Towing trans tests
Discussion in '2.5 Gen Tundras (2014-2021)' started by Creepbam, Jan 5, 2022.
  1. Apr 21, 2022 at 7:18 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd say go with the cooler to be on the safe side but I'm just a 2016 owner who never monitors Trans temps :notsure:
    Sumo91 and MadMaxCanon like this.
  2. Apr 21, 2022 at 10:49 AM
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    I took my truck up to the mountains the other day. It go up to 190 with the torque converter running in the 200s. Normal and safe to me.
  3. Apr 21, 2022 at 11:44 PM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    I have been towing smaller campers for years with my 08 Tacoma, 17 4Runner, 19 Tundra 4.6 (big mistake) and now a 17 Tundra 5.7. I used a ScanGauge2 in all instances. One thing I learned is when your just cruising along in any gear, there is no heat being generated in the transmission. I could drive an hour and have temps stay at 200F or below. The only time when heat is generated is when the torque converter unlocks and the transmission starts to hunt or downshift. It's when the torque converter unlock is when heat spikes.
    Personally I use Tow/Haul mode and bump through S4 S5 S6. If I'm on a flat section S6, if in light rolling hills, S5, and heavier climbs, S4 or S3. If I'm in S3, I drop my speed, I'm usually in no rush.
    One lesson. On a cross country trip with the 4Runner and a 17' trailer, elevation was the enemy, I couldn't beleive how much power was lost higher up. You lose 3%hp per 1000' of elevation unless you have a Turbo.
    Oey12 likes this.
  4. Apr 22, 2022 at 12:54 AM
    Blue By U
    Blue By U New Member
  5. Apr 22, 2022 at 2:46 AM
    Retired...finally
    Who revived this horse we've beaten to death...
    Cpl_Punishment likes this.
  6. Apr 24, 2022 at 9:50 AM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    How are you measuring engine oil temp? Your post implies you are measuring it separate from trans temp.
  7. Apr 24, 2022 at 6:52 PM
    Creepbam
    Creepbam [OP] New Member
    2020 SR5 4x4
    OBD Fusion
