Top Engine, EFI, and Throttle Body Cleaning
Discussion in 'General Tundra Discussion' started by Tundyfundy, Oct 27, 2020.
  1. Oct 27, 2020 at 10:26 PM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I was at the dealership and they were offering a "Top Engine Cleaning" which was around $200.00. I was looking into this further and it basically is a cleaning of the top engine, the EFI Sytem and the throttle body of the Tundra. The service representative said they basically use the Toyota Induction kit for this cleaning.
    The price seemed high to me and after searching around I found the Induction kit he was referring to. Linked here https://parts.toyota.com/p/Toyota-Induction-Kit/69278036/00289INDKT.html
    It basically consisted of
    1. A spray cleaner for the throttle body and throttle plate https://www.amazon.com/Genuine-Toyota-00289-1TP00-Throttle-Cleaner/dp/B00C39314S
    2. An additive for the gas tank to clean the EFI Sytem https://parts.toyota.com/p/Toyota-EFI-Cleaner-Pour-in-Tank/69280273/00289EFI00.html
    and
    3. A top engine cleaning chemical to be administered through a vacuum port on the intake manifold. https://parts.toyota.com/p/Toyota-Top-Engine-Cleaner/69278031/002891TE00.html
    The instruction for the EFI additive and the throttle body cleaning were straight forward but the instructions for the top engine cleaner were not.
    You basically need a special tool to hold the can of cleaner and administer it into the intake manifold. You can see the tool on the link I posted for the top engine cleaner but that part number is discontinued. So after a few phone calls to the dealership they called Toyota to find out what was going on and they gave me this part number to the part needed to administer the top engine cleaner
    https://parts.toyota.com/p/Toyota__/TOP-ENGINE-CLEANER-T/72013517/0028900189.html
    Part number 00289-00189
    I was able to shop around and found it for $53.83 through Piercey Toyota.
    It's a bit spendy but after the initial buy you can basically do the cleaning whenever you want on most Toyota vehicles for about 25 bucks (the cost of the induction kit)
    You will also need a short length of rubber tubing (About 4 inches) in order to connect the tool to a vacuum port on the intake manifold. I used a piece of 1/2" automotive tubing and it worked well. There is a smaller vacuum port that looks about 1/4" but Toyota doesn't really specify which one to use.
    What I can say is after the cleaning of the top engine, EFI and the throttle body I felt a significant difference in the smoothness of the throttle and increased power lower in the RPM range. I also cleaned my MAF sensor just for good measure as its part of the induction system. I highly recommend this. It seemed the engine was more responsive in the throttle and was breathing easier (Hard to describe), I felt before I had to give it more gas at lower RPM's. The best way I can describe it is it rolls easier into the higher RPM range. Much smoother, for what its worth. Hope this helps!
    EDIT: At the time of cleaning I had about 85,000miles on the odometer.
    JohnLakeman, Wallygator and P-Factor like this.
  2. Oct 27, 2020 at 10:33 PM
    Tundyfundy
    Bay Area, CA
    JohnLakeman likes this.
  3. Oct 28, 2020 at 1:50 AM
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
    i did this on my 13 tacoma which was direct injected and helped drastically with the pre ignition problems I had
    Tundyfundy[OP] likes this.
  4. Oct 28, 2020 at 4:41 AM
    Wallygator
  5. Oct 28, 2020 at 8:51 AM
    Tundyfundy
    Bay Area, CA
    I didn't think I had a problem either but it made a difference! I use sea foam almost every oil change as well to keep things tip top. I’ll try the amsoil.
    Wallygator[QUOTED] likes this.
  6. Oct 28, 2020 at 8:56 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    The tundra is MPI, not DI, so IMHO top end cleaner isnt much more than them trying to upsell you.
    Do the TB clean, run some stuff in the tank, run a cleaner in the crankcase and call it a day personally.
