Towing up a grade in the summer...
Discussion in 'Towing & Hauling' started by 909engineer, Jul 2, 2018.
  1. Jul 2, 2018 at 11:56 PM
    909engineer
    909engineer [OP] New Member
    2017 Silver SR5 CM
    I'll be dragging my smaller trailer up the grade between Bishop and Mammoth Lakes. Looking at the weather, it's going to be almost 100 degrees as I start my ascent.
    I know it'll be fine, but is there anything that I should be aware of? Am I worrying too much? Should I just keep it in tow/haul mode and let the big dog eat?IMG_0034.PNG.jpg
    Black Wolf likes this.
  2. Jul 3, 2018 at 12:56 AM
    LML 3500HD
    TH mode and watch gauges.
    909engineer[OP] and Black Wolf like this.
  3. Jul 3, 2018 at 1:29 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    619Tundra and 909engineer[OP] like this.
  4. Jul 3, 2018 at 4:43 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Th and let it eat, the trans fluid does run hotter in these trucks but if it was an issue I'm sure Toyota would have addressed it. You can also grab a scangauge or ultragauge to watch those trans temps as well if you don't have one.
  5. Jul 3, 2018 at 5:04 AM
    15whtrd
    15whtrd Mr. Blonde
    I use TH amd S mode. I try to limit the trucks upshift and downshifting by choosing the right gear for the grade, and holding it. Upshifting on the flats. I typically won’t go past 5th so it doesn’t hunt.
    I kind of drive that way anyways with or without trailer except for using 6th more often.
  6. Jul 3, 2018 at 6:22 AM
    909engineer
    2017 Silver SR5 CM
    It's a bit less than 3500lbs with it loaded. Not hauling any water as the site has full hookups.
    Thanks for all the feedback guys. We did the same trip with our Odyssey last summer and I pegged the temp gauge. That whole trip with the serious crosswinds and climbs was sketchy AF. Hence the Tundra...
    landphil and ColoradoTJ like this.
  7. Jul 3, 2018 at 10:10 AM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    Leave it in a lower gear with the torque converter locked, you should be just fine.
    15whtrd likes this.
  8. Jul 3, 2018 at 10:43 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Let it rip! I tow 3500 at 10,000 feet all the time.
    ColoradoTJ likes this.
  9. Jul 3, 2018 at 10:45 AM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I see you are hitting almost 7000 feet. I live daily at pretty close to that altitude. You’ll have no issues.
  10. Jul 3, 2018 at 10:46 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Piece of cake. I’ve towed over 8k up and down 395 with no issues. Put it in tow haul and lock it in 5th unless you are downhill.
  11. Jul 3, 2018 at 4:30 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    No need to worry about a single 10mi grade. Just did a trip from WI to WY with 5000lbs. No issue, just put it in tow haul and pressed the gas.
  12. Jul 3, 2018 at 4:45 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    The only thing u need to worry about is to pack your fishing poles and go fishing.
    lewi3069 likes this.
  13. Jul 13, 2018 at 10:25 PM
    909engineer
    2017 Silver SR5 CM
    Thanks for all the advice. We did the trip with no issues climbing the grade. I was mightily impressed.
    On the way back, the temps hit 106 with serious cross winds. I didn't really notice the breeze until the toy hauler in front of me started wandering all over the road. We then hit an epic thunderstorm coming down the Cajon pass. Winds, lightning, marble sized raindrops. I was concerned about hydroplaning while towing but it didn't even flinch.
    I. Love. My. Truck.
  14. Jul 13, 2018 at 11:02 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Nice! Glad everything worked out.
  15. Jul 14, 2018 at 9:46 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    And to think I thought TH mode just changed the pedal/throttle mapping ..
    BTBAKER likes this.
