Tow rating...
Discussion in 'Towing & Hauling' started by radartech, Jun 22, 2018.
  1. Jun 22, 2018 at 10:37 AM
    radartech
    radartech [OP] New Member
    Ok— I was reading the owners manual.. it lists 8800 to 9800 for the CM2018 38 gallon tank...
    I haven’t picked mine up yet, but is there really that much difference?
    And why!?
  2. Jun 22, 2018 at 10:52 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    depends on 2wd or 4wd and dbl cab or crewmax
  3. Jun 22, 2018 at 11:05 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    It has to do with the GVWR. (Gross Vehicle Weight Rating). The more cab and drive train accessories take away from that GCWR (Gross Combined Weight Rating). That is why a regular cab 2wd will have a higher payload and tow rating (GAWR) given the same drive train and wheelbase.
  4. Jun 22, 2018 at 12:17 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    check your door sticker for a more accurate number. Manuals are printed for a variety of trucks with varying options.
    Based on what I've read the rear differential available with the tow package makes a big difference in towing capacity. Not sure if that's standard equipment or not on the 2018.
