Towing problems- No transmission cooler on 2020 TRD Pro
Discussion in 'Towing & Hauling' started by RIck729, Jun 16, 2020.
  1. Jul 11, 2021 at 12:13 PM
    #331
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
    You cannot void the warranty using fluid specified as meeting the WS standards.
    Wallygator likes this.
  2. Jul 11, 2021 at 12:34 PM
    #332
    Wallygator
    I already have a cooler and have done the ridiculous process to check the fluid level. Was just curious how much the dealer charged for your flush cuz I'm thinking about having that done. Already have a 2.5 gal bottle of the Amsoil WS. I was gonna just drain and fill multiple times but may have the dealer flush instead. Just don't know if I trust them.
    Dirtytruck[QUOTED] likes this.
  3. Jul 11, 2021 at 12:54 PM
    #333
    Jaxyaks
    Jaxyaks New Member
    I do a few things with all my towing vehicles, I lock out the overdrive gears unless on flat ground and I usually buy or usually negotiate into the deal an extended powertrain warranty that takes me to about 120K...Then I use the crap out of the truck and trade before warranty is up. Toyotas almost always trade well, and keeping them until I smoke the transmission makes no financial sense to me at the costs of replacements and the lost resale having a truck with a bad transmission. Luckily Toyotas are not known for their transmission or power train problems.... If Toyota wants to remove the trans cooler thats cool with me, if the transmission fails I'll take it in and have them put in a new one at their cost.
  4. Jul 11, 2021 at 6:24 PM
    #334
    Dirtytruck
    2021 SR5
    I understand the trust thing. A few years ago I was having them do the oil changes. 3 different times with two different trucks I came home parked in the driveway only to find fresh oil on the ground later from the “tech” not tightening the drain plug and the skid plate missing screws.
    If I do take it in for anything now I check all their work before I leave the dealership. I’m back to doing my own fluid changes now except ofcourse the trans fluid flush. I checked every connection and fastener before I drove off.
  5. Jul 11, 2021 at 6:36 PM
    #335
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    He edited it.
  6. Jul 11, 2021 at 6:44 PM
    #336
    I know but I like dealing with small numbers............
  7. Jul 11, 2021 at 6:47 PM
    #337
    Dirtytruck
    2021 SR5
    I wonder if Toyota’s reputation for solid transmissions will continue now that they’ve removed the cooler. I’m not being sarcastic, I’m totally serious.
    My cooler install and flush cost less than a new transmission a probably about the same or a little more than a extended drivetrain warranty.
    All that matters really is how one gets their “warm and fuzzies” and with my transmission that’s how I get mine.
    ATV25, GODZILLA and IndianaGeologist like this.
  8. Jul 11, 2021 at 6:56 PM
    #338
    Dirtytruck
    2021 SR5
    I was all set to do the drain and fill then I found a Toyota dealer who would do the flush.
  9. Jul 11, 2021 at 7:06 PM
    #339
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Seems like other automakers are designing transmissions without external coolers. It very well may become a thing of the past. That doesn’t change the fact that the transmission in our trucks was originally designed with one, and I think all of us 2019+ owners who have gone the cooler route very much prefer the temps we see with one installed.
  10. Jul 11, 2021 at 7:15 PM
    #340
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Totally agree that cooler temps. are better, but still waiting for the proof/data that these hotter temps. are destructive to our trans. Time will tell I guess.
  11. Jul 11, 2021 at 7:40 PM
    #341
    Terndrerrr
    Music City
    6UR-FE
    Post 133 is why I installed one: https://www.tundras.com/posts/2158424
    sask3m and Dirtytruck like this.
  12. Jul 11, 2021 at 7:44 PM
    #342
    blanchard7684
    blanchard7684 New Member
    this is my thinking as well.
    Tacoma got their cooler yanked as well.
    Other systems are running without an aux cooler or have an aux cooler with controls to ensure temps stay in tight range albeit elevated.
    my 4Runner doesn’t have an aux cooler but is ice cold.
    Dirtytruck likes this.
  13. Jul 11, 2021 at 7:57 PM
    #343
    TILLY
    Massachusetts
    I remember that post, to be perfectly clear I have no problem with people adding coolers if that's what they want, and the ones available here are top notch quality. I have a 19 as well, so this does effect me to a certain point. I just need more info before dropping money on a problem that hasn't really been proven to be a problem yet.
  14. Jul 11, 2021 at 8:07 PM
    #344
    Dirtytruck
    2021 SR5
    Take a sample of your fluid and look at it and smell it. You’d at least know the basic condition of it. I’d be interested to know what you find.
  15. Jul 11, 2021 at 8:16 PM
    #345
    TILLY
    Massachusetts
    Not trying to be combative here, but the look and smell of your trans fluid without a lab analysis means pretty much nothing nowadays. Did you do an analysis before you decided to add the cooler?
