Topper fit
Discussion in 'Tonneau Covers, Caps and Shells' started by ionyota, Sep 9, 2020.
  1. Sep 9, 2020 at 11:42 AM
    ionyota
    ionyota [OP] New Member
    Will a topper/camper shell from a 2007-2013 CrewMax (5.5 ft bed) fit on a 2014 - 2020 model?
    And vice versa?
  2. Sep 9, 2020 at 12:43 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Will it fit? Idk but the tailgates are different.
  3. Sep 9, 2020 at 2:43 PM
    TheBeast The Beach
    there is a video from a member here that shows how to adapt and the differences.
  4. Sep 9, 2020 at 2:44 PM
    ionyota
    Do you know what section of the site that video resides in?
  5. Sep 9, 2020 at 2:46 PM
    TheBeast The Beach
    i found it, he is a member here. he runs a mtb YT channel now.
    ionyota[OP] likes this.
  6. Sep 9, 2020 at 2:54 PM
    I remember that vid but info is outdated. A real pain in the ass to convert but certainly doable.
  7. Sep 9, 2020 at 2:56 PM
    TheBeast The Beach
    yeah it seems some work was involved to make it fit.
    Black Wolf likes this.
  8. Sep 9, 2020 at 2:58 PM
    I see a lot of used CM toppers on Craigslist all the time. Might be a color match issue for the OP and a good deal. Hmmmm...
    TheBeast[QUOTED] likes this.
  9. Sep 9, 2020 at 4:31 PM
    ionyota
    Thanks guys. I was only going to consider it if the toppers were plug and play. Agreed, looks like a lot of work.
  10. Sep 9, 2020 at 4:32 PM
    ionyota
    It’s not a color match issue as I’m likely going to Linex the exterior of the topper anyway.
    I’m just looking for a used topper for a 07 - 13 and not finding many near me. So I was hoping the newer model version would work, but oh well. Keep looking.
  11. Sep 9, 2020 at 4:43 PM
    Where are you located? Maybe we can help with your search!
    BlackSheep likes this.
  12. Sep 9, 2020 at 4:43 PM
    ezdog
    ezdog New Member
    Gateway To The West
    OK my experience is with the Long Bed versions and I do not know if the same exact differences are similar with the other bed length so.......
    The only difference in the Long Bed are the tailgate thickness which adds 1.5" in the 3rd gen trucks vs the 2nd gen truck.
    So all I had to do to use a 2nd gen shell on a 3rd gen truck was get a piece of 1.5" or 2" L Angle the width of the bed which was esily bought at a hardware store and rivet it to the cab end of the shell.
    This closed the 1.5" gap that I ended up with when the shorter 2nd gen shell was fitted to the tailgate end of the bed.
    Then of course I lined the two sides and cab end under the edge with weather sealing rubber tape and clamped the shell in place.
    Not a deal at all really if you are even a little bit handy with tools.
  13. Sep 9, 2020 at 4:44 PM
    ....also check out Durabak.com if you want to DIY lining.
  14. Sep 9, 2020 at 5:09 PM
    ionyota
    Bozeman, Montana. And willing to travel a bit for a good deal.
  15. Sep 9, 2020 at 6:14 PM
    Kuul, I'll check out what's up in your area. Can't hurt.
    ionyota[QUOTED][OP] likes this.
  16. Sep 9, 2020 at 6:32 PM
    ionyota
    I don’t think I mentioned that what I’m looking for is a topper that fits a 2010 CrewMax (5.5 foot bed)
    Plan to put a rack on it to hold a roof top tent.
  17. Sep 9, 2020 at 7:05 PM
    RTT on it??? Game changer. You are going need a topper with appropriate structural option that can handle the additional weight of a RTT. Huge game changer. A used one if you can find one used will cost you $2K easy....
    TheBeast likes this.
  18. Sep 9, 2020 at 7:08 PM
    SouthWestGA
    SouthWestGA New Member
    Here’s the compatible list
    07-13
    14-17
    18-20
    Cabs must be the same style
    second and third gen are not compatible
    The third gens are a few inches longer
    I have an 07 camper top that was on a 14 model with a gap at the end. The owner got it second hand but it didn’t fit
    it fits my 07 perfectly
  19. Sep 9, 2020 at 7:09 PM
    ionyota
    Very possible, but I think a lot of average toppers can hold more weight than the manufacturers are willing to let on/state for liability reasons.
    I could be wrong and find out the hard way on that, but we’ll see.
  20. Sep 9, 2020 at 7:18 PM
    The hard way could get quite expensive with overload to bedsides without reinforcement. Backing out of this......
  21. Sep 10, 2020 at 3:17 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Except that as I said above that gap is a simple effective fix or at least has been for me 3 different times now.
  22. Sep 10, 2020 at 4:32 PM
    ionyota
    @SouthWestGA - So did they make double cabs with a 5.5 ft box?
    If so, would that topper fit on a CrewMax?
  23. Sep 10, 2020 at 5:40 PM
    SouthWestGA
    @ionyota
    I am not aware of a Double Cab with a short bed on 2007 and newer models. I believe all double cabs have full size beds.
    the 2007 and up CrewMAX have short beds
  24. Sep 10, 2020 at 9:16 PM
    ionyota
    Suspected that, but wasn’t sure.
  25. Aug 30, 2024 at 6:38 AM
    MoTundra
    MoTundra New Member
    Nick
    2007 Black 5.7 rcsb work truck
    Stock
    @SouthWestGA I have a 2007 rcsb and it’s odd, the crew max is the only tundra with the actual short bed yet Toyota still calls the 6’5” the short bed instead of the regular bed from what I’ve seen. Odd.
