Tow "recovery" hooks
Discussion in 'Recovery & Gear' started by Chaosx4, Apr 4, 2016.
  1. Apr 4, 2016 at 4:14 AM
    Chaosx4
    Chaosx4 [OP] New Member
    2016 White Tundra SR5 TRD
    Hey guys, I have a quick tech question that I am hoping you can help with. I am planning on powdercoating my front row hooks off my 16 SR5 to match the TRD red from my sway bar and the TRD red stitch in my seats. My question is, what should I torque the bolts to when reinstalling the tow hooks on the front? I couldn't find any info in the manual or online. Thanks for the help in advance!
    Also, if any one knows the paint code for TRD red that would be helpful.
  2. Apr 4, 2016 at 6:37 AM
    Chaosx4
    Thanks
  3. Apr 4, 2016 at 8:50 AM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    +2 for the high temp red. Did the same for my 2016.
  4. Apr 4, 2016 at 9:15 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    My hillbilly torque wrench only has 3 settings. Pretty tight, Damn tight, Damned frackin' tight. I torqued mine to the third setting.
    Seriously, I think 65 is the expected torque.
    f86sabjf likes this.
  5. Apr 4, 2016 at 10:21 AM
    Chaosx4
    Haha, thanks for this. My wrench had a fourth setting; bolt stripping tight. As a wanna be mechanic, I am frequently torquing mine to the fourth setting.
    Lindenwood likes this.
  6. Apr 4, 2016 at 10:47 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Grandpa always said... Tights tight to tight is loose again....
    Vector W8 likes this.
  7. Apr 4, 2016 at 12:38 PM
    olivenb
    olivenb New Member
    Nathaniel
    SUMTER, SC
    2015 Silver Sky Metallic Tundra Limited TRD
    TRD CAI, TRD DUAL EXHAUST, TRD PRO SUSPENSION & TRD SKID PLATE TRD PRO HEADLIGHTS, TRD PRO GRILL PAINT TO MATCH DOOR HANDLES & MIRROR CAPS, 32in LED BAR, HWMS from SDHQoffraod.com, WARN ZEON 12-S Platinum winch
    Torque is 43ft lbs for 14+ tundras. I downloaded the installation instructions for trdsparks.com.
    T-Rex266 likes this.
  8. Apr 4, 2016 at 12:47 PM
    olivenb
    olivenb New Member
    Nathaniel
    SUMTER, SC
  9. Apr 4, 2016 at 5:44 PM
    Chaosx4
