Towing/off-roading suspension decision
Discussion in 'Suspension' started by Scutterborn, Mar 25, 2020.
  1. Mar 25, 2020 at 8:26 PM
    Scutterborn
    Scutterborn [OP] New Member
    Ben
    '14 Tundra Platinum
    RC Vertex 7" Camburg 1.5” UCA’s Icon RTX rear leafs on option 2 Firestone bags with daystar cradles 20” Fuel Kranks w/ 5.75 bs. 295 Toyo AT3
    I have a 2014 CM 4x4 with 112k and I spend half of my days on fire roads, the other half on highways. (I’m a surveyor) I also tow my boat once a month or roughly 1500 mi a year. I currently only have a 1.5” spacer leveling “kit”. My problem is this: I need to replace my rear shocks and I’m going to do all 4 corners. I’m leaning towards 6112/5160 over to Fox 2.5. The 5160s, long term, require at least 1” of lift. I’m ok with that. Naturally, this is where I fell down the rabbit hole...
    Now I’m looking at the CB+2 and Firestone air bags with daystar cups. I don’t usually get into anything too crazy when I’m out in the field. I do like to be prepared though. Advice? Suggestions?
    I’m not looking to get crazy with anything. I just want to be more comfortable and safer out there. I run a 50ish gallon fuel tank and a Yeti in the back permanently. My gear weighs less than 50lbs. Let’s say 550lbs permanent weight in the bed.
  2. Mar 25, 2020 at 9:46 PM
    If your running airbags, I would always install the daystar cradles. Simple piece of mind from not tearing the bags.
    6112/5160 combo is pretty nice. I enjoyed the improved feel and dampening.
    Scutterborn[OP] and Luckydog like this.
  3. Mar 25, 2020 at 10:48 PM
    Pairodice
    Pairodice New Member
    Jay
    What does the boat weigh? Any 1/2 ton needs bags if you tow much. They are tuned for soft ride more than towing since they have become more popular. IMO I would do shackles and bags w/ 5160 out back & 6112 up front no shims. I would consider pulling off the sway bar if you spend that much time off road, with heavier springs it will minimize body roll. But it will be considerably better on the rough stuff
  4. Mar 26, 2020 at 4:29 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    The boat weighs no more than 3500lbs or so with the trailer. It will sag the rear by 3” though.
  5. Mar 26, 2020 at 2:03 PM
    Pairodice
    Jay
    It must be very nose heavy, I pulled a smaller bobcat on an 18 ft 10k capacity trailer that weighs 8k total and it sits just about level or 2 inches lower
  6. Mar 26, 2020 at 3:20 PM
    Scutterborn
    Ben
    '14 Tundra Platinum
    I’m spitballing the drop. Could be 2” or so. Either way, I’m not having it.
  7. Mar 26, 2020 at 3:35 PM
    Pairodice
    Jay
  8. Mar 26, 2020 at 7:40 PM
    rustytoys
    rustytoys New Member
    I've heard guys complain about the 5160's harsh ride, but no personal experience; my 5100's in rear ride very nice. The 6112's do sound like a nice easy choice that most guys like - but I would personally try to keep the lift notch around what you have now roughly 2-2.25" max lift - unless you want to go down the rabbit hole of replacing upper control arms.
    Are you happy with 2", or where you trying to get up to 3" front lift or more?
  9. Mar 27, 2020 at 4:22 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    I am perfectly fine with the look of a 2”/0” setup.
  10. Apr 15, 2020 at 11:17 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    I've made a decision.
    Bilstein 6112's on the top circlip up front with 5150's in the rear. Icon RXT leaf springs in the rear on option 2 and the Firestone airbags with the Daystar cradles.
    I decided to replace the springs after dropping the rear tires and seeing my stock springs were flat as a pancake. I chose the middle option on the springs because I'm also installing a 50 gallon fuel cell in the bed along with the gear I run with all the time. I also have the diff drop kit and the carrier bearing drop just to smooth any binding that may occur.
    Everything is in hand except for the Icon RXT springs which should be here today.
