Towing no sway bars
Discussion in '2.5 Gen Tundras (2014-2021)' started by Samoan Thor, Apr 4, 2021.
  1. Apr 4, 2021 at 8:11 PM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    So has anyone towed with no sway bars? I had both front and rear then sold them because I was set on being a fast off-roader and I was for a while but things change and I plan on buying a travel trailer. Yes I will be way below my tow rating, I believe 9k pounds is the towing capacity but of course I won't tow exactly that, I will be comfortable with 6500 pounds or less, thats just me. I will buy them again if I need to, just asking......
  2. Apr 4, 2021 at 8:15 PM
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I tow a 5x10 trailer with 3-3500 pounds on a single axle quite often with no sway bars. Taller loads can make the body roll back and forth after turns, I am adding rear bags with daystar cups as a sort of extended bump stop while towing. Otherwise I have no complaints
    Samoan Thor[OP] likes this.
  3. Apr 4, 2021 at 8:17 PM
    RobertD
    Robert
    DFW, Texas
    I towed a 3.5k travel trailer before I had my rear bar, no issues. I assume I'll roll less now that I have the rear bar but I never felt unsafe
  4. Apr 5, 2021 at 6:03 AM
    Samoan Thor
    RobertD likes this.
  5. Apr 5, 2021 at 6:05 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    I have no sway bars and have no issues towing ~4,500 bumper pull camper. I have OME suspension with full Dakar rear leaf pack. I’ve had a Dodge dually 3500 4x4 and a 35’ 5th wheel, Dodge 2500 single rear wheel with 32’ bumper pull. It doesn’t feel THAT solid but I have zero complaints.
  6. Apr 5, 2021 at 7:06 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    I have a 6500# TT. Before I put on the rear sway, I most definitely had a lot of body roll, enough that it made me nervous, but that might have been because I was used to towing with my Titan which was a towing beast.
    Adding the rear sway bar most definitely helped a lot with body roll, enough that I’m comfy again.
    YMMV.
  7. Apr 5, 2021 at 7:15 AM
    wsutundra
    wsutundra 2021 Smoked Mesquite 1794
    I tow with a Tacoma (upgrading to tundra next month) a 3000lb single axle and I would never tow with without sway bars. Too much can just go wrong, really fast. Especially if you are in high wind areas. Just my opinion. It’s worth the $500 to buy a good setup.
  8. Apr 5, 2021 at 7:33 AM
    Mixb7
    Mixb7 New Member
    Napa Valley California
    2010 4x4 Tundra Platinum Crew Cab
    Bilsteins all around,110v and 12v in the bed, Rocklights, Dual Batteries, Trailer Brake Controller Mod, Lots of DIY Mods
    I’ve had my 2010 CM for two years and tow a 6000# TT and also my bass boat when I’m fishing. Have never felt unsafe towing either. The truck has really done well with both. I use load distribution bars and an anti sway bar on the hitch towing the TT. Now saying all that after reading about sway bars on here for the last two months I am going to install one after the reviews of reducing bed roll not towing anything. I want to see what I was missing. I hope this helps.
