TOTAL CHAOS | Feedback, Pics, Product Info, *ANYTHING TC RELATED*
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Dec 14, 2019.
  1. Apr 24, 2024 at 8:27 AM
    #61
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    The Rebelle Rally covers 2,500 kilometers of stunning terrain across the Nevada and California desert.
    Blending the love of driving with the ultimate challenge of precise navigation, the Rebelle tests your skills over 8 days of competition. It is not a race for speed, but a unique and demanding event based on the elements of headings, hidden checkpoints, time, and distance using maps, compass, and roadbook.
    NO GPS. NO CELL PHONES. EVER.
    The Rebelle Rally is designed with intention. Every last detail. It is a platform for women to shine. At its core, it's a world-class competition. Peel back the layers, and it is a world-class brand.
    IT IS TOUGH, RAW, AUTHENTIC, and all dressed up in one amazing package attracting adventurous, smart, empowered women from across the globe. Designed by the best in in action sports, rally, automotive, & the adventure world, it delivers a unique & life-impacting challenge. The REBELLE is fast becoming a MOVEMENT built on community values seeded in action not simply words. Because talk is cheap.
    LIFE CHANGING. AUTHENTIC TO THE CORE. FAIR. WORLD CLASS.
    https://www.rebellerally.com
  2. Apr 25, 2024 at 6:35 AM
    #62
    TOTAL CHAOS
    Corona, CA
  3. Apr 25, 2024 at 7:26 AM
    #63
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Was looking at your UCA, and saw that it won’t work with the trd lift kit. Why is that?
    I’ve gutted a lot of the trd kit. Went fox front and rear, plus removed the sway bar drop and replaced with Icon’s sway bar drop kit.
    Looking to replace the trd UCA so I can lock in easier alignment.
  4. Apr 26, 2024 at 3:43 PM
    #64
    TOTAL CHAOS
    Corona, CA
    I'll provide some detailed info once I'm back in the office!
    Thanks for posting up and Thank You for your patience. We will be back in on Monday
    -Team TC
    info@chaosfab.com
    951.737.9682
  5. Apr 30, 2024 at 10:19 AM
    #65
    TOTAL CHAOS
    Corona, CA
    Sorry about the wait!
    The TRD UCA is an extended width on some kits. The ext. width isn't compatible for our systems.
    Do you have a part # for the unit or kit you have? I want to make sure you don't have the extended with TRD kit
  6. May 6, 2024 at 9:03 AM
    #66
    TOTAL CHAOS
    Corona, CA
    Brands that go together like peanut butter & jelly - TC and @Baja Designs !!
    Add a slice of @foxshox and serve it on a Gen 2 Tundra or Gen 2.5
    Long Travel or Mid Travel? Which one would you order?
    440968215_971851644501541_52641657832457_abae65f9518ed0ce3155b60b0d770a998d8dee36.jpg
    441371008_971850677834971_45139878447084_952a106c55725305efa7889caf5c08a484b69f0a.jpg
    440872096_971850664501639_12558837005562_ef9a92de31e623fe7d4acd8bf72e6c72197f325b.jpg
    440948173_971851637834875_64082001575248_3fdbf09ff484bba61157b46aa65471e5653416e5.jpg
    441410616_971850584501647_26525600050846_f2ab9c14c9019c5220329296d9fb90f21ce14b76.jpg
    440899220_971850567834982_66679215834437_cc9e1a61394f9aecec922baf0869360f156eeca2.jpg
    440872156_971850744501631_33526109566297_85e7b1a81d789fe05dfce4222653cf975eb72122.jpg
  7. May 6, 2024 at 10:00 AM
    #67
    6rian
    6rian New Member
    Long travel kits being developed for the 3rd gens?
  8. May 6, 2024 at 2:56 PM
    #68
    TOTAL CHAOS
    Corona, CA
    It's in the works by our R+D Department :thumbsup:
    If you'd like to be included in the contact/update list, shoot an email to info@chaosfab.com
  9. May 7, 2024 at 3:31 PM
    #69
    TOTAL CHAOS
    Corona, CA
    PERFORMANCE TOYOTA AND LEXUS REAR LINK KIT – WHY UPGRADE?
