Tow Mater
Discussion in '2.5 Gen Builds (2014-2021)' started by Mater, Apr 24, 2020.
  1. Mar 2, 2023 at 6:17 PM
    #181
    Mater
    Mater [OP] New Member
    Nick
    SD
    2016 MGM Platinum
  2. Mar 2, 2023 at 6:31 PM
    #182
    Wallygator
    :thumbsup::D:thumbsup:
    FrenchToasty likes this.
  3. Mar 2, 2023 at 6:32 PM
    #183
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Right up my alley!
    Mater[QUOTED][OP] likes this.
  4. Mar 2, 2023 at 6:38 PM
    #184
    Mater
    Nick
    SD
    2016 MGM Platinum
    This tank is huge! Might have to downsize
  5. Mar 2, 2023 at 6:43 PM
    #185
    SAGE63
    San Diego County
    @dittothat is that your new diesel heater?
  6. Mar 2, 2023 at 6:47 PM
    #186
    Mater
    Nick
    SD
    2016 MGM Platinum
    Yes sir. 5kw. Might be a little overkill for T2S, but I’m hoping to get a RTT similar to yours and doing the camping/skiing things next winter in mammoth/Tahoe. Already got a case to put it in and mount everything up. Some pretty elaborate builds on YouTube for these things.. you can go nuts.
    Someone’s more than welcome to pitch their tent next to mine and can split heat. Might have to deal with my snoring, so you won’t be sleeping. Noise or cold.. pick your poison.
  7. Mar 2, 2023 at 6:56 PM
    #187
    FrenchToasty
    Mo
    Bone stock
    It’s probably the same size as mine, that’s half as tall and twice as wide………
    definitely lots of cool case builds out there. Enjoy the heat!
    Wallygator and SAGE63 like this.
  8. Mar 2, 2023 at 7:20 PM
    #188
    SAGE63
    San Diego County
    Which one did you buy?
  9. Mar 2, 2023 at 7:23 PM
    #189
    Mater
    Nick
    SD
    2016 MGM Platinum
    This guy:
    VEVOR Diesel Heater 12V, 10L Tank, 5KW Diesel Air Heater, Fast Heating, Diesel Heater with LCD Switch & Remote Control for Truck, Boat, Trailer, Campervans and Caravans https://www.amazon.com/dp/B08MVVKJWC
    Going to follow this guys build fairly closely
    https://youtu.be/3umUc14JFr8
  10. Mar 2, 2023 at 7:27 PM
    #190
    SAGE63
    San Diego County
    cool and thanks for the info
    FrenchToasty and Mater[OP] like this.
  11. Mar 8, 2023 at 3:35 PM
    #191
    Mater
    Nick
    SD
    2016 MGM Platinum
    :spy:
  12. Mar 8, 2023 at 3:37 PM
    #192
    FrenchToasty
    Mo
    Bone stock
    That thing is a ball buster! Paid for itself!
  13. Mar 8, 2023 at 3:38 PM
    #193
    Mater
    Nick
    SD
    2016 MGM Platinum
    Dang! Talk about doing damage :eek:
    glad to know it’s stout!
  14. Mar 8, 2023 at 3:38 PM
    #194
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    cheater
  15. Mar 8, 2023 at 3:39 PM
    #195
    FrenchToasty
    Mo
    Bone stock
    Oh did I mess up, what is it Wednesday?
  16. Mar 8, 2023 at 3:42 PM
    #196
    Mater
    Nick
    SD
    2016 MGM Platinum
    Also @FrenchToasty did you design/fabricate your own swingout? if so what should be the tubing specs for the swingout if doing one side for a 35ish tire and 25lb table.. any thoughts
  17. Mar 8, 2023 at 3:43 PM
    #197
    FrenchToasty
    Mo
    Bone stock
    So I was also helping my sister move and forgot to latch the other side, the swing out flew open!!!! Snapped the pin on the lock out, and broke the handle on the gusset, I had another lock out barrel assembly already, so I just swapped it out and back to new!
    Wallygator and Mater[QUOTED][OP] like this.
  18. Mar 8, 2023 at 3:57 PM
    #198
    FrenchToasty
    Mo
    Bone stock
    I did build it myself.
    I’d have to look in the garage but I think I used 2x3 3/16 tube for the main, and then 2x2……… maybe 3/16 tube for the up rights and braces and like 10 gauge for the top rail
    It ends up being a lot of weight on the pivot point; so whatever you weld that bracket to, needs to be strong in multiple directions, i gusseted the shit out of my bumper in that corner inside(should have just boxed the bumper)
    I will say, it’s held up to the boys being on it fully open…….
