TopCoat F11 is the Proverbial Shiznit.
Discussion in 'Detailing' started by Backslider, Jul 1, 2017.
  1. Jul 15, 2017 at 6:35 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Looks good @Backslider !
    How's the maintenance on it after 1st application? I'm assuming you just re-apply on top without doing anything else? Please update us with results and maintenance. I'm tempted to try this product! How long are people reporting saying it is lasting on their vehicles?
  2. Jul 15, 2017 at 7:10 AM
    Backslider
    Backslider [OP] Thirsty...
    Tooele, UT
    Went almost two weeks before washing my wife's car, and even when I did wash it it looked pretty great outside of some grill and windshield bugs. When I did wash it I just used water and no soap and everything came right off. I then tried with a clean microfiber towel.
    They say that after a few applications you can just wipe off dirt but I don't feel comfortable doing that yet. Even just a quick rinse and dry is a lot faster than my usual process, so I'm very happy with it.
    They say that after a few coats it creates a strong bond with the paint, so I may try the wipe method after a few months.
    Allegedly it lasts 3-6 months, and there are a few YouTube videos out there claiming that too. I am going to reapply to both of our vehicles within the next week or so and hope to get at least 4 months before reapplying. It's supposed to be that the longer you have used it the longer it will last. You're also supposed to need less of it after the initial coat. When I reapply it in a few days I hope to confirm that.
    BlueBottle[QUOTED] likes this.
  3. Jul 15, 2017 at 7:17 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Nice. How long did it take to ship once you ordered? Really tempted now.
  4. Jul 15, 2017 at 7:20 AM
    Backslider
    Tooele, UT
    About a week to arrive. Not long at all in my opinion.
  5. Jul 15, 2017 at 8:07 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Great @Backslider just ordered me the $60 special!!! U guys are costing me too much $$$.
  6. Jul 15, 2017 at 8:49 AM
    Backslider
    Tooele, UT
    Nice! I'm positive you will love it. First application requires some prep work but after that it should be smooth sailing!
    If it makes you feel any better I'm about to drop $1000 on retrofits today, but to be fair I am also buying a pair of OEM headlights at a great deal to do it with.
  7. Jul 15, 2017 at 8:49 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I need some retros in my life too. Your one step ahead of me bud!!!! One day...
  8. Jul 15, 2017 at 8:51 AM
    Backslider
    Tooele, UT
    Not ahead, same distance on different paths! You've got a ton going on that I'm jealous of.
  9. Jul 18, 2017 at 7:31 AM
    ToyotaTundraMike
    2015 Tundra
    May have to give this a shot, been using the H2O guard and gloss from Adams Polishes and it works fairly well, but doesn't last as long as I had hoped.
    Backslider[OP] likes this.
  10. Jul 18, 2017 at 7:39 AM
    Backslider
    Tooele, UT
    You should give it a shot - I've only got a month on the 4runner but it still looks freshly washed. I did rinse it off and dry it but used only clean water and no soap. The Tundra, with the exception of some mud around the wheel wells, also looks like it just got washed.
  11. Jul 18, 2017 at 7:45 AM
    ToyotaTundraMike
    2015 Tundra
    Think I will. Almost out of the other stuff anyway. Definitely wish they sold a smaller bottle to test it out first, but I'll take your word for it.
  12. Jul 25, 2017 at 7:49 AM
    Borgs
    Borgs New Member
    PA
    I am thinking about pulling trigger on a bottle of this. I am still unclear on surface prep before application. The website suggests there isn't much surface prep as the product will work its way through any existing wax over time.
    From the FAQ of the TopCoat website:
    Before F11™ is applied, make sure your bike, vehicle, or surface is cleaned first. You can use any products to wash but preferably use products without wax in it, or any synthetic “coating” for “protection” as the F11™ won’t bond properly on the first application. However, each application of F11™ will push out any other coatings that were there and F11™ will eventually bond 100% to the substrate. If you want to add several coats of F11™ to your surfaces, wait at least 24-48 hours between coats to ensure effective performance. Multiple, consecutive coats can be applied, but you will not achieve the benefits as you would by allowing one application to “set up” or “cure” first within the stated time frame. Clay Bar: If you have any contaminants in the paint, overspray, or hardened fallout where you need or want to Clay your paint, you can clay it and use F11™ as the solution, thus claying and adding the coating all at the same time! F11™ works amazing with clay bars.
