Tow Haul light not working
Discussion in 'Towing & Hauling' started by SundanceKid, May 7, 2020.
  1. Oct 21, 2020 at 9:13 AM
    marckicker46
    marckicker46 New Member
    Marc
    Thank you. What program do you used for wire diagram and location? I would like to have it. AJ4 connection to another module?
  2. Oct 21, 2020 at 9:24 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Over the passage of time I've stumbled on bits and pieces of information like that on the web that I download and save. It's kind of unorganized and spread out over three computers and a couple cloud servers so when I'm looking for something that I think I have, I need to dig around in various places to find it and I don't alway have what I think I have. It's sorta like poking around in a junk filled attic/basement/storage unit.
    The AJ4 connection probably goes into the main harness and then to the main ECU connector (pin 51) for "power" as suggested in @NewImprovedRon's diagram.
  3. Oct 21, 2020 at 9:26 AM
    marckicker46
    Marc
    I appreciate your help..please let me know what you found out when you pop the cover and measure voltage from tow haul switch. I am getting 9.5V. Thanks
  4. Oct 21, 2020 at 9:29 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Edited previous post about AJ4 connector.
    Ya, it's slowly warming up enough to where I think I can get things apart and not crack plastic panels.
  5. Oct 21, 2020 at 9:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  6. Oct 21, 2020 at 9:40 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's what mine is showing as well, must be the same document. :thumbsup:
    NewImprovedRon likes this.
  7. Oct 21, 2020 at 9:47 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think I have one too, it's for 2007-2010 specifically though...
  8. Oct 21, 2020 at 9:54 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  9. Oct 21, 2020 at 11:03 AM
    marckicker46
    Marc
    Thank you everyone for your help. I will let you know what I found out about my haul mode switch
  10. Oct 21, 2020 at 11:29 AM
    marckicker46
    Marc
    Where is this transmission control switch located at J24/J25?
  11. Oct 21, 2020 at 12:07 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What I'm finding is that it's installed inside the shift lever assembly in the center console, assuming you have the floor shifter.
  12. Oct 21, 2020 at 12:16 PM
    marckicker46
    Marc
    Yes I have floor shifter..by looking at wire diagram..look like tow haul mode switch is tie into transmission control switch
  13. Oct 21, 2020 at 3:03 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When I look at the diagram, I see that the T/H switch and the transmission control switch are getting power(+) from the same source and share a ground(-).
    I finally got into mine. Red and Green are illumination. White/Black stripe is ground. Beige is +12, with T/H both on and off. As mentioned, I think that this is a momentary switch and when it's pressed it momentarily grounds the +12V and that tells the ECU to change shift patterns (flips a bit from 0 to 1). When it's pressed again, it tells the ECU to flip it back. In my mind that would explain why it's +12V when in T/H or not (and why the button doesn't stay recessed when on and extended when off).
  14. Oct 21, 2020 at 3:24 PM
    marckicker46
    Marc
    Are you getting 12Volts Beige wire from voltmeter when press off and on T/H switch? I am getting 9Volt
  15. Oct 21, 2020 at 3:27 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes. +12V with T/H on and off.
  16. Oct 21, 2020 at 3:48 PM
    marckicker46
    Marc
    I believe the cause is I am having issues with beige wire only getting 9.5V. Do you know where beige wire goes too?
  17. Oct 21, 2020 at 4:02 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The diagrams indicate that it goes to that connector (AJ4) behind the passenger side kick panel where it changes color to L (lavender?) then on to pin 51 of the main ECU.
  18. Oct 21, 2020 at 4:14 PM
    marckicker46
    Marc
    Can you be able to point out which is connector AJ4? The wire diagram is very hard to point out
  19. Oct 21, 2020 at 4:20 PM
    #49
    marckicker46
    Marc
    I am also confused about this..what is this switch used for ..look like it also tie into AJ4 with tow haul switch
  20. Oct 21, 2020 at 4:29 PM
    #50
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would look at the white connector that is horizontal to those two red wire taps. The bottom left wire is beige and that looks to jive with position 19 on the AJ4 connector. See if you can get you meter probe in there (maybe a sewing pin or straighten out a small gage paperclip) to see if the +V there matches what you're seeing behind the switch.
  21. Oct 21, 2020 at 4:31 PM
    #51
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's just power and ground for that switch.
  22. Oct 21, 2020 at 4:40 PM
    #52
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Here's the text description that I found about it:
  23. Oct 21, 2020 at 4:49 PM
    #53
    marckicker46
    Marc
    Tow Haul switch doesn't go into transmission control switch. It control by ECM correct?
  24. Oct 21, 2020 at 5:05 PM
    #54
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Nope. The transmission control switch is for S-Mode.
    The T/H button just allows the driver to tell the ECU what shift pattern the driver wants the transmission to use. That alternate shift pattern is in the ECU.
    marckicker46[QUOTED] likes this.
  25. Oct 22, 2020 at 7:25 AM
    #55
    marckicker46
    Marc
    Can you do me a favor. Can you please send me a picture of connections under yellow plug passenger kick panel. Picture of wires.
  26. Oct 22, 2020 at 7:36 AM
    #56
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That is awesome.
    I never scrolled down that far on my wiring diagram...:eek2:
    Wynnded[QUOTED] likes this.
  27. Oct 22, 2020 at 7:48 AM
    #57
    marckicker46
    Marc
    Can you do me a favor. Can you please send me a picture of connections under yellow plug passenger kick panel. Picture of wires to compare your and my.
  28. Oct 22, 2020 at 10:09 AM
    #58
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I don't know if that will help, my truck is quite different from yours...
  29. Oct 22, 2020 at 10:29 AM
    #59
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was thinking, I may have a picture on my phone of this area of my truck. I'll see if I can dig it up and see if that gets us anywhere. I'm at work today so I don't think I'll have an opportunity to pull interior panels on my truck to take a photo, but we'll see.
  30. Oct 22, 2020 at 10:44 AM
    #60
    marckicker46
    Marc
    Here is attachment of pictures..I need to know if there supposed to have wires between green & purple. I would like a picture of connections
