Too Much Rake?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Badknees, Jan 25, 2021.
  1. Jan 27, 2021 at 11:37 AM
    #61
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Did you go with the standard duty set or the heavy duty set?
  2. Jan 28, 2021 at 6:50 PM
    #62
    tundra121
    tundra121 New Member
    Thanks your Tundra looks great also can't go wrong with white lol. Its been a work in progress not sure how much more I will do ...pro skid plate is going on next oil change hate dropping the existing one down to do a oil change and Auburn Pro Series Limited Slip Differential to be done in the spring this should have been the minimum set up on these trucks.
    With 3/4" wheels the studs do bottom out on the wheel I machined a slight reseced hole about 1/16" in the pockets of the factory wheel.
    Badknees[QUOTED][OP] likes this.
  3. Jan 29, 2021 at 4:21 AM
    #63
    Badknees
    Badknees [OP] New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Thanks very much for the information about the BORA wheel spacers - it is very helpful. Also, I'm not educated enough yet about the LSD on the Tundras. What are the benefits of the Auburn unit over OEM?
  4. Jan 30, 2021 at 5:45 PM
    #64
    tundra121
    The LSD works off wheel speed sencers and applies brakes to lock wheels for traction when one starts to spin ... auburn unit is clutch pacs in the diff witch works way better. I haven't checked out if true/trac makes a limited slip diff for the tundra it would be a better option. We installed them on my sons Tacoma.
    IMG_3335.jpg I can't go places my son can now that's he's change out the rear end.
  5. Jan 30, 2021 at 5:54 PM
    #65
    Badknees
    South Carolina
    Thanks for the info. Off topic but your truck is almost identical to mine. Did you add the TRD dual exhaust? I have a 295/70 R18 spare and I’m concerned the exhaust won’t clear?
  6. Jan 30, 2021 at 6:05 PM
    #66
    tundra121
    I am running 295/70 r18 also and Yes I did add the Trd dual exhaust but I don't have the spare switched over yet still waiting for a tire. Hopefully don't get a flate lol IMG_3332.jpg
  7. Jan 30, 2021 at 6:11 PM
    #67
    Badknees
    South Carolina
    I had to make a mod to the spare brackets to make it fit. I cut/drilled out the inner most rivets and installed a 1/4” washer and bolt to tilt each bracket back and allow for the 34” OD tire. If you have interference with your exhaust once you get your spare pls. Let me know. Many Thanks.
  8. Jan 30, 2021 at 6:17 PM
    #68
    tundra121
    The guy I picked up the trd wheels from had a 35" spare tire on his tundra with dual exhaust he was running a 6 inch lift but don't think that would change much. Once I get mine done I will let you know. Thanks for the tip should make it easier for me.
  9. Jan 30, 2021 at 6:21 PM
    #69
    Badknees
    South Carolina
    Just as info., I used a side grinder to cutoff most of the rivets and then drilled out after-PITA!
    tundra121[QUOTED] likes this.
  10. May 13, 2022 at 9:30 AM
    #70
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    Did someone say too much rake? :gossip:…… Finally got around to putting on a new set of Alcan leaf springs…. 800#’s over stock..2”of lift…1” shackles… (trying to get rid of the constant ass-sag and having to keep 20#’s of air in the bags even when the bed was empty…) The ride is better IMO… feels more planted and stable on acceleration… Feels like a truck… :notsure: I may have to adjust my front up a little….IDK.. We’ll see how it feels when i get everything loaded back in and the trailer hooked up…. Can you have too much rake :monocle:… Only thing that stands out to me is… NOW my 35’s look small … :annoyed:.. I’m thinking I can’t afford this truck…
    2F8EBDBB-AE20-47ED-86E0-D756794F1734.jpg 2AACC707-FAE5-404C-963E-B80D244C6C8C.jpg ….354EDF50-EB65-400A-95AB-B8F3A1558EF6.jpg
    Badknees[OP] likes this.
  11. May 13, 2022 at 10:12 AM
    #71
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    I prefer the level look, but don’t think the rake looks bad. If you want to level out the front, I’ve enjoyed the Westcott Designs setup on my front (w/TRD pro fox suspension all around). I don’t regularly tow enough to sag out my rear, and it pulls my SxS and boat just fine without dropping the ass end.
  12. May 13, 2022 at 1:00 PM
    #72
    Badknees
    South Carolina
    Maybe if you go back to stock shackles you’ll be closer to the rake you want? Looks good to me as is though and it’s bound to settle some.
  13. May 13, 2022 at 1:19 PM
    #73
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    what are the red calipers on your truck?
  14. May 13, 2022 at 1:38 PM
    #74
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    I stayed with Alcan shackles to be safe.. some folks on here have had issues with their springs making noise… they are close to in size to stock anyhow… I actually prefer the rake.. just maybe not that much…
    PowerBrakes and 2stage rotors… not for the faint of heart:spending: awesome stopping and feel… not sure I recommend them though… limited pad availability kinda locks you into buying from distributor…$$$$
  15. May 13, 2022 at 1:54 PM
    #75
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Makes sense-they look pretty cool poking through your black wheels. Glad they’re working well for you; appreciate the caution on recommendation
  16. May 13, 2022 at 3:23 PM
    #76
    Badknees
    South Carolina
    Painting them is always an option but a real PITA.
    Dogsled likes this.