    TOTAL CHAOS is regarded as the industry leader in aftermarket performance Upper Control Arms and Toyota long travel independent front suspension systems. When you upgrade your front suspension, it is necessary to upgrade the rear suspension to balance the vehicle. We manufacture high quality performance Toyota and Lexus rear link kits for a variety of off road SUV’s as well as the newly designed rear linked pickup trucks.
    2022+ 3rd Gen Tundra with TC 5-link kit (PN: 88450), KING 3.0 IBP rear shocks, and KING sway bar link.
    Rear link kits are often referred to as upper and lower rear control arms. They are used to locate the rear axle and to prevent the housing from rotating causing axle wrap – a common traction issue with rear leaf spring systems. Rear links work in conjunction with a variety of rear coil springs that will set the rear ride height and hold the appropriate vehicle weight – and the shock absorbers provide dampening control keeping the tires firmly planted over uneven terrain.
    TOTAL CHAOS REAR SUSPENSION PACKAGE UPGRADES
    Wheel travel is a function of how far your vehicle’s suspension can compress and extend. More wheel travel generally equates to increased ability to absorb bumps off-road without losing control or causing damage to your vehicle. Some versions of TOTAL CHAOS rear link kits provide an additional inch of down travel when paired with the appropriate custom length aftermarket shock. TOTAL CHAOS stocks KING shocks to build your rear suspension package. An aftermarket coil spring is usually added to your vehicle when you purchase shocks. We supply longer coil springs so they accommodate the added droop travel. We also offer different spring rates and list options to customize your ride for your specific application.
    OEM 5th Gen 4Runner links on the left vs. TC links on the right (PN: 86400). TC link wall thickness varies on other models but is always thicker than stock.
    TOTAL CHAOS REAR LINKS ARE STRONGER THAN STOCK
    TOTAL CHAOS upper and lower links are constructed from chromoly tubing that is twice as thick and more than twice as strong as stock. They are fitted with PTFE-lined chromoly adjustable rod ends and high misalignment spacers that bolt-on and pivot at the frame. We use greasable urethane bushings at the rear axle end to help absorb road vibration since most vehicles are driven 80% on-road. Factory hardware is reused on all TC kits for a true bolt-on installation.
    REBUILDABLE REAR LINK KITS
    Factory rubber bushings will wear out over time with excessive off road use or high mileage vehicles. They are a soft rubber compound designed to twist and flex. Over time the rubber becomes dry rotted allowing the rear suspension to incur more flex and body roll. Toyota and Lexus factory rear link control arms are not rebuildable. TOTAL CHAOS Toyota and Lexus rear link kits are completely rebuildable and designed to last the life of your vehicle.
    REAR LINK SKID PLATE ACCESSORY
    TOTAL CHAOS offers a lower rear link skid plate upgrade to protect the factory lower link pivot mounts from rock damage on the trail. These brackets fit: 2003-2009 4Runner | 2010-2023 4Runner | 2003-2017 FJ Cruiser | 2003-2009 GX 470 | 2010-2024 GX 460
    Lower Link Skidplates are a great complement to TOTAL CHAOS Links.
    AMERICAN MADE
    Like all TOTAL CHAOS suspension products, our rear link systems are manufactured in house at our facility in Corona, California. When you call, the person on the other end of the phone is an off-road enthusiast with decades of hands on knowledge and experience. We strive to help ensure that you get the best possible customer service in the industry.
    TOYOTA AND LEXUS REAR LINK KIT APPLICATIONS:
    1996-2002 3rd Gen Toyota 4Runner
    2003-2009 4th Gen Toyota 4Runner
    2010-2022 5th Gen Toyota 4Runner
    2007-2009 Toyota FJ Cruiser
    2010-2017 Toyota FJ Cruiser
    2008-2021 200 Series Toyota Land Cruiser
    2022-Current Toyota Tundra
    2023-Current Toyota Sequoia
    2003-2009 Lexus GX470
    2010-2021 Lexus GX460
    2008-2021 Lexus LX570
    2022-Current Lexus LX600
    1996-2002 Toyota Prado 90
    2003-2009 Toyota Prado 120
    2010-2022 Toyota Prado 150
  10. May 7, 2024 at 4:18 PM
    #70
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Is this Rebel Rally similar or same as one you gals did about 6-7 years ago? I ran into you while working at buttercup, you were set up under the big trees west of midway campground. I thought it was a really cool trip you gals were doing, no gps, phones, etc. just land nav. TC gal was in a nice Tacoma.
