Towing Mirror Turn Signal Marker Lens
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tony'sToy, Mar 5, 2017.
  1. Mar 5, 2017 at 2:53 AM
    Tony'sToy
    Tony'sToy [OP] New Member
    Tony
    Savannah, MO
    2015 Toyota Tundra SR5 TRD OFF ROAD
    6" Rough Country lift kit 20" BMF Novakane Wheels 35"X12.50R20 Nitto Trail Grappler MT AIRAID Cold Air Intake Flowmaster Outlaw Exhaust System Bushwacker Pocket Style Fender Flares Recon Projector Headlights (Smoked) Recon 35 Watt Hid Headlights Recon 35 Watt Hid Foglights Recon LED Brake Lights (Smoked) Recon LED 3rd Brake Brake Light (Smoked) Recon LED Tailgate Light Bar(Smoked) Recon LED Big Rig Light Bar (Smoked) Recon LED Bulbs Every Bulb Location Rough Country 30" Bumper Mount Single Row Light Bar. Headlight Revolution LED Interior Light Kit Replaced Every Bulb Blue LED Bulbs Toyota TRD PRO Grille (Black) TRD Shift Knob All Windows Tinted 20% WeatherTech In Channel Window Deflectors WeatherTech Floor Liners Extant Encore Tonneau Cover
    Does anyone know how to take out the amber side marker lens on the tow mirrors? I'm wanting to replace them with the smoked lens.
    az1441 likes this.
  2. Mar 5, 2017 at 4:57 AM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    I just mentioned this the other day. Where do you see these?
  3. Mar 5, 2017 at 6:10 AM
    Tony'sToy
    Tony
    Savannah, MO
    These are on eBay. Made by A-1 Auto. They are really nice if I can figure out how to remove the factory amber ones.
  4. Mar 5, 2017 at 9:50 AM
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    I haven't done this personally but I've heard that you need to remove two torques bit screws that mount the lens inside the mirror housing. I don't know how you remove the mirror... maybe they're just popped into place cause I have now clue how they're secured into the mirror housing.
  5. Mar 5, 2017 at 10:03 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    If you tilt the movable mirror inward you'll see a couple of screws to remove.
  6. Mar 5, 2017 at 10:15 AM
    I bought my mirrors off 1a-auto I didn't like lenses too dark so got me OEMs lenses because if u stood front n back of truck u couldn't see led lights when turn signals were on so OEMs don't fit right in the aftermarket mirrors but yeah if you move mirrors certain way there two screws you can get to so you take off lenses but 1A-Auto sells lenses
  7. Jun 19, 2017 at 1:01 PM
    captjv
    captjv New Member
    JOHN
    towing mirror
    you can pop out mirror and remove screws with torx driver, and replace with new lens and pop mirror back in..takes about 2 minutes..Just did it this morning.
  8. Jul 23, 2017 at 7:23 PM
    Scottri
    Scottri New Member
    Scott
    West Linn Oregon
    2017 Quicksand SR5 TRD Off Road
    Adjust the mirrors all the way in with the switch on the dash. You can get to the two screws to the outside of the mirror glass.
  9. Feb 1, 2020 at 1:13 PM
    frieselu
    frieselu 13 years with a 1st gen; recent 2nd gen convert
    2008 Green CrewMax
    This is an old thread but I swapped out a turn signal marker on my 2008 tow mirror this morning so chiming in with my experience if it’s helpful. I tilted the mirror inward but there was no way I was going to be able to reach the torx screws with the tools I had on hand.
    I ended up removing the mirror glass. “Just pop it out” felt a bit vague, but I’m here to tell you it’s true. The tow mirror glass does NOT come out in the same way the regular mirror glass does (which requires to be pried straight up, then out). It literally pulls straight out away from the mirror housing with no other manipulation required. Don’t be afraid to give it a little tug. You might have to move the mirror a bit to get your fingers around an edge or two.
    Changing out the turn signal marker is a piece of cake with the glass out. Remove two screws and the electrical connector, pull it out, and reverse those steps with the new marker.
    Putting the mirror glass in was more challenging than removal. It requires a pretty firm push to seat solidly and I was afraid I was going to crack the glass or something. But I braced my fingers directly where the plastic backing ring was, and was able to apply enough pressure but not so much as to break it. Very pleased overall with how it worked.
    Leo's first likes this.
  10. Feb 1, 2020 at 1:43 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    Can you post some pictures of the OEM mirrors with the new markers installed?
  11. Feb 1, 2020 at 2:38 PM
    frieselu
    2008 Green CrewMax
    I didn’t put in the darker lens, I installed an amber OEM replacement as the original was damaged. So my pictures probably aren’t what you’re looking for.
  12. Feb 1, 2020 at 4:51 PM
    Marshwalker
    Marshwalker New Member
    Z
    Tow mirror are the way to go
    voz likes this.
  13. Feb 1, 2020 at 5:39 PM
    voz
    voz New Member
    2016 Tundra
    I concur, but would like some puddle lights on em.
  14. Apr 28, 2021 at 1:00 PM
    ianmcbride5.7
    ianmcbride5.7 New Member
    Ian
    2014 grey sr5 doublecab 5.7
    Stock
    I just got my smoked lenses in the mail. I was able to unscrew the two screws holding the lens in place without removing the mirror. MY ISSUE IS THE ORIGINAL LENSES HAVE SILICON HOLDING WIRES WHERE A PLUG WOULD BE AND WIRES ARE CONNECTED INSIDE ORIGINAL LENS, so I removed the silicone and the wires go plum inside the signal with no plug. My new mirrors have a three prong plug insert and I can’t just plug them in now. I cut the wires in the originals as close as I could thinking I could surely figure out a way to connect them to the three prong plug on new ones. Can I just solder the wires onto the prongs or should I find a three prong connector that could half ass plug into the lens?
  15. Apr 28, 2021 at 2:31 PM
    biebs96
    PA
    You could always paint the orange ones and reinstall them for a much cheaper price.
    mine are still visible like they used to be, just invisible when off.
    And yes, like others have said if you angle the mirror, you can access the screws.
