Torque Spec on Carrier Bearing (Shaft) Nut?
Discussion in '1st Gen Tundras (2000-2006)' started by Professional Hand Model, Nov 18, 2018.
  1. Nov 18, 2018 at 6:06 PM
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    2002 Tundra 4x4 SR5 Access Cab V8. New Carrier Bear and Nut going on in place of the old. Need spec. Thank you.
  2. Nov 20, 2018 at 4:39 AM
    Hand Protectors
  3. Nov 20, 2018 at 7:17 AM
    Casper421
    In the woods
    06 DC
  4. Nov 20, 2018 at 3:00 PM
    Hand Protectors
    Thank you! Looks like a tighten, then loosen, then tighten situation.
    MS22 and Casper421 like this.
  5. Nov 20, 2018 at 3:08 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Attached is the dis and reassembly from the service manual.
    landphil likes this.
  6. Nov 20, 2018 at 3:17 PM
    Hand Protectors
    Anyway to post a screen grab(s)?
  7. Nov 20, 2018 at 3:40 PM
    Festerw
    Festerw New Member
    04 Tundra DC
  8. Nov 20, 2018 at 4:39 PM
    Hand Protectors
    The lack of me having a SST Tool is making me now readjust my strategy of having the heavy truck shop do the carrier bearing install. Was just gonna skip the u-joints but will have them done simultaneously. I’ll just remove the propeller and take it up there and let them have fun with it. Pick it up and reinstall.
    I wonder if I could bolt the other end of the propeller to a wall and use that as leverage instead of this SST Tool? Or, just crank off the nut with the other end still attached to the transfer case?
  9. Nov 20, 2018 at 5:40 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I did it without anything special, since it's only torqued to 60 it isn't real hard to get off. A couple whacks with a dead blow hammer and the flange and bearing came off easily. Whole job took maybe 45 minutes.
  10. Nov 20, 2018 at 5:46 PM
    Hand Protectors
    Is that nut 24mm? I ordered a new OEM one, but it didn’t specify the size. Should be here tomorrow.
  11. Nov 20, 2018 at 6:18 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I don't recall off the top of my head, it took a pretty good size socket. I know I didn't have a large enough metric, used a 1 1/8" I believe.
  12. Nov 23, 2018 at 4:38 PM
    Hand Protectors
    Here is the OEM carrier shaft nut (24mm). Total cost with shipping $6.02.
  13. Mar 7, 2022 at 8:14 AM
    Playfast12
    Playfast12 New Member
    I thought he asked for torque specs for the carrier bearing?
  14. Mar 7, 2022 at 8:43 AM
    You revived a post from 2018. :boink:
  15. Mar 7, 2022 at 9:52 AM
    Playfast12
    Yeah I know, hope everyone is still kickin.
    tacoguybill likes this.
