Torque spec?
Discussion in 'Suspension' started by oneup, Apr 6, 2019.
  1. Apr 6, 2019 at 10:04 AM
    oneup
    oneup [OP] New Member
    Cincinnati
    17 cm
    I’m in process of installing 6112. I read on here that 2 bolts which separates knuckle from bottom needs to be 220lb. Am I reading it right?
  2. Apr 6, 2019 at 10:08 AM
    15whtrd
    15whtrd Mr. Blonde
  3. Apr 6, 2019 at 10:09 AM
    oneup
    Cincinnati
    17 cm
    So I’m guessing LCA ball
    Joint attachment is that 2 bolts you need to loosen up to install coilover right?
    glowblue and 15whtrd like this.
  4. Apr 6, 2019 at 10:16 AM
    15whtrd
    15whtrd Mr. Blonde
    SprinterAE86 likes this.
  5. Apr 6, 2019 at 10:19 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    yes 220 ft/lbs and use red loctite per service manual
  6. Apr 6, 2019 at 10:20 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Took the words out my mouth. Red loctite and elbow grease.
    osidepunker[QUOTED] likes this.
  7. Apr 6, 2019 at 11:07 AM
    oneup
    Cincinnati
    17 cm
    Thanks!
    osidepunker likes this.
  8. Apr 6, 2019 at 2:35 PM
    oneup
    Cincinnati
    17 cm
    got it done. I’m gonna be sore tomorrow
    15whtrd likes this.
  9. Apr 6, 2019 at 3:02 PM
    15whtrd
    15whtrd Mr. Blonde
    Haha yeah it definitely takes some effort
  10. Apr 8, 2019 at 6:29 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    They don't have red loctite on them from the factory, do they?
  11. Apr 8, 2019 at 6:33 AM
    Danman34
    Danman34 New Member
    Danny
    Any bolt on the front end that is succumb to vibrations should have thread lock on it. You most def do not want those bottom bolts backing out on you haha.
  12. Apr 8, 2019 at 6:34 AM
    BlackSheep
    Scott
    Kansas City, MO
    crap. i just finished removing all the little fake beadlock bolts from my RW wheels. That chore was a total and complete PITA, and those only had blue loctite on them.
  13. Apr 8, 2019 at 6:42 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    The service manual specifically instructs to use red loctite. Those bolts hold the weight of the truck so you want them glued in place. They'll still come off with a breaker bar in the future
    You should use blue on almost everything, red on the critical big bolts
  14. Apr 10, 2019 at 9:02 AM
    BlackSheep
    Scott
    Kansas City, MO
    Will I need to heat any bolts treated with red to 500 deg. as the product specs state? Which others, besides the two LCA bolts, will be treated with red?
  15. Apr 10, 2019 at 9:39 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    No.
    I don't have them memorized, I just follow the service manual instructions.
  16. Apr 10, 2019 at 9:41 AM
    BlackSheep
    Scott
    Kansas City, MO
    thank you, as long as i don't need to worry with heating them, i can muster enough elbow grease to get the job done. :muscleflexing:
  17. Apr 10, 2019 at 9:45 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I take mine on and off all the time. I have uniballs and a long travel suspension so I'm always doing maintenance that requires disconnecting them.
    A 1200ft/lbs impact won't take them off, but a regular 1/2" breaker bar will
  18. Apr 10, 2019 at 9:49 AM
    BlackSheep
    Scott
    Kansas City, MO
    1/2" breaker is exactly what i have.
  19. Apr 10, 2019 at 9:53 AM
    15whtrd
    15whtrd Mr. Blonde
    Damn. My pro instructions did not mention anything about Loctite. I torqued my lower control arm knuckle bolts to the proper spec and then used a paint pen to mark their position so I can tell if they back out. So far they haven’t even moved. Would you recommend that I took them back out one at a time and put Loctite on and then reinstall?
  20. Apr 10, 2019 at 10:12 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    The pro instructions disagree with the service manual.
    I would back them out and add the red loctite if it were me. Especially if you off road.
    bolt marks don't mean shit if they back off while you are driving...
    JohnLakeman and 15whtrd[QUOTED] like this.
  21. Apr 10, 2019 at 10:28 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah dammit. I guess I know what I’ll be doing this weekend. Or at least very soon.
  22. Apr 11, 2019 at 2:05 PM
    15whtrd
    15whtrd Mr. Blonde
    Ok just finished up removing the bolts and installing red locktite. Easy and quick. I feel better now. Good looking out!
  23. Apr 12, 2019 at 4:35 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I love when someone actually follows through! Good job yo! :thumbsup::thumbsup::thumbsup:
    15whtrd[QUOTED] likes this.
  24. May 30, 2022 at 8:54 PM
    Flockem
    Flockem New Member
    Remington
    2016 Crewmax 4x4
    6112/5160 +CB shims SPC UCA and Diff Drop Toytec Shackles 35x12.50 BFG ATs on factory 20s Spidertrax 1.25s BMC Headlight Revolution SM LED Breather Mod Dents in the body due to trees...
    TRD instructions say 207 on lower CAs and the dealership is saying 96
    others on here have said 96
    With it around 96 I get a pop at low speed turns… when i tried to get them to 200 the pop stopped.
    so my question is 207 too much? Why does Toyota have conflicting info?
    is there that big of a difference between 96 and 207… I think so but I’m not a technician
