Torque wrench preferences?
Discussion in 'General Tundra Discussion' started by cornwall325, Jul 27, 2020.
  1. Jul 28, 2020 at 10:25 AM
    Brlowe
    Brlowe Tundra Owner
    Idaho
    2020 Cavalry Blue Tundra Limited 4x4
    I would think for basic stuff you could get away with most wrenches and not have to spend lots of money.
    Just remember to always set it back to zero before putting it away. This should be done with all torque wrenches.
    TechWrench, Haggis777 and omgboost like this.
  2. Jul 28, 2020 at 5:32 PM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Okay, I'm going to throw this out there.
    A fish scale and a wrench. Using simple math. Length times force = torque.
    cost about $15 bucks total including wrench.
    Why is everybody making this so complicated for somebody looking to do simple oil changes.
    and for what its worth torquing the oil filter housing to book spec will net you 1 of two things. 1) a hell of a time getting it off or 2) a broken plastic oil filter housing that you have to figure out how to get it off). Strongly suggest you tighten that by hand and then with a wrench using feel. It bottoms out so you aren't really torquing the housing like you think. You're just deforming the threads of the plastic.
    Also, don't rule out doing suspension rebuilding/motor swaps, once you start to tool up you might find yourself tackling all sorts of stuff you weren't expecting
    Hope this helps.
    TechWrench likes this.
  3. Jul 28, 2020 at 6:02 PM
    cornwall325
    cornwall325 [OP] Work in Progress
    2018 Tundra TRD Offroad Limited Crewmax
    I’m not disagreeing about the going by “feel” method. I have always used the going by feel method with spin-on oil filters. I just figured that since the housing is plastic that this was the safest practice. So you’re saying the 18 ft lbs of torque is too much and overkill? Also, who here is torquing and who isn’t torquing the housing? Again, forgive me but this is my first vehicle that I’ve had with this type of oil filter setup.
    Black Wolf likes this.
  4. Jul 28, 2020 at 6:14 PM
    You don't have to with Stahlwille's. Purely mechanical. No springs or tilt blocks. 10 years is way, way too long without having your T wrenches checked. Everyone's needs are different. Torquing on anything plastic is always iffy. Switch to metal..problem solved.
  5. Jul 28, 2020 at 6:32 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Buy the aluminum filter housing.
  6. Jul 28, 2020 at 6:42 PM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    I broke my wives plastic housing (Toyota venza) after receiving it torqued to spec from the dealership. Granted i'm on my back under the car at an awkward angle attempting to get good purchase on the housing.
    Take my advice for what its worth (not much as i'm sitting at keyboard and you don't know anything about me). But in my experience the 18 ft-lbs of torque was overkill for the plastic housing on the oil filter.
    But, i also don't remove the drain plug before i replace the oil I just unscrew the housing (as i found it made a mess either way).
    Lots of smarter/more experienced guys on this forum then me.
    The worst part of the job is getting that stupid splash shield outta the way to get to the oil filter itself, makes buying an aftermarket skid plate tempting as it comes with a door (or fabricating a door for the splash guard.
    And the book spec should be the required pre-load on the housing threads in relation to the oil filter housing to ensure adequate loading. Without knowing the material properties of the Nylon/plastic housing and the receiving threaded housing material (I'm assuming aluminum) and knowing the grease (oil typically fails at a lubricant for threads but is typically what we use because its available) I have no way to determining what the correct torque should be.
    https://www.assemblymag.com/articles/94040-how-to-determine-a-torque-specification (Granted this for bolts and clamping loads not necesary screw type joints)
    The Stahwille's stuff looks great. But $550 bucks for a torque wrench is just plain out of my budget as a home mechanic.
    I replaced mine with aluminum. Not really sure anybody has reported breaking an plastic oil filter housing while driving. But its a cheap enough feel good mod so why not. (and i happened to have it on hand when my wife's venza plastic one was destroyed so that worked out in my favor).
    If you're still reading and you are a first timer at removing that plastic filter assembly you'll need a special tool. Walmart makes a stamped aluminum one (that won't help much at 18 ft-lbs) and a few other places stronger style sockets/tools to get the filter off. Also a company makes a good assembly to drain the housing if you wanted to spend some money and not make a mess. Further a 10 quart bucket is required. make sure you're ready for that much oil.
    lastly, you can buy a valve that you just cycle to drain the oil from the pan. It works well, no mess, but it does take a long time to drain 9 quarts from an essentially 1/8" hole.
    Hopefully this helps.
  7. Jul 28, 2020 at 6:52 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    True, mostly. I wouldn't buy a new Chinese made Snap On. Not sure America is very quality oriented these days either. But the older American made wrenches can be found on flea bay and the prudent shopper can find a good deal.
    TG705 and Bravohook[QUOTED] like this.
  8. Jul 28, 2020 at 7:00 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Still have one of the best , the old style with the long needle in 1/2 inch , built alot of racing motors with it. Works great, but just to hear the clicking noise , I have 3/8 and1/2 inch from Farm and Fleet stores , and also a 1/2 inch harbor freight , and a really nice 1/2 inch Dewalt my son bought me a few years ago. But yes strongly agree ,always return to below -0- when done. Also never have had one calibrated , except at work , and that was just because of ISO and mainly the way people took "no" care of them. For all of us no cal. needed if taken care of, and used properly.
  9. Jul 28, 2020 at 7:04 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I agree, when my Grandpa passed away he left me a rolling cabinet 48x48 with all American made snapon stuff. When I had a ratchet crap out on my the local tool truck stopped by but replaced with a Chinese made one, it has been returned and replaced 6 times by the same guy. He ended up giving my a pre paid card for $100 to get something else. I regularly stop by estate sales and such to see what I can find, but I have had good luck with HF, but I'm bot a professional, if I was I'd go with Cornwell or Mac
    Black Wolf and 831Tun[QUOTED] like this.
  10. Jul 28, 2020 at 7:21 PM
    cornwall325
    I went ahead and ordered the OEM aluminum housing for peace of mind. I’ll swap the plastic one out when it gets here. Going to do the hand tight method and maybe snug just a touch without a torque wrench like I always have in the past for spin-on filters.
  11. Aug 23, 2020 at 3:57 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I have wondered how the newer electronic torque wrenches do at maintaining accuracy and durability over time compared to the mechanical ones.
  12. Sep 3, 2020 at 7:28 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Badass setup!
  13. Sep 3, 2020 at 7:44 PM
    You found it! Yeah nice setup. Best I've worked with after all these years. A full complement of parts too!.
    14burrito[QUOTED] likes this.
  14. Sep 3, 2020 at 7:49 PM
    Digital torque wrenches aren't necessarily better than non digital. Depends on the "guts". Has nothing to do with accuracy, repeatability, or durability. Simply convenience with the display. The vast majority of torque wrenches we get in our cal lab are non digital. I wouldn't buy a digital torque wrench. My preference...
    huntertn[QUOTED] likes this.
  15. Sep 3, 2020 at 8:27 PM
    Kuul that your grandfather left you that roller! Early Snap On! FYI....Cornwell and Mac are basically the same. Same "guts". You'd be surprised that most well known brands innards come from a single source....many
    Bravohook[QUOTED] likes this.
