Towing problems- No transmission cooler on 2020 TRD Pro
Discussion in 'Towing & Hauling' started by RIck729, Jun 16, 2020.
  1. May 27, 2021 at 3:46 PM
    #91
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If I burn out my transmission while towing, I'll dump my truck for something with more payload.
  2. May 27, 2021 at 3:55 PM
    #92
    Blue Thunder
    Washington
    Just here so I can post :deadhorse:
  3. May 27, 2021 at 4:05 PM
    #93
    timsp8
    NY
    I keep wondering why people want to tell others how to spend their money.
    You want to pay more for a TRD Pro and immediately change the suspension? Everyone asks if they can buy your
    Pro suspension and wants pictures of new setup.
    You get new tires on you truck with less than 1000 miles? People want pictures.
    You want to add a trans cooler with your own money? Let me tell you how wrong you are and how you just ruined your truck, warranty, and will die alone.
  4. May 27, 2021 at 4:53 PM
    #94
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    You drank that Toyota bath water. Good luck with your puck and keeping temps below 265 towing 5000lbs or more.
    Neo258 and avssuc like this.
  5. May 27, 2021 at 5:31 PM
    #95
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I don't think anyone here is telling people how to spend their money, hell, spending money on Mods is what most of this forum is all about. I think it gets lost on some, that pushing a purchase for a problem that doesn't really even exist yet can get pretty tiresome.
  6. May 27, 2021 at 9:44 PM
    #96
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    I’m an idiot, so I guess I need this explained more slowly...
    Why are people concerned about trans fluid temps around 230-240 when the idiot light doesn’t come on until after 300? Seems pointless except to tell you to head to the dealer for a new transmission. Sorry, something just doesn’t add up if the fluid is already “cooked” well before that.
  7. May 28, 2021 at 12:19 AM
    #97
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Good luck with your 2018. Ive never seen anywhere near 265 so thanks for your concern.
    Jtundra81 likes this.
  8. May 28, 2021 at 4:26 AM
    #98
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    ^ This! Just did a 12 qt drain and fill at 120k on my '18 (tow 8k 5ver and 5k boat 5-10k miles a year). The old fluid was as clean as the new going in...
    szabo101 and JStrabler1 like this.
  9. May 28, 2021 at 4:28 AM
    #99
    timsp8
    NY
    I don’t think I’ve seen anyone force or push others into buying a trans cooler. But some people are strongly against others buying one. I didn’t really need a led light bar, but no one is posting data on the lumens of the lights that Toyota provided and saying I was fine without it and it’ll void my warranty. There’s been no proof Toyota will void warranties if someone adds the cooler. If someone adds a trans cooler, it seems to be the end of the world.
    Terndrerrr likes this.
  10. May 28, 2021 at 4:30 AM
    #100
    timsp8
    NY
    If you have the 5.7, then you have a trans cooler. This is kinda an argument FOR having one. You shouldn’t have ever reached temps at or over 230/240.
  11. May 28, 2021 at 4:54 AM
    #101
    ScottsTundra
    ScottsTundra New Member
    2017 SR5 Crewmax
    Headwaters seat covers, Undercover Flex
    I don’t mean to derail this thread or anything, but I asked on another thread and never got much traction.
    Is the lack of transmission cooler on the 2019+ Tundra specific or 5.7l specific?
    Do the 2019+ sequoias not have a transmission cooler?
    Did they ever have a transmission cooler?
  12. May 28, 2021 at 4:59 AM
    #102
    Nm6300'asl
    2022 DC SR5 4x4
    I use obd fusion app 2 moniter pan and tc temps. With just me and a few hundred lbs of tools in the truck I can see temps 225-230 (even in winter), on long hills/going thru mountains. Pretty sure toyota knows what they are doing.
    JStrabler1 likes this.
  13. May 28, 2021 at 5:07 AM
    #103
    timsp8
    NY
    Some 19-21 guys have posted seeing over 250. I never said Toyota didn’t know what they were doing. I don’t care one way or the other because I’ll never own a 19-21 tundra. Just pointing out the irony of you posting that things are good in a thread about the removal of the cooler when you have the factory cooler.
    Looks like Toyota knew what they were doing when they added a cooler to your truck.
  14. May 28, 2021 at 5:11 AM
    #104
    Nm6300'asl
    2022 DC SR5 4x4
    What I am trying 2 say is that in certain conditions I have seen the same/near the same temps with a cooler that the non cooler people are so worried about. Even when temps are in the 30's.
    timsp8 likes this.
