Towing
Discussion in 'Towing & Hauling' started by Den, Oct 11, 2022.
  1. Oct 11, 2022 at 5:25 PM
    Den
    Den [OP] New Member
    Dennis
    What’s the max weight travel trailer with 5 passengers and camping gear in truck can be pulled
  2. Oct 11, 2022 at 5:27 PM
    Need a bunch more information Dennis.
    I would also check the towing section on the forum. This will answer any questions you have.
  3. Oct 11, 2022 at 5:27 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  4. Oct 11, 2022 at 5:35 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    It varies.
  5. Oct 11, 2022 at 6:25 PM
    mountainpete
    It ranges.
  6. Oct 11, 2022 at 6:54 PM
    it really depends on a range of variables.
    Jaypown, hagrid, Gaston and 4 others like this.
  7. Oct 11, 2022 at 7:22 PM
    Retired...finally
    Do you and your passengers prefer Planet Fitness or McDonalds?
  8. Oct 11, 2022 at 7:26 PM
    mountainpete
    To varying dependencies.
  9. Oct 11, 2022 at 7:27 PM
    But within a specific range.
  10. Oct 11, 2022 at 7:29 PM
    mountainpete
    Plus or minus 100%.
  11. Oct 11, 2022 at 10:34 PM
    blenton
    blenton New Member
    Is your tundra silver with the red letter package?
    SD Surfer, hagrid, Gaston and 2 others like this.
  12. Oct 12, 2022 at 4:58 AM
    Retired...finally
    A simplified answer would be to load your truck as if you were going camping and have it weighed. Top the tank off before hand. Subtract that number from the GVWR of your truck. The resulting number will be your maximum tongue weight. Multiply the tongue weight by 10 to get your total trailer weight.
    Now if your total trailer weight comes out to 5,000# or more you will need a weight distribution hitch which BTW further reduces your payload by about 75#.
    Also note that most travel trailers are built nose heavy and it will take some creative packing to get them at that magical 10% tongue weight.
    JDR76 likes this.
  13. Oct 12, 2022 at 5:01 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You can go up to 15% tongue weight.
    JDR76 likes this.
  14. Oct 12, 2022 at 6:26 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Towing capacity is directly proportional to the amount of transmission coolers you have installed.
    1 cooler = no effective increase.
    2 coolers = .25% increase.
    6 coolers = 3% increase.
    6 coolers mounted on a rooftop mast = 2000% increase.
