Towing harness plug - no running lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by oleg8888, Nov 13, 2017.
  1. Nov 13, 2017 at 2:59 PM
    oleg8888
    oleg8888 [OP] New Member
    Oleg
    Tundra LTD 2016
    I was rewiring the lights on my trailer (not the truck's) and must've messed up the wiring. Now there are no running lights. Brakes and blinkers work fine.
    Tested on 4 other trailers - no running lights.
    Fuses checked out fine.
    Any ideas?
  2. Nov 13, 2017 at 3:42 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Do you have running lights on your Tundy still?
  3. Nov 13, 2017 at 4:09 PM
    oleg8888
    Oleg
    Tundra LTD 2016
    Yes, everything is operational on the truck
  4. Nov 13, 2017 at 4:14 PM
    LML 3500HD
    Ground
    oleg8888[OP] likes this.
  5. Nov 13, 2017 at 6:08 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Something sounds strange if the running lights are not working on 4 other trailers. Sounds like maybe the wiring goof on the 1st trailer possibly shorted something out on the truck trailer wiring. If you look at the trailer plug cover (round 7pin) there is a diagram of what connection relates to what function. I would use a multimeter or idiot light and have someone in the truck run all the functions while you watch the tester. Good luck Oleg.
  6. Nov 13, 2017 at 6:57 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    looks like there is a TOW TAIL fuse and a relay
    ColoradoTJ likes this.
  7. Nov 14, 2017 at 7:39 AM
    oleg8888
    Oleg
    Tundra LTD 2016
    Thanks muisejt, will check this out
  8. Feb 17, 2023 at 6:39 PM
    AlaDan00
    AlaDan00 New Member
    Daniel
    2006 Toyota Tundra SR5
    Has anyone had any luck resolving this issue by replacing the wiring harness from the tail lights to the 7-pin connector?