    If you can, maybe think of doing dual swing outs? I could have made mine shorter, and done duals but I just wanted it to be simple
  19. Mar 8, 2023 at 4:33 PM
    #199
    Mater
    Nick
    SD
    2016 MGM Platinum
    Awesome! Thanks for the specs. That’s what I had in mind.
    Yeah, dual would be ideal but I think I’m going to have to go one at a time to keep the old lady happy. Don’t think I could do a single piece across like yours as I park in some pretty shallow parking spots and need to be able to get in/out of the bed pretty regularly because of the fridge. Have a funny feeling that I might be opening the tonneau with the key to toss my groceries in rather than dropping the tailgate. We will see :cheers:
  20. Mar 8, 2023 at 4:47 PM
    #200
    Mater
    Nick
    SD
    2016 MGM Platinum
    Also, I’m neither a structural engineer nor a fabricator.. so this ought to go well
  21. Mar 8, 2023 at 4:55 PM
    #201
    FrenchToasty
    Mo
    Bone stock
    image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
    Definitely feel free to tag me while your going thru it. I’m neither of those things either, but I made it work.
    Sorry for the cobwebs, but that was some of the gussets it did underneath inside the bumper for more strength.
  22. Mar 8, 2023 at 9:27 PM
    #202
    SAGE63
    San Diego County
    looks like the Holcomb valley outting. fun time!
  23. Mar 14, 2023 at 11:10 AM
    #203
    Mater
    Nick
    SD
    2016 MGM Platinum
    Started packing for the trip. Going to be here before we know it.
    Going to need to attach a line from the case to the lid to prevent it from completely falling over. Any ideas? Thinking a steel fishing leader might be a good option. Should be strong enough and the barrel swivels should prevent it from getting rats nested.
    Was loading up the box with the truck locked. The top flopped over and slammed on the prinsu setting off the alarm. Don’t think I’ve sprinted that fast in a long time; surprised I didn’t pull my hammie.
    Anyway, was able to fit quite a bit in there. Camplux, two winch dampeners, soft shackle, morrflate, and rockpals solar panel (under morrflate).E7A059C6-E1D2-401F-9773-998817E29736.jpg
  24. Apr 3, 2023 at 4:52 PM
    #204
    Mater
    Nick
    SD
    2016 MGM Platinum
    One of the big items on my to-do list was figure out how I was going to get a full size spare to ride along with me. I know bigghertz Jason fit a 35 with the coachbuilder shackles but I don’t have the time to mess around with that, unfortunately. Rear bumper and swingout will be a summertime project so need something in the meantime.
    Wasn’t about to lift a 35” tire onto the roof, so I whipped this together real quick. Have a y-strap coming in from polyperformance. Hopefully will serve its purpose. Since these photos have been taken I’ve added a couple more 2x4 underneath for support. Still need to add on the rear wall/door thing with hinge/latch. Also, it’s going to be a tight squeeze in there with a 35x12.5. Might have to air the spare down a bit.
    most important question is do I paint it black or put some epoxy on it and leave it 2x4 pine
    06FB5B10-61E9-4AE5-B62D-8432A1869A63.jpg C282E5C1-94EC-44AE-8A6E-98097B9EA26A.jpg 11E7159C-37A2-484B-B9CB-2B90EE4DD1B2.jpg 862DC2B1-C21B-40CD-836E-4C7A87711CE4.jpg
  25. Apr 3, 2023 at 8:06 PM
    #205
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I vote black
  26. Apr 3, 2023 at 8:17 PM
    #206
    Mater
    Nick
    SD
    2016 MGM Platinum
    :thumbsup:
    I’ll put it midway down the list and see if I get to it. Come to think of it; parents are coming into town this week and it’s supposed to warm up. Might just throw a paint roller in my dads hand..
  27. Apr 3, 2023 at 8:24 PM
    #207
    RainMan_PNW
    Casey
    Clark County, WA
    I’ve got to do plumbing for a friend and at might finally have nice weather so that means yard work
    Mater[OP] likes this.
  28. Apr 7, 2023 at 2:54 PM
    #208
    Mater
    Nick
    SD
    2016 MGM Platinum
    Definitely not my best work with the fids but it’ll do. Triple cross then bury; no stitch 66AE52B0-3111-499E-8D79-9CBC5F9E12FA.jpg5297BBB3-8971-470E-B857-1A3A60D183F6.jpg
  29. Apr 7, 2023 at 3:19 PM
    #209
    FrenchToasty
    Mo
    Bone stock
    I did a brummel since I had both ends loose
  30. Apr 7, 2023 at 3:55 PM
    #210
    Mater
    Nick
    SD
    2016 MGM Platinum
    :confused:
    you’ll have to teach me that one
    I’m more of a “if you can’t tie a knot; tie alot” kinda guy:notsure:
