Too Much Rake?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Badknees, Jan 25, 2021.
  1. Jan 25, 2021 at 8:55 AM
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    That rake looks perfect to me
    Badknees[OP] likes this.
  2. Jan 25, 2021 at 9:15 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    2E2E9625-2944-4B4E-AD54-D4309E62D88B.jpg Not sure why anyone wants to be level? Looks great!
  3. Jan 25, 2021 at 9:22 AM
    Badknees
    Badknees [OP] New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Thanks for the input. Nice looking Tundra you got there.
  4. Jan 25, 2021 at 12:07 PM
    Badknees
    South Carolina
    Not sure where you are, but I think these are like mine on Atlanta C.L.:
  5. Jan 25, 2021 at 12:14 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Thanks! I had @BashFab weld some sliders up. They’re amazing. FA34421B-1033-4B2B-91B6-9AE57E140409.jpg
    plumber802 and Badknees[OP] like this.
  6. Jan 25, 2021 at 12:28 PM
    Jabos30
    Jabos30 New Member
    Greer,SC
    2020 Tundra XP Hunter
    So just adding the TRD shocks raised the truck about 2”?
  7. Jan 25, 2021 at 12:34 PM
    Badknees
    South Carolina
    Yes, front TRD Pro suspension will raise the front approx. 2" on a stock Tundra.
  8. Jan 25, 2021 at 12:39 PM
    Jabos30
    Jabos30 New Member
    Greer,SC
    Does it raise the back also?
  9. Jan 25, 2021 at 12:41 PM
    Jabos30
    Jabos30 New Member
    Greer,SC
    What is involved in doing that? Is it just changing the shocks?
  10. Jan 25, 2021 at 12:41 PM
    Badknees
    South Carolina
    There is some debate I've seen about the rear TRD Pro shocks raising the back. I didn't see any increase but I have seen others on this site that show theirs raised up to 0.75". On the safe side, I wouldn't expect it.
  11. Jan 25, 2021 at 12:46 PM
    Jabos30
    Jabos30 New Member
    Greer,SC
    Where did you get your TRD shocks? Does it ride better than the stock shocks?
  12. Jan 25, 2021 at 12:47 PM
    Badknees
    South Carolina
    It's a bit involved on the front but simpler on the rear. If you're not too mechanically inclined and don't know your way around suspension work a little, I recommend taking it to a professional to have it done. I did mine myself as I didn't want to pay the "stealership" over $500 to do it for me.
    If you have a stock Tundra, just adding TRD Pro will level the front with the rear.
  13. Jan 25, 2021 at 12:49 PM
    Badknees
    South Carolina
    I see today for the first time that Amazon is selling the TRD Pros. However, I suggest you do some research on this site as there are plenty of less expensive alternatives that will likely get you what you want. And yes, these ride much better than the stock suspension.
  14. Jan 25, 2021 at 1:04 PM
    Jabos30
    Jabos30 New Member
    Greer,SC
    So the front is not just shocks but the coil over, correct?
  15. Jan 25, 2021 at 1:15 PM
    Badknees
    South Carolina
    You probably need to do some research on this site as I'm not the best to answer all your questions. It's all about how you plan to use your truck and how much you want to spend. You can go anywhere from cheap spacer kits just to raise the fronts and rear for a certain "look" (not recommended for any off-roading and won't help your ride much) to high end upper control arms, front coil-overs, extended rear shocks, and other suspension parts that can make your truck tackle most any terrain.
    lonedrake likes this.
  16. Jan 25, 2021 at 1:34 PM
    Jabos30
    Jabos30 New Member
    Greer,SC
    Thanks. Sorry about all the questions.
  17. Jan 25, 2021 at 1:41 PM
    Kanobi13
    Kanobi13 New Member
    Yes the front trd shocks is entire coil over will lift 2 inches
  18. Jan 25, 2021 at 1:56 PM
    Jabos30
    Jabos30 New Member
    Greer,SC
    I gotcha. I see that you can buy just the trd pro shocks and I think that is where I misunderstood it. I would like to do a 2” lift all the way around but it is pricey.
  19. Jan 25, 2021 at 1:56 PM
    #49
    Badknees
    South Carolina
    No worries! If you’re like me there’s lots to learn but plenty of very experienced and knowledgeable folks on this site that can help.
  20. Jan 25, 2021 at 2:13 PM
    #50
    Kanobi13
    Kanobi13 New Member
    Other budget options bilstein 5100s or 6112s.
  21. Jan 25, 2021 at 2:34 PM
    #51
    Jabos30
    Jabos30 New Member
    Greer,SC
    Yeah. I have looked at those.
  22. Jan 25, 2021 at 7:43 PM
    #52
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    The rake is perfect for a truck.
    As others have posted, just a little weight in the back can level it out.
    I can’t stand when the tail is dragging, especially when due to a just moderate load.
    Love the rake.
    Y0TA PR0 and Badknees[OP] like this.
  23. Jan 25, 2021 at 7:59 PM
    #53
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I just put a set on my truck and it raised my rear 1" using the "dime" gap measurement. I would assume it would lift it more with the "quarter" method. Easy to follow instructions. I don't tow anything, I just got a great deal on the set and decided to give them a shot.
  24. Jan 25, 2021 at 8:07 PM
    #54
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    FE3B4A7A-1750-4C93-AC69-1A46FE05E30B.jpg Thinking about a rear bumper to help with my rake problem?
  25. Jan 26, 2021 at 2:06 AM
    #55
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    $3200 (plus 7% sales tax for me) for TRD Pro Fox shocks!?!?!? OUCH!
  26. Jan 26, 2021 at 4:26 AM
    #56
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    How is the ride unloaded? And an 1" would be perfect because my cap has my truck sitting about an inch lower so that would be perfect
  27. Jan 26, 2021 at 5:33 AM
    #57
    Badknees
    South Carolina
    Thanks Lug Nut and others for your comments. I think I've decided to leave the rake alone for now.
  28. Jan 26, 2021 at 9:56 PM
    #58
    tundra121
    tundra121 New Member
    The rake looks right ....3/4" spaces will help a lot from stone chips and mud flinging up on the truck. I had after market +18 wheels for a while but went back to factory with 3/4 spaces just barely stick past fender. I am running the pro suspension with a 1" block in the rear. IMG_2500.jpg
  29. Jan 27, 2021 at 4:14 AM
    #59
    Badknees
    South Carolina
    Many Thanks Tundra 121. I really like the looks of your truck and had seen it on several other threads. I have almost exactly the same set-up as you, except I'm running 1" shackles rather than the 1" block (but getting 1.5" of lift). I agree about the spacers too, but BORA 3/4" are hard to find and I'm waiting now until late February before I can get what I ordered off Amazon.
  30. Jan 27, 2021 at 11:06 AM
    #60
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I'm unloaded 95% of the time. Ride is improved with less squat on take-off from the light. I'm partial to a slight forward rake myself, so sitting perfectly level was not my ideal stance. To each their own.
    Lake.Life24[QUOTED] likes this.
