Tonneau Drain
Discussion in 'Tonneau Covers, Caps and Shells' started by Rockpig, Dec 10, 2024.
  1. Dec 10, 2024 at 5:08 AM
    Rockpig
    Rockpig [OP] You did what?
    08 Limited
    Now that the weather is getting colder I'm yet to do something with the drains for my roll top tonneau. Presently when it rains they drain into the bed, wouldn't be concerned but I have a bed rug in there and I don't want it to have stuff freeze to it or for it to mildew.
    I know I'll have to drill to direct the drain tubes but want to do this as minimally invasive as possible. Let's see what you've done and used to do it.
  2. Dec 10, 2024 at 7:15 AM
    Breathing Borla
    Northern Illinois
    I had a detailed post or two on this with sizes etc , not sure where it is, one of the tonneau threads
    but 90 angled hose barb from the bed into the hose that runs up the side corner of the bed that way it lays flat under my bed mat
    Rockpig[OP] likes this.
  3. Dec 10, 2024 at 8:34 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    What if you park nose down? What about the thickness of the walls, floor, corners etc?
  4. Dec 10, 2024 at 8:50 AM
    Breathing Borla
    Northern Illinois
    what do mean?
  5. Dec 10, 2024 at 8:52 AM
    Breathing Borla
    Northern Illinois
    found it
    1371
    Rockpig[QUOTED][OP] likes this.
  6. Dec 10, 2024 at 2:13 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    May be yours won’t leak but every tonneau cover I’ve had over the years leaked. I’m sure relocating the drain hoses will help but there still will be leakage
  7. Dec 10, 2024 at 2:16 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    To remedy the problem, maybe a Sequoia is in order...
  8. Dec 10, 2024 at 2:37 PM
    Breathing Borla
    Northern Illinois
    sequoia rear cargo area is trash, toyota dropped the ball on that with the hybrid only. I think its one of the smallest cargo capacities out there for its class
  9. Dec 10, 2024 at 2:46 PM
    Rockpig
    08 Limited
    My driveway is flat so no run off to speak of, good idea but whatever falls on the cover would still shed into the tracks and into the drain holes of the cover.
  10. Dec 10, 2024 at 2:56 PM
    Breathing Borla
    Northern Illinois
    it takes effort to make them tight for sure.
    I spent time with the installs with silicone, weatherstripping, drains, etc and can get them pretty damn tight.
    I have installed 9 of them to date, so lots of practice, lol.
  11. Dec 10, 2024 at 3:17 PM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    I mean do you have a drain if the front wheels are lower than the back wheels, aka "nose down" or does it pond up inside the bed? Are there drains in the front corners? I have a spray in bedliner so I can't tell.
  12. Dec 10, 2024 at 3:20 PM
    Breathing Borla
    Northern Illinois
    I have drains in the front yes
  13. Dec 10, 2024 at 3:30 PM
    Rockpig
    08 Limited
    I know I can't waterproof it and there will be some intrusion into the bed but not nearly as much as the drains going into the bed.
  14. Dec 10, 2024 at 3:31 PM
    Rockpig
    08 Limited
    Sure, I have another spare 80k sitting around, why didn't I think of that ?
  15. Dec 10, 2024 at 3:32 PM
    Rockpig
    08 Limited
    Great idea, think I'll try to incorporate the 90's into the bedside just below the drains.
