Towing Help needed, only 3500lbs
Discussion in 'Towing & Hauling' started by Doug2000, Aug 12, 2022.
  1. Aug 12, 2022 at 10:21 AM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Great question! I have no freaking clue! please school me on how that works exactly and I'll give you my best answer lol
  2. Aug 12, 2022 at 10:44 AM
    Let me get some information for you Alex.
  3. Aug 12, 2022 at 11:07 AM
    You will need to look up the make/model of your LDH. Some are rated for reversing and others are not.
    This one is not:
    https://www.etrailer.com/Weight-Distribution-Hitch/CURT/C17063.html
    These doesn't say, and I would question even trying:
    https://www.etrailer.com/Weight-Distribution-Hitch/CURT/C17057.html
    https://www.etrailer.com/Weight-Distribution-Hitch/Reese/RP67509.html
    https://www.etrailer.com/Weight-Distribution-Hitch/Reese/RP66542.html
    These do allow for backing up and state just that:
    https://www.etrailer.com/Weight-Distribution-Hitch/Reese/RP66074.html
    This one is adjustable from 350-550 lbs tongue weight and is reverse compatible:
    https://www.etrailer.com/Weight-Distribution-Hitch/Blue-Ox/BXW0556.html
    Personally I have owned these two hitches and they were equally great hitches:
    https://www.etrailer.com/Weight-Distribution-Hitch/Equal-i-zer/EQ37120ET.html
    https://www.etrailer.com/Weight-Distribution-Hitch/Fastway/FA92-00-1200.html
    These performed the same way and if I had to buy one today, it would be the Fastway E2 due to pricing.
  4. Aug 12, 2022 at 11:13 AM
    Nightshade Tundra
    Alex
    I see what your saying now, this is the one I have
  5. Aug 12, 2022 at 11:18 AM
    blenton
    blenton New Member
    I didn’t even think about having a reverse rated WDH… But now that I think about it, the one we used when I was a kid would sometimes give us fits when backing up. Now I use an Andersen Weight Distributing Hitch and it is super smooth with zero sway. Smoothest WDH I’ve used and hardly any porpoising if at all. Its also easier to adjust, IMO.
    https://andersenhitches.com/product/weight-distribution-hitch/
  6. Aug 12, 2022 at 11:20 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    This is a true chain WDH and is made by Andersen. It is sway control, WDH and allows for full turning in reverse. I personally have one and I like it on anything except single axle trailers. In my opinion, the design creates more bounce with a single axle.
    ColoradoTJ likes this.
  7. Aug 12, 2022 at 11:20 AM
    mountainpete
    You beat me to it :)
    blenton[QUOTED] likes this.
  8. Aug 12, 2022 at 11:25 AM
  9. Aug 12, 2022 at 11:27 AM
    mountainpete
  10. Aug 12, 2022 at 11:31 AM
    I wouldn't think so? However, any binding might snap off the ball on the frame. Good question though....and one I don't have an answer to. Most of my advice is had from bad experiences. :rofl:
    I should have been a marketing tester for certain items. "I'll test the shit out of it for ya buddy!"
  11. Aug 12, 2022 at 11:40 AM
    Nightshade Tundra
    Alex
    Yup I always take the sway control when backing up, I don't ever take of the bars though and don't feel any binding I will at some point replace the system but I'm not sure what I would get since up to now I haven't had any issues with it and I've driven at the very least 10k miles on them
  12. Aug 12, 2022 at 11:48 AM
    They are rated to back up, so I wouldn't change a thing then. 400+ dollars buys 2-3 tanks of gas in your beast!!
  13. Aug 12, 2022 at 11:52 AM
    Nightshade Tundra
    Alex
    You ain't lying lol
  14. Aug 12, 2022 at 2:17 PM
    Doug2000
    Doug2000 [OP] New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    Yes, I couple the ball and lock it them raise the truck and trailer about 5” so I can easily attach the bars then lower the trailer putting the weight on the hitch.
  15. Aug 12, 2022 at 2:30 PM
    Doug2000
    What is RAS?
  16. Aug 12, 2022 at 3:39 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I didn’t read the whole thread. But I wouldn’t bother with a WDH with a 3-4000 pound trailer.
  17. Aug 12, 2022 at 4:38 PM
  18. Aug 12, 2022 at 6:00 PM
    Doug2000
    Without out the WDH, the truck squats and the ride is horrible.
  19. Aug 12, 2022 at 7:16 PM
    #49
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    Sounds like a trailer without enough tongue weight. My dad’s flatbed does the same thing when empty. Add weight to the front and it rides great.
    He uses a wdh to smooth out the ride. It helps but weight on the front is key.
    blenton likes this.
  20. Aug 12, 2022 at 7:19 PM
    #50
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’d try 35 psi in the trailer tires. I’m assuming they are load range C in either 215/75R14 or 215/75R15, are are rated to carry at least 1750 lbs each at 50 psi max pressure. Which means inflating to 50 psi max would be correct if your trailer axle weight was 7K lbs. You’re just over half of that.
    Is your trailer leaf sprung? Not many tandem RV’s use torsion axles that I’ve seen.
  21. Aug 13, 2022 at 4:08 AM
    #51
    Retired...finally
    @Doug2000 Sorry if I missed this if it's been covered but are your rear shocks on the truck doing their job?
    I can get into an abbreviated situation you type of but only one one particular bridge in Louisiana only because of the spacing of the expansion joints on the road surface. My truck is less than one year old with the friction type Fastway E2 WDH.
    You have done an impressive job setting up your combo. Very impressive.
  22. Aug 13, 2022 at 11:48 PM
    #52
    Doug2000
    The truck is a 2017 with only 41,000km. The suspension is good.
    I'm leaning to increasing the tire pressures to see what happens.
