Towing travel trailer with a lifted truck
Discussion in 'Towing & Hauling' started by Luv2_4x4, Jan 31, 2021.
  1. Feb 4, 2021 at 1:10 PM
    Luv2_4x4
    Luv2_4x4 [OP] From Tacoma to Tundra 02/14/21
    2006 DC 4WD V8
    Any suggestions?
    owner decided not to sell to me so problem solved. im back on the search for an 06 tundra 4x4 v8
  2. Feb 4, 2021 at 1:33 PM
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    however i am still interested in learning about gear ratio if anyone would like to explain it.. i would like to buy a truck with a 3" lift :burnrubber:
  3. Feb 4, 2021 at 1:45 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Bummer about that truck. But things happen for a reason im sure something closer will pop up for you.
    Look up ring and pinion to see what they look like. They sit in the bulbous part of the axles. They have a ratio number, such as 3.55:1 or 4.30:1 on the 5.7 tundras. The higher number (called “lower”) gears turn more times per twist of the axle, thus increasing leverage over the axle. This gives the vehicle easier ability to turn taller/heavier tires. Taller tires will reduce your engine RPMs for a given speed vs stock tires. So adding driveline turns through lower gears will get those engine RPMS back up to where you want them.
    yes they help in towing a ton, but they also help the truck drive like stock with taller tires every day.
    Hope that helps!
    Luv2_4x4[QUOTED][OP] likes this.
  4. Feb 4, 2021 at 1:53 PM
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    most definitely helps. great info thank you soo much!
    Hbjeff[QUOTED] likes this.
  5. Feb 4, 2021 at 6:23 PM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    @Hbjeff @Luv2_4x4 basically the numerically higher the axle ration the easier it will spin bigger tires or pull a load. If you gear it down (numerically higher) further, it will easier spin both bigger tires and the load.
    Luv2_4x4[OP] likes this.
  6. Feb 4, 2021 at 6:25 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    With stock tires yes, but with upsized tires lower gears just return you to your stock final drive ratio
  7. Feb 4, 2021 at 6:27 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    @hb Jeff yes sorry... I guess I meant that gearing it down more than you need to will help when you have bigger tires. Returning to stock ratio wouldn’t be too bad either for towing as long as the tires aren’t that much bigger.
    Hbjeff likes this.