  16. Jul 11, 2021 at 8:31 PM
    #346
    Dirtytruck
    2021 SR5
    Understood. No offense meant or taken.
    Lab analysis is by far the best way to check the fluid characteristics hands down. Having said that, if the fluid is black and smells burnt then you would know that and could make a decision whether or not to do something about it. You could also share what you found with this thread. It wouldn’t cost anything either.
    I was and am genuinely curious.
    Oey12 and TILLY[QUOTED] like this.
  17. Jul 11, 2021 at 8:54 PM
    #347
    TILLY
    Massachusetts
    Not sure what to tell you. There are lots of vids of dark and dirty looking trans fluid coming back from the lab with perfectly great results. Its totally up to you how you deal with what you think is unacceptable, I'm not here to judge. ;)
  18. Jul 12, 2021 at 8:58 AM
    #348
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Wondering if 2022's will have an external cooler and if not will it be possible to add one after the fact. As 19-21 owners we are fortunate enough to be able to do so.
  19. Jul 12, 2021 at 9:10 AM
    #349
    blanchard7684
    a lot of us here are finding this technical detail the most intriguing thing about the new generation.
    my take is it will probably be like the hd trucks: targeting elevated trans pan temps BUT have systems to control it . Aux cooler , thermostat, and with fan with temp set points .
    so you will still see 250 degree temps but there will be multiple layers of control to make sure they stay there.
    sask3m[QUOTED] and Dirtytruck like this.
  20. Jul 12, 2021 at 9:28 AM
    #350
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Me me me!!
    I has teh judgy-ness!
    GODZILLA, Cpl_Punishment and Oey12 like this.
  21. Jul 12, 2021 at 4:24 PM
    #351
    Dirtytruck
    2021 SR5
    That’s a good question and I agree, we are fortunate. REALLY fortunate.
    My prediction is it will not. At least not what we can retrofit today. It’ll take at least 2-3 years or more to work out the bugs anyway. Always happens with the “new and improved.”
    Until a fluid is made that can easily withstand the 220+ temps on a regular basis I won’t run without a cooler.
    Currently, according to a Schaeffer oil expert I spoke to, there is no fluid available that can run nearly continuously at these high temps without
    starting the serious oil breakdown.
    He went on to say if I ever saw 240 degrees fluid temp I should do a flush as soon as possible no matter the fluid I was using.
    Since my truck did not come with a fluid temp gauge or cooler and I towed numerous heavy loads through the mountains, I decided a pre-emptive strike was in order and I put on a cooler and had the trans flushed with AMSOIL.
  22. Jul 17, 2021 at 6:09 AM
    #352
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Some interesting insight in this video of how the towing capacity on a vehicle is determined when they do the Davis Dam test. Kind of makes sense how the newer tundras were able to keep their current tow rating without the trans cooler. This vehicle is specifically about an f-150 overheating but the tundra is mentioned about halfway through
  23. Jul 20, 2021 at 7:50 AM
    #353
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    My plan thus far has been to just not worry about it and if any issues come up, to let the warranty handle it. But I have to say, the TFT numbers are pretty crazy. Yesterday I drove the truck with no load (just me and 3/4 of a tank of gas). Ambient temperature of 79 degrees. I drove for about 20 minutes and hit 210 deg F. No wonder I'm hitting 230 when towing.
  24. Jul 20, 2021 at 8:32 AM
    #354
    Clemsonman14
    chevrolet having similar issues with their 2021 6.2. 7k pounds and they hit 300 on the trans temp. Also some questions in the video about if Chevrolet has also moved away from the trans cooler
    Dirtytruck and jordoncloutier like this.
  25. Jul 20, 2021 at 8:50 AM
    #355
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    My 2020 came with an exterior transmission cooler…it’s called Alaska ;)
    szabo101, Dirtytruck, Bammer and 5 others like this.
  26. Jul 20, 2021 at 11:14 AM
    #356
    blanchard7684
    that’s crazy. Overheated it twice
  27. Jul 20, 2021 at 12:55 PM
    #357
    Dirtytruck
    2021 SR5
  28. Jul 20, 2021 at 1:01 PM
    #358
    Dirtytruck
    2021 SR5
    I used a thermal gun to check pan temp after driving 25 miles no load in 90 ambient.
    I aimed the red dot on the pan drain plug: 178, overflow plug: 188. It ain’t one hundred percent accurate but it’ll do until I get a scangaugeII.
  29. Jul 20, 2021 at 1:03 PM
    #359
    Dirtytruck
    2021 SR5
    Try running with another fluid like AMSOIL. Even without a cooler it might help. My 2020 3/4T Chevy ran 10-15deg cooler with a fluid flush and I’m nearly positive it did not have a cooler. At that time I had it flushed with the Schaeffer fluid.
  30. Jul 20, 2021 at 1:51 PM
    #360
    Kanobi13
    Kanobi13 New Member
    Lol the Tundra on ike gauntlet did not over heat but these trucks did guess we do not need coolers