  11. Apr 15, 2020 at 4:21 PM
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    Sounds like a great plan! Please post a few pictures when it's all installed.
  12. Apr 15, 2020 at 5:02 PM
    Scutterborn
    Ben
    '14 Tundra Platinum
    Springs came in today... Incomplete!!! The option spring was missing on one set of the leaf springs. Unfortunate. I was hoping to get everything installed this weekend.
  13. Apr 15, 2020 at 8:03 PM
    Quikrete
    Quikrete New Member
    Sorry your having a delay, hopefully the shop you got them through is making it right so you can get those things installed. FWIW, I just added the RXT leafs to my firestone bags and daystar cradles when I installed my new shocks. I'm really enjoying the quality of the ride. It is a noticeable improvement over just the airbags.
  14. Apr 16, 2020 at 10:22 AM
    PhilActual
    PhilActual New Member
    Phil
    2018 Doublecab SR5 5.7 4x4
    SDHQ ABS guards, Hondo Garage/Ram phone/GPS mounts, 275/65r18 duratracs
    Hey I'm a timber cruiser and it sounds like we do a lot of the same kind of driving. Do you have any details on the aux fuel tank you are installing? I researched it and didn't like the idea of the gas nozzle on the back of the tank. I may go with the transfer flow tank replacement. Just kinda spendy$$$
  15. Apr 25, 2020 at 4:06 PM
    Scutterborn
    Ben
    '14 Tundra Platinum
    I had a custom tank welded up for my by a buddy at work. They have a CNC cutter and he made it out of 10g. I’ll attach some pics. I just installed it last weekend. This weekend I’ve been working on my suspension. Pics to come!!!
    PhilActual[QUOTED] likes this.
  16. Apr 25, 2020 at 7:14 PM
    PhilActual
    Phil
    Awesome!
  17. Apr 26, 2020 at 6:59 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    Ok. I’m at a crossroad. I went with option 2 with the Icon RXT Leaf springs and even with my gear, it’s sitting taller than I had hoped. I know it’ll settle but I’m starting on the front and have a question. The Bilstein 6112’s will also settle and I have them at the 2.5. The truck sat level before this and I prefer that look. Short of pulling the leafs and going back to option 1, how do y’all feel about this?
    Taking off the 1.5” spacer and cutting shims out of it? Either 1/2” or 3/4”? I have the Camburg 1.5 UCA’s going in at the same time.
  18. Apr 26, 2020 at 7:00 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    The pic of the front is with the stock equipment and a 1.5” spacer.
    I also have the diff drop kit ready to install and the carrier bearing drop installed.
  19. Apr 26, 2020 at 10:47 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    No spacer, it is. I can always alter down the road.
    anthonygan likes this.
  20. Apr 26, 2020 at 2:08 PM
    Scutterborn
    Ben
    '14 Tundra Platinum
    All done for now.
    Wallygator likes this.
  21. Apr 26, 2020 at 2:14 PM
    Scutterborn
    Ben
    '14 Tundra Platinum
    All said and done, here’s what I went with:
    Bilstein 6112/5160
    Icon RXT leaf springs on option 2
    Camburg 1.5” uniball UCA’s
    Firestone ride rite airbags (for towing)
    Diff drop
    Carrier bearing drop
    OME brake/ABS line relocation kit
    I’ll add more if I think about it.
    CBrider likes this.
  22. Apr 27, 2020 at 6:39 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    Waiting on spec sheets, but my toe was way messed up afterwards. It’s on the rack at Firestone now. Not ideal, I know. I had hoped it wouldn’t be too far out until the springs settled. Oh well, it’s only money, right?
  23. Apr 29, 2020 at 11:04 AM
    Scutterborn
    Ben
    '14 Tundra Platinum
    So now I have rubbing on the mud flaps in reverse. I took measurements and I know I increased in height. WTH? I realize I altered the geometry but, I thought it would've allowed me to go 295's. Currently running 275/60r20 with Nitto RG. 5.75 backspacing on Fuel cranks. Any thoughts? Yes, I'm aware i can remove the mudflaps and likely will, however, I'm curious about the rubbing and where I stand with 295's.
