I always just associate it as a county in Montana.
    NWPirate, gosolo, Leo's first and 5 others like this.
  29. Oct 30, 2021 at 1:52 PM
    RainMan_PNW
    Casey
    Clark County, WA
    ^^^This^^^
  30. Oct 30, 2021 at 1:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    And there’s a submarine test facility nearby too. Given the central location, this may need to be our capital.
    NWPirate, gosolo, Leo's first and 4 others like this.
