Torque wrench
Discussion in '2.5 Gen Tundras (2014-2021)' started by Part_time, Aug 11, 2019.
  1. Aug 11, 2019 at 8:49 AM
    Part_time
    Part_time [OP] Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Truck is out of warranty. Doing my own maintenance, probably should get a torque wrench. Does anyone know the most torque I will have to reach and the lowest so I buy the right one. Also if you suggest a particular model.
    Thanks
    Rica25 likes this.
  2. Aug 11, 2019 at 9:15 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I'd get one that goes 250 ft lbs for when you get into serious stuff. Typically that's 1/2" drive but it's nice to have a smaller 3/8"drive and for that you don't need much, 100 ftlbs or so.
    As for brand... I have a matco and snap on but I scored them as great deals on ebay... If I were buying new, SK or gearwrench are great for home use...
    Gearwrench torque wrenches look EXACTLY the same as my matco... Probably made in the same factory with a different sticker
    15whtrd likes this.
  3. Aug 11, 2019 at 9:48 AM
    mscribellito
    mscribellito New Member
    Michael
    2006 White Regular Cab Tundra
    This is worth looking at. I have a lot of quality tools and used to frown at anything from HF. But they have a handful of really good items.
    Not related, but I bought this a few months ago and it saved me a trip to the stealership for an ABS issue. https://www.youtube.com/watch?v=ck_O5U1Tyz8
  4. Aug 11, 2019 at 10:18 AM
    Mike Tread lightly.
    south carolina
    I have all snap on used bought them off eBay cheap.. turn out have them send out for calibration. Good for 3 years for me..
    I'm waiting on Milwaukee new torque wrench and I will be ordering that to add to my tool box..
    snarkscarbine likes this.
  5. Aug 11, 2019 at 10:31 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Depending on what you do, you actually may need a few. Having a high foot-pound in 1/2" will get the big, heavy work done. Having a low-to-mid range 3/8" and mid-to-high as well will get most of the moderate routine maintenance work done. Having a couple of inch-pound wrenches, one high and one low, with the lowest one being a 1/4" drive will pick up the rest.
    I have 6-8 of these at this point from HD, Lowe's, AutoZone, HF and Amazon. I haven't calibrated any of them, but I use and store them per the instructions and have never stripped a bolt, had one back out, nor torqued something down to an improper spec so that it caused a leak.
    Here's a good recent video on testing a number of them, including ones that you might not have considered. The torque wrench info starts at 19:58 if you want to skip the tech info.
    15whtrd and JohnLakeman like this.
  6. Aug 11, 2019 at 10:49 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    I went with this after reading many good reviews:
    kevine0001, EDDO and BTBAKER like this.
  7. Aug 11, 2019 at 10:51 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    For the coilovers get one with a pivot head.
    TRD15559 and Sas like this.
  8. Aug 11, 2019 at 11:33 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Smart move. Especially after tire rotations.
    Rica25 likes this.
  9. Aug 11, 2019 at 11:35 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Second this.^^^. Excellent torque wrench for the money. I have some high end wrenches at work and this guy works every bit as good.
  10. Aug 11, 2019 at 12:47 PM
    Sas
    OKC, OK
    I was really surprised at the results. Good on HF!
  11. Aug 11, 2019 at 5:54 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    My Harbor Freight torque wrench was garbage actually. I like a lot of stuff from there, but the torque wrench was a waste.
    Been very pleased with this one from Tacklife. Best wishes.
    TACKLIFE 3/8" Drive Click Torque Wrench Set,With 1/2" & 1/4" Adapters And An Extension Bar
    (10-80 ft.- lb./13.6-108.5 Nm) - HTW1A
    https://www.amazon.com/dp/B07FDX517M/ref=cm_sw_r_cp_apap_poFrhzbzqsu28
  12. Aug 11, 2019 at 7:25 PM
    mscribellito
    Michael
    Did you have the cheap torque wrench or the ICON one?
  13. Aug 12, 2019 at 6:11 AM
    Bigbird57
    Bigbird57 New Member
    I would echo having two. One 3/8 and one 1/2 drive. I would recommend 300 ft/lbs for the 1/2 drive. 250 would be a minimum spec.
    I would not be afraid of the Harbor Fright wrenches. Find a 25% off coupon!
  14. Aug 12, 2019 at 7:33 AM
    Part_time
    Oregon
    What takes the most torque probably the tires how many lbs. on that correct me if I am wrong. And thanks for all the replies. Need to buy one as of now I usually just use my good judgment when reefing on a bolt not too much but not too little.
  15. Aug 12, 2019 at 12:53 PM
    kevine0001
    kevine0001 New Member
    Kevin
    Another bump for the Tekton. I have the 1/2" drive, up to 200 ft lbs. Used on my 2000 Land Cruiser and now my Tundra. I use it for all my vehicles, and thus far, haven't needed it for anything beyond it's 200 lbs. Actually, can't remember even getting close to that. I also got a torque screw driver from Home Depot (Husky I think) for lbs per inch. Came in handy when torqueing down the screws on my hunting rifle scope. Probably should have a 3/8 for 0-50 ft lbs, but the 1/2" covers just about all the auto stuff I've done so far.
    https://www.amazon.com/TEKTON-24320.../2+inch+drive&qid=1565639422&s=gateway&sr=8-4
    AxelsHumanDad likes this.
  16. Aug 12, 2019 at 6:01 PM
    Haggis777
    SW Michigan
    Great question. May have the wasted one in the barn still.....
  17. Aug 12, 2019 at 6:19 PM
    Bigbird57
    100 ft/lbs for factory aluminum wheels
    140 ft/lbs for factory steel wheels
    The C/V axle nut would need the most torque.
  18. Sep 13, 2019 at 8:18 PM
    Part_time
    Oregon
    I am ordering the Tekton, thanks for all the info.
    AxelsHumanDad and Rica25 like this.
  19. Sep 15, 2019 at 3:18 PM
    Part_time
    Oregon