  15. May 28, 2021 at 5:12 AM
    #105
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    There’s an an extremely simply solution to Toyota not putting a trans cooler in the Tundra.
    Slow down... Towing at 65 will create significantly less transmission heat than driving 70 +.
    I personally could care less about it. I drive according to what my vehicle can handle and the conditions present. My personal opinion is that if you care about your Tundra, use it for what you need but don’t beat the piss out of it. And with that said the vast majority of Tundras with no transmission coolers will not self destruct in the years to come.
    Allrsdup and Nomoredomestics like this.
  16. May 28, 2021 at 5:12 AM
    #106
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    For 11 years of production 200F was the temp that Toyota decided was best for the Tundra then all of a sudden they realized that up to 260F was good and the transmission didn't need an external cooler. OK.
    The reason the cooler was dropped in 2019 was because the AC refrigerant when to R1234YF. They could no longer use the AC to cool the transmission because the new refrigerant isnt as efficient. The decision was made based on cost and testing shows no problems under normal conditions. Normal condition are not towing up a mountain at 90F. The few owners that do abnormal towing would be covered under the warranty.
    jordoncloutier and timsp8 like this.
  17. May 28, 2021 at 7:56 AM
    #107
    CurtisLemansky
    2017 SR5 CM TRD OR
    All right, that makes sense. I guess I’m having trouble with the statements saying it’s “common knowledge” that your fluid will be “cooked” if it hits 265-275 when that is still well before the idiot light. Again, I’m a moron when it comes to this stuff... still doesn’t add up.
    Ruggybuggy[QUOTED] likes this.
  18. May 28, 2021 at 8:05 AM
    #108
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I bought, have yet to install, the cooler kit from Nick. Maybe I need it maybe not. I live in an area with a lot of hills and tow 3000 to 6000 frequently and my temps run 225° when towing. The only harm that I see from installing the kit is to my wallet and a possible argument with Toyota if I have a transmission failure. However, I feel that Toyota will have an uphill battle explaining to me how a kit with many Toyota parts caused harm to a transmission.
    JJtruckon likes this.
  19. May 28, 2021 at 8:28 AM
    #109
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Higher trans temps that hit "higher" temps will just shorten the service life of the transmission fluid. My personal experience was that I was seeing above 245F towing and it was easier for me to install the cooler kit than to have to change the trans fluid every year.
    crewmaxlmt likes this.
  20. May 28, 2021 at 8:40 AM
    #110
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    The interesting thing will be to see what Toyota does with the 2022. God help this board if they put the transmission cooler back on. The “I’m going to sue Toyota and get my trans cooler” crowd will be back in full force.
    If they leave it off again it may suggest the end of the previous generation was kind of a test towards the future
    CopFiveO, Allrsdup, GODZILLA and 6 others like this.
  21. May 28, 2021 at 8:49 AM
    #111
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Ya I'm not sure what all the fuss is about the cooler being off. Most really dont need it and if you do, install it. Twenty years ago most trucks just had a cooler in the rad and if you wanted to tow it was necessary to install a ambient trans cooler.
    Kn4x2 and Clemsonman14[QUOTED] like this.
  22. May 28, 2021 at 9:11 AM
    #112
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    The 2018 and older models with tow package used the AC refrigerant to cool trans fluid? I thought it was an external air-to-oil cooler.
  23. May 28, 2021 at 9:22 AM
    #113
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    2014-2018 that used the AC condenser to cool. 2013 and prior used a ambient cooler in front of the rad.
  24. May 28, 2021 at 9:38 AM
    #114
    crewmaxlmt
    scott
    Of the ones that have installed a cooler, have you left the puck unpinned or pinned?
  25. May 28, 2021 at 9:51 AM
    #115
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Always remove the pin. It allows the thermostat to work correctly and control the temperature of the transmission.
    GODZILLA likes this.
  26. May 28, 2021 at 9:55 AM
    #116
    crewmaxlmt
    scott
    That is what I was leaning towards.
  27. May 28, 2021 at 10:25 AM
    #117
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    but the head toyota mechanic said "they dont need them" :rofl:
  28. May 28, 2021 at 10:39 AM
    #118
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Who's the head mechanic? Automotive technicians are not engineers.
  29. May 28, 2021 at 10:44 AM
    #119
    Tundra18overland
    Jesse
    GA
  30. May 28, 2021 at 10:51 AM
    #120
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    Just for the sake of numbers, I have towed my 7600 lbs TT from AZ to Norcal, on Tuesday. 2012 with tow package. The highest I have seen was 242° at the TC, while going up hill in 3S.