    If you’re a gal and like to wheel, I highly recommend jumping in with this. These girls were having a blast.
  11. May 7, 2024 at 5:24 PM
    #71
    TOTAL CHAOS
    Corona, CA
    Certainly similar! Especially regarding no gps, phones, etc.
    The start points and destinations do change.
    Not sure who you met, probably Nicole or Rori, or both. We try to support the rally as much as we can!
  12. May 7, 2024 at 5:36 PM
    #72
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Here's a shot I took a few years ago of Nicole (TC) and Emily Miller (Rebelle)
    TOTAL CHAOS[OP] likes this.
  13. May 8, 2024 at 11:36 AM
    #73
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I met the gal on the left, Nicole I guess. She was pretty cool. If I remember correctly she had a grey Tacoma. I thought what they were doing was a pretty cool thing.
  14. May 8, 2024 at 1:36 PM
    #74
    TOTAL CHAOS
    Corona, CA
    Sweet! That's Nicole, Director of Operations | Marketing
    She's in this video here:
    https://www.youtube.com/watch?v=AeeLnFiqHeA
    Bprose[QUOTED] likes this.
  15. May 10, 2024 at 7:44 PM
    #75
    TOTAL CHAOS
    Corona, CA
  16. May 10, 2024 at 7:53 PM
    #76
    Bailey
    CO
  17. May 13, 2024 at 9:23 AM
    #77
    TOTAL CHAOS
    Corona, CA
    Post up if you have any questions!
    HOURS: M-TH 7AM TO 5:30PM PST
    CLOSED: FRI, SAT & SUN
    But I'm here on the forums on our days off!
  18. May 16, 2024 at 8:15 AM
    #78
    TOTAL CHAOS
    Corona, CA
    We will be closed May 16th through May 19th
    for Overland Expo West in Flagstaff, AZ.
    Stop by and see us in Booth # P11
    https://www.overlandexpo.com/
  19. May 18, 2024 at 10:28 AM
    #79
    TOTAL CHAOS
    Corona, CA
    Here's a few TC equipped rigs at the event!
    More pics to come!!!
    info@chaosfab.com
    951.737.9682
    rdiddy5 likes this.
  20. May 18, 2024 at 8:05 PM
    #80
    TOTAL CHAOS
    Corona, CA
    Tomorrow is the last day!
    Thanks to everyone that has visited us
    SUN 9-3
    Booth # P11
  21. May 21, 2024 at 12:17 PM
    #81
    TOTAL CHAOS
    Corona, CA
  22. May 28, 2024 at 5:57 PM
    #82
    TOTAL CHAOS
    Corona, CA
    - Team TC
    info@chaosfab.com
    951.737.9682
  23. Jun 4, 2024 at 10:47 AM
    #83
    TOTAL CHAOS
    Corona, CA
    Looking for a turn-key customized ballistic overland rig that is ?
    Reach out to the crew tavllc in New Mexico!
    1f4f8_afcb88c4ebfe63817a7117d7c5d0d19acd165668.png: TAV, binkdesigns & multicamadv
    https://www.tavllc.com/
    447776572_992029835817055_48800327741398_a69b354c7521fabe87a78d2cb4f6561c8a9f7f06.jpg
    447692788_992029929150379_85190894620637_2ec0f11a10731c7b18331412a1e572cfc336ab2c.jpg
    447627663_992029865817052_18049514931166_5067382dd91051ae04319d7459ecfce094eae4f5.jpg
    447777323_992029912483714_12777444494868_1ed86514e53299ed34734212641e95c3aec8b113.jpg
    447638441_992029859150386_16155823811155_b38f39d50e0abbbd9e49377314628c09b7d5976d.jpg
    447689348_992029935817045_88908130191052_5459627e64b0ea69d3daa0074e6f84563bc8ae26.jpg
    447775753_992029842483721_12653233980143_6d22afbf0d70857454080ef44ac93077a8b14942.jpg
    sandboxjoe likes this.
