Totaled Tundra Fix
Discussion in 'General Tundra Discussion' started by martinjrherrera, Apr 13, 2019.
  1. Apr 13, 2019 at 9:25 AM
    martinjrherrera
    martinjrherrera [OP] New Member
    martin
    2008 Toyota Tundra SR5
    The Insurance company totaled my tundra because a cab mount bracket was busted. Went to Toyota got the $30 part and now going to take off old one and weld a new one on.
    YardBird, 4x4_Angel, Seantron and 5 others like this.
  2. Apr 13, 2019 at 11:06 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Do you know anyone with a frame machine that can check for straightness as well. If the mount cracked it’s possible the frame is tweaked as well. I have seen some vehicles go back together and find out later that the frame was tweaked just enough that they couldn’t get the alignment right.
  3. Apr 13, 2019 at 1:32 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    This.
    That’s enough offset force to be transferred unevenly through the frame in the L direction.
  4. Apr 13, 2019 at 1:48 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Not if @martinjrherrera is secretly building a Tundra trophy truck :D
    Black Wolf and Mountun Goat like this.
  5. Apr 13, 2019 at 1:52 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I bet if the parts bolt on nicely it’s fine.
    Black Wolf likes this.
  6. Apr 13, 2019 at 1:52 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I wrote a civic off by bending the front subframe. Drove it for 6 more years haha
  7. Apr 13, 2019 at 2:58 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    So, how did the crash happen? Looks like what ever it was went over the bumper, mostly.
  8. Apr 13, 2019 at 4:02 PM
    G10dra
    G10dra Not a New Member
    no better time for a front end conversion, you have.
    Said the wise guy Yoda.
    4x4_Angel and ZappBrannigan like this.
  9. Apr 13, 2019 at 5:31 PM
    Tundrius
    Tundrius New Member
    Jonah
    08 tundra, matching 10 prius!
    Get your frame checked before you do anything major. Good luck frame shop can pull you straight in nothing flat.
    ZappBrannigan likes this.
  10. Apr 16, 2019 at 4:18 PM
    G10dra
    So What's happing now OP ?
  11. Apr 16, 2019 at 5:00 PM
    martinjrherrera
    martin
    Ran a new liquid A/C due to collision busting my old one and waiting on new lock for hood since 2nd gen is different and one brack for the support I ordered. Overall it's coming along good just making adjustments
  12. Apr 16, 2019 at 8:38 PM
    G10dra
    Looks good Sir, Love the progress @martinjrherrera is there any pain point's you'd like to point out for those who might be looking to do this conversion.
    list some difficulties or issues to watch out. Any close-up pictures. Are you going full on LED? Also those tires look very worn out :)
  13. Apr 17, 2019 at 6:52 AM
    martinjrherrera
    martin
    Yeah man for sure getting new tires. Pain points are just making sure everything lines up and my build was unique because I had to replace the entire front end. So when I ordered parts I ordered everything for a 3rd gen the front frame assembley was a bitch. We had to drill out the spot welds on old one and then break the welds to remove old frame. this was most difficult part so far. I would think if your 2nd gen front frame is good it will save you alot of time.
    aperezsh and Watt maker like this.
  14. Apr 17, 2019 at 6:54 AM
    martinjrherrera
    martin
    I am going full LED TRD Pro lights and I need to figure out how to connect 2nd gen cables to 3rd gen lights looks like a harness is required with some rewiring? Anyone know how to do it and lives in Houston,TX??
  15. Apr 17, 2019 at 6:28 PM
    martinjrherrera
    martin
    Almost there put in new radiator,a/c condenser/a/c line, water pump, and belt ran for 1hr and drove like new no leaks. Just need the harness for the 2018 TRD PRO Headlights I need to figure out the wiring for the DRL.
  16. Apr 28, 2019 at 2:24 PM
    G10dra
    :popcorn:, What's happening OP. I am waiting to see your build complete.
  17. Apr 28, 2019 at 2:28 PM
    martinjrherrera
    martin
    What's up man! I just got the paint and getting ready to spray the truck.
  18. Apr 28, 2019 at 4:15 PM
    G10dra
    My hats off to you sir for painting it yourself:hattip:. I'd do all other work but wouldn't dare to paint. Good luck.
  19. Apr 29, 2019 at 5:09 PM
    martinjrherrera
    martin
    Got the paint just need to sand prime and paint
  20. Apr 29, 2019 at 5:17 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    Do you have a part number for that AC line or a link? Mines got a hole in it.
    Thanks
  21. Apr 29, 2019 at 5:30 PM
    martinjrherrera
    martin
    I ordered from PIT STOP AUTO Item
    1420140 2017 Toyota Tundra Hoses and Pipes-1420140 it was way cheaper than dealer
    BOBONTUESDAY likes this.
  22. Apr 29, 2019 at 5:44 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Looking good.
  23. May 7, 2019 at 3:23 PM
    martinjrherrera
    martin
    Everything is painted and bolted on. Matching color not bad for a at home project. My dad helped with the painting it came out nice.
  24. May 7, 2019 at 3:37 PM
    Dontra
    Dontra Newer
    Don
    AR
    2021 Ram Big Horn
    2021 Ram Patriot Blue, Lonestar or Bighorn, Crew cab 4x2, 5.7 bed, 5.7 Hemi etorque, Level 2, anti-spin 321 rear end, Air ride, 33 gal tank, 18 in wheels, Multifunction tailgate, Ram box, Wheel liners, MT Brown Deluxe bucket seats, 8.4 no navigation, Trailer brake controller. Front and rear rubber mats. Mopar power steps,8 yr 85K extended Mopar warranty.
    Looks real good
    martinjrherrera[OP] likes this.
  25. May 7, 2019 at 4:04 PM
    Aerindel
    Aerindel New Member
    Montana
    I don't own a vehicle that hasn't been totaled. Good for you.
  26. May 7, 2019 at 4:41 PM
    TheBeast The Beach
    nice job OP !
  27. May 7, 2019 at 4:44 PM
    G10dra
    :yes: Nicely done.
  28. May 7, 2019 at 5:39 PM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    Wow nice work!!:broccoli:
  29. Nov 14, 2019 at 5:33 PM
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    nice work @martinjrherrera Do you have the P/N to the hood latch used? After googling, I find several P/N's.
  30. Nov 14, 2019 at 5:44 PM
    martinjrherrera
    martin
    53510-0C060 hood latch @68vert
    68vert likes this.