  13. Jul 25, 2017 at 8:31 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Received mine yesterday. Took about a week to receive. It will be a while before I try it out. gonna use it on the wife's jeep first as that one needs more TLC right now. Gotta clay and polish it first.
  14. Jul 25, 2017 at 9:03 AM
    Backslider
    Tooele, UT
    On my truck, which has wax, I used Chemical Guys "Clean Slate" to strip the wax. They say that multiple coatings will eventually clear up the wax, but because it's so expensive I chose just to strip wax instead.
    Hope you guys post your results! I was going to detail and apply a 2nd coat to my Tundra last night but chose not to. Today we have unexpected and fairly heavy rain, which is strange for July in Utah.. Phew.
    Eclipsed & Floating likes this.
  15. Jul 25, 2017 at 9:19 AM
    Borgs
    Borgs New Member
    PA
    Makes complete sense. I got my truck in May - and while I probably should have already - have not polished or waxed it yet.
  16. Jul 25, 2017 at 6:16 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Backslider did you apply the coat on everything? Plastic, Rubber, glass?
  17. Jul 25, 2017 at 7:26 PM
    Backslider
    Tooele, UT
    Not on glass but yes to everything else. Made windows moldings and mirrors look amazing.
  18. Jul 25, 2017 at 8:33 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Just finished the Jeep. That was the easiest protection coating I have ever applied. Kinda feels like how it feels to apply Rain-X. Now to test to see how well it performs/lasts.
  19. Jul 25, 2017 at 9:35 PM
    #49
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Not on glass, bit u did the windows?+
    BlueBottle likes this.
  20. Jul 25, 2017 at 9:54 PM
    #50
    Backslider
    Tooele, UT
    Just windows moldings.
  21. Jul 25, 2017 at 9:55 PM
    #51
    Backslider
    Tooele, UT
    Looks great!
  22. Jul 25, 2017 at 9:57 PM
    #52
    Backslider
    Tooele, UT
    I wish I could say I was drunk when I wrote this..
    I applied to the plastic and rubber surrounds on the glass and mirrors, but not on gflass and mirrors themselves. I did apply to my headlights and it has made but removal quick and effortless.
  23. Jul 25, 2017 at 10:13 PM
    #53
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    I use it and it really makes the color pop! I don't think that it lasts very long,but I just washed and dried no clay bar and applied, 3rd coat so far.still on the fence for this product.
  24. Jul 25, 2017 at 10:27 PM
    #54
    swede78
    Lars
    westminster co
    Nothing yet
    My truck is a 2008, bought it in 2013 or 2014 (who cares) I have never waxed it and I don't know if the previous owner did.my paint looks pretty good I'm op the pin striping is fading. 3rd coat of f 11 in about 3 months. 20170720_145947.jpg 20170720_145947.jpg 20170720_145824.jpg 20170718_204246.jpg
    Backslider[OP] and BlueBottle like this.
  25. Jul 25, 2017 at 10:29 PM
    #55
    BlueBottle
    '16 Platinum 4x4
    See fine print
    How long is it lasting you and how are you maintaining it? I read on topcoat that your not supposed to use soap or water!? Just a microfiber rag and maybe some more topcoat? Scary thought to do. Anyone do this?
  26. Jul 25, 2017 at 10:30 PM
    #56
    swede78
    Lars
    westminster co
    Nothing yet
  27. Jul 25, 2017 at 10:37 PM
    #57
    swede78
    Lars
    westminster co
    Nothing yet
    I think it's a easy detail, very easy. A good scrub down,a good wax and some time you will have a better lasting shine, inop.
  28. Jul 26, 2017 at 4:03 AM
    #58
    Backslider
    Tooele, UT
    Are you using soap? I am just rinsing with water and wiping with a wet microfiber towel, goxing to see how that works. After over a month on the 4runner it's still there and still beads water really well.
  29. Jul 26, 2017 at 6:40 AM
    #59
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I'm so scared to wash without soap. It's so not what your regularly supposed to do lol.
    Have you dealt with bird poop yet? Wondering how to deal with that once it occurs.
  30. Jul 26, 2017 at 6:49 AM
    #60
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    How does thid stuff hold up when grainey mud and road sludge is constantly being slung? Any idea?