  24. Nov 26, 2024 at 2:38 PM
    #84
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    Hi, Are you going to be having any Black Friday sales this year? Thanks!
  25. Dec 11, 2024 at 8:44 AM
    #85
    dom98se
    dom98se New Member
    2023 TRD OR
    Need long travel for 3rd gen!
  26. Dec 11, 2024 at 9:09 AM
    #86
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Curious if you guys (really gals) at total chaos have heard of this event. Saw it on a flight ant thought of you.
    https://rallyjameel.com/
    I
    met a bunch of ladies at buttercup several years ago doing a land nav trip. It was my introduction to the Total Chaos brand and thought they would do awesome at this.
    Documentary of it from an American viewpoint would be worth watching too.
  27. Jun 16, 2025 at 5:15 PM
    #87
    TOTAL CHAOS
    Corona, CA
  28. Jun 19, 2025 at 11:59 AM
    #88
    TOTAL CHAOS
    Corona, CA
  29. Jul 29, 2025 at 10:22 AM
    #89
    TOTAL CHAOS
    Corona, CA
    We're no strangers to innovation and originality. It's no secret that the Toyota lower ball joint design on the 1st Gen Tacoma, 3rd Gen 4Runner, and 1st Gen Tundra is known to be a weak link. When ball joint failure occurs, the lower control arm will separate from the spindle and fall to the ground causing serious damage. To fix this problem we designed the first bolt-on billet machined 1″ lower uniball conversion.
    TOTAL CHAOS is full of employees who are enthusiasts. We invest in our vehicles and gain hands on knowledge to give us the ability to make components that are built to to withstand years of abuse and CHAOS. In 2018 Mike spent countless hours creating a hand-made prototype of the lower uniball conversion. He then went out and logged 5,000 miles on the part to ensure the concept was legit, and ready for the machining phase.
    2 years and 4 months in the making from prototype to first units out the door! Made in the USA and designed to last a lifetime with periodic maintenance. Mike is always ready to go full-send and the proof is all in the photos below!
    Two kits are available to work with either OEM Toyota tie-rods or the TOTAL CHAOS heim steering upgrade. Built-in locating pins and a registering center ring lock into the spindle and lessen the shear load on the mounting hardware. With a durable Cerakote™ finish and all hardware included this is a perfect upgrade to your stock lower control arms or your TC long travel kit. Click your application below for more information on our lower uniball conversion!
  30. Aug 7, 2025 at 5:02 PM
    #90
    TOTAL CHAOS
    Corona, CA
    HUSH THE SQUEAKS!!!
    All New Bushings and Waterproof Grease
    WE HEARD YOU!
    We finally have the perfect combination of grease and a brand new urethane bushing compound that we spent 8 months developing and testing on our personal fleet of TC equipped Toyota’s. Our new bushing supplier offers state of the art CNC molding equipment that provided a smooth and precise pivot surface. Their heating and curing processes make this bushing compound the highest quality that we can offer our customers.
    Hush Butter our icky-sticky grease solution, partnered with our brand new custom bushing compound is the game changer in the squeaks and noise that used to be associated with TC urethane bushings!
    This new bushing rolled out and has been supplied in all of our TOTAL CHAOS suspension systems purchased after March 15, 2025.
    At TOTAL CHAOS continuous improvement is the name of our game. We are constantly trying to advance our products in order to remain the leader in performance bold-on suspension systems.
    UCA PREP KIT
    Prep your suspension systems the way the crew at TOTAL CHAOS does it! This complete package is designed to provide you all the necessary parts and tools needed to fully prep a set of TC UCA’s.
    LEARN MORE
    HUSH BUTTER SYNTHETIC BUSHING GREASE w/PTFE 14oz
    Minimize Bushing Noise. Maximize Suspension Performance.
    LEARN MORE
    NEW vs OLD
    LEARN MORE
    See you in the Dirt!!
    redrdr67 likes this.
