Tow Mirrors question....
Discussion in 'Towing & Hauling' started by tibadoe, Jul 26, 2014.
  1. Jul 26, 2014 at 3:47 PM
    tibadoe
    tibadoe [OP] New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    Called my salesman and asked about the "Heated tow mirrors with signals". Since he is checking on it I will ask here as well. Is it an option to have them factory installed or just a dealer/self install?
    Definitely want them either way - whether I order a Tundra or find one that fits my criteria on a dealer lot. Thanks
  2. Jul 26, 2014 at 9:35 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Price check them with sparks http://www.trdsparks.com
    They are not hard to install. If the dealer charges to install them and you can use a socket wrench, just do them yourself. They are just plug and play.
  3. Jul 27, 2014 at 3:43 AM
    tibadoe
    Joe
    Gladys
    2014 SR5 DC 4x4
    Was just wondering if they were offered as a factory install item. If not, it would be an easy enough install to do myself. Thanks!
  4. Feb 19, 2016 at 6:05 PM
    Ehunter
    Ehunter New Member
    2015 White Tundra XP
    32" Grill Led Bar Led Back up lights BR5 Front Bumper/ 24" light bar Warn 10,000# winch Tow Mirror OEM Brake Controller Bakflip G2 Bed Cover
    Takes 20 minutes max.. All you need the plastic tool to remove the pins on the screw covers and 10mm long socket..
  5. Feb 19, 2016 at 6:17 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    2014 double cab TRD off road
    /\/\/\/\ this
  6. Feb 19, 2016 at 6:53 PM
    Ehunter
    Ehunter New Member
    Yep
  7. Feb 20, 2016 at 5:27 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I don't think this is a factory installed option. I haven't seen it included in any of the packages.
  8. Feb 20, 2016 at 5:46 AM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    You can get them from the factory but they aren't in a package they are a stand alone option
    MotoTundra likes this.
  9. Feb 20, 2016 at 12:07 PM
    tibadoe
    Joe
    Gladys
    2014 SR5 DC 4x4
    Actually they are a factory installed option. When I ordered mine back in July 2014 I added the tow mirrors for only $50 - well worth it.
  10. Feb 20, 2016 at 12:11 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    When I was buying my truck I asked for the dealer to add tow mirrors. He informed me they could only be installed at the plant and NOT the dealer. I had to special order my truck just to get the toy mirrors. This was last month......
  11. Feb 20, 2016 at 12:14 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    I worked at toyota of warren for 10 years and that is the best way because if they order then at the dealership they are over $400 but they can order and install them
  12. Feb 20, 2016 at 12:49 PM
    Tracker
    Tracker New Member
    Shane
    hmm, that wasnt explained to me
  13. Feb 20, 2016 at 12:55 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    It may be different in other areas but I did it several times for customers over the years, or maybe the people at the dealership dont know they can do that
