Tow Mater
Discussion in '2.5 Gen Builds (2014-2021)' started by Mater, Apr 24, 2020.
  1. Nov 29, 2024 at 12:03 PM
    #331
    Mater
    Mater [OP] New Member
    Nick
    SD
    2016 MGM Platinum
    Latest purchase for the truck arrived but need to make a run to the hardware store to pick up a couple air fittings. The laziness in me is excited to try it out but the instructions say to connect all 4 tires prior to inflation/deflation. 1 tire at a time sounds good to me :thumbsup:
  2. Nov 29, 2024 at 8:35 PM
    #332
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    My laziness has been piqued…
    :popcorn:
    Mater[QUOTED][OP] likes this.
  3. Nov 29, 2024 at 8:47 PM
    #333
    Mater
    Nick
    SD
    2016 MGM Platinum
    Mine too. Picking up fittings tomorrow
    My neighbor caught me at the wrong time today. Morrflate uses some crazy thread paste one their hose kits so was trying get those cleaned up for the new fittings. Came over and said “is that the auto deflate/inflate tool?” “Yup” “oh a guy I went wheeling with last week had one and it took him as long as me to inflate his tires”. “Well he must have a sucky compressor or not know what he’s doing”
    TRDFerguson[QUOTED] likes this.
  4. Nov 29, 2024 at 8:56 PM
    #334
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    This is why I’m glad my neighbors don’t talk to me :rofl:
    I can say that my new setup is pretty much money
  5. Nov 30, 2024 at 1:55 PM
    #335
    Mater
    Nick
    SD
    2016 MGM Platinum
    Can confirm this gets you within 2 psi up or down and can load one tire at a time (first reading check it’ll reset to a more accurate cumulative PSI).. so easily passes my laziness to productivity ratio. Plus I like the idea of not removing valve cores or screwing things off/on valve stems multiple times. Has a nice hanging spot too
  6. Dec 31, 2024 at 2:12 PM
    #336
    Mater
    Nick
    SD
    2016 MGM Platinum
    Added this guy. Still waiting on an additional wire hider to show up so I can get it finalized. Used my Klein angle gauge instrument thing for maybe the 3rd time ever but was nice to be able to get the angle aligned with the rake of the truck and not just guess
    Also tested out this guy. Was out recently and one of our group members was chatting with another group but I couldn’t reach them. FOMO kicked in so I ended up picking this guy up on Black Friday. Compactenna works well for daily use but sometimes you want a little more. Maybe now they’ll be able to hear me..
    2m
    70cm
  7. Mar 5, 2025 at 10:58 PM
    #337
    Mater
    Nick
    SD
    2016 MGM Platinum
    Mater’s trying to clean up the salvage yard a bit. I have about 25 of these 20bin organizers for nuts, bolts, bits and bobs. This rack will hold 20 (10 bins on each side) and will roll under the workbench.
    If anyone would like to do this, here’s how to do it.
    • First buy the rack
    https://www.amazon.com/dp/B003HEYM1O
    • Buy some bins (Stanley bins work as well):
    https://www.harborfreight.com/20-bin-medium-portable-parts-storage-case-93928.html
    • Cut one side of connecting rods so all four are 16 3/4” (double-check this if using Stanley bins)
    • Pick up some 5/16 or 1/4” all thread and run it through (Milwaukee insider if your friend here)
    • Use washers and nylocs to keep everything tight.
    • Happy organizing. Many people remove bins and custom 3d print larger bins to fit in their place.
  8. Mar 23, 2025 at 6:26 PM
    #338
    Mater
    Nick
    SD
    2016 MGM Platinum
    Spent 30mins this afternoon prepping for T2S prep. Hopefully this will make truck and honey-do mods go a little quicker in the coming month..
  9. Apr 4, 2025 at 6:46 PM
    #339
    Mater
    Nick
    SD
    2016 MGM Platinum
    Tight squeeze and it still needs to go up 3/8” to clear the mountain hatch.
    Might just need to run two fridges in Sedona. Instead of the cart girl on the golf course, I’ll be an alcohol ambassador on the trails.
  10. Apr 4, 2025 at 10:07 PM
    #340
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I support this idea
  11. Apr 5, 2025 at 7:50 AM
    #341
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    This sounds like a wonderful plan
  12. Apr 6, 2025 at 5:25 PM
    #342
    Mater
    Nick
    SD
    2016 MGM Platinum
    New spare tire superstrut rack is tighter than the fridge. We’re in the mm’s here.
    Figured these T-bolts would come in handy some day
    Left these intentionally long for potential future upgrades
    Just waiting on the Amazon man for the final piece. Main question is whether to paint it black or leave the zinc
  13. Apr 7, 2025 at 6:47 PM
    #343
    Mater
    Nick
    SD
    2016 MGM Platinum
    Should probably put some outriggers off to the side to prevent the tire bouncing back and forth but this should be adequate for the road in and out of Sedona
    Endcaps/bumpers for the strut should arrive tomorrow along with a few new quick fists to relocate whip storage from inside the bed onto the rack.
  14. Apr 7, 2025 at 6:51 PM
    #344
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve seen tennis balls used as end caps, genius!!!
  15. Apr 7, 2025 at 6:58 PM
    #345
    Mater
    Nick
    SD
    2016 MGM Platinum
    Might be a good idea! And that is genius :thumbsup:I’m afraid of the ones sticking out the back. Can sense a gash in the forehead coming
    Tripleconpanna likes this.
  16. Apr 7, 2025 at 6:58 PM
    #346
    SAGE63
    San Diego County
    It is only skin and blood
  17. Apr 7, 2025 at 7:07 PM
    #347
    Mater
    Nick
    SD
    2016 MGM Platinum
    Don’t need another reason to piss off my wife, Sid. Looking at a scar from drunken stupidity/poor engineering is a sure fire way to do that. Tennis balls it is!
    :playball:
  18. Apr 7, 2025 at 7:18 PM
    #348
    FrenchToasty
    Mo
    Bone stock
    I saw it from a hvac guy who uses a lot of strut, I think he was trolling at one point(which I love) and had like 30 tennis balls all over his install. Cut a X and slide it on
  19. Apr 7, 2025 at 7:30 PM
    #349
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  20. Apr 8, 2025 at 12:33 AM
    #350
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Any connection to Trail Mater on YouTube?
  21. Apr 8, 2025 at 6:07 AM
    #351
    Mater
    Nick
    SD
    2016 MGM Platinum
    Haha I wish! That guy has a sweet rig and does some great recoveries. Would be a dream job for me (I think). Grass might not be greener though
    I follow a few of those guys: trail mater, Casey ladelle, Matt’s Offroad
  22. Apr 8, 2025 at 10:30 AM
    #352
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Yeah....some of my favorite YouTubers.
  23. Apr 12, 2025 at 2:32 PM
    #353
    Mater
    Nick
    SD
    2016 MGM Platinum
    New to me fridge lids were popping open every so often so I upgraded the springs in the latches. Used a pair of end nippers to cut them down to size.. only shot two across the garage :bananadead:
  24. Apr 12, 2025 at 2:37 PM
    #354
    FrenchToasty
    Mo
    Bone stock
    Like Subarus?
  25. Apr 12, 2025 at 2:39 PM
    #355
    Mater
    Nick
    SD
    2016 MGM Platinum
    :rofl:yup. Big, strong, high leverage.. Subarus
  26. Apr 12, 2025 at 6:33 PM
    #356
    TRDFerguson
    Jake
    2018 MGM CrüeMax
