2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. May 2, 2023 at 12:07 PM
    #1351
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Depends how much you charge me for the cover
  2. May 2, 2023 at 12:32 PM
    #1352
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Anyone interested in a Retrax Pro, visit me in the market place... Or whatever you call the area where you sell stuff, lol.
  3. May 2, 2023 at 12:37 PM
    #1353
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    I am thinking of going with the Undercover Armor flex when my truck arrives. Let me know what you think of their quality and fitment. Thx.
  4. May 2, 2023 at 3:17 PM
    #1354
    Breathing Borla
    AZ
    will do, I just got the call I can pick up my rig tomorrow so I should be putting on the undercover shortly here.
    HMNYC likes this.
  5. May 4, 2023 at 6:56 PM
    #1355
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Bakflip sent me a new cover and new rails. I do have to say customer service is great. HOWEVER! The new rails and new cover are no different. Same issue with the parts near the cab not being flush and same issue with the metal wanting to cut into the rubber. I put some padding on it to see if that helps, but the padding keeps it from closing well. Bummer.
  6. May 4, 2023 at 8:04 PM
    #1356
    Breathing Borla
    AZ
    I got my truck and I’ll put on the undercover flex ultra this weekend and let you know how it installs and looks
    for anyone that’s looking for an alternative
  7. May 5, 2023 at 5:54 AM
    #1357
    OCTX
    OCTX New Member
    23 Platinum LB
    Just got my undercover installed last night from www.versuscaraudio.com s ft worth they had them in stock
    G3ardnut likes this.
  8. May 6, 2023 at 11:45 AM
    #1358
    Breathing Borla
    AZ
    I’m installing my undercover right now, tried using the brackets with the cargo mount system and it’s phucked, way too much slop in the bracket tolerance, and it won’t hold up the rail level with the truck bed rail.
    I took out the cargo management system and installed using the other standard brackets they included and poof , dead on balls level and tight
    see pics, you can see the tilt and then see the other one nice and flat
    Jacen1794 likes this.
  9. May 6, 2023 at 11:58 AM
    #1359
    G3ardnut
    Joe
    Canada
    Interesting, that kind of sucks. I was hoping to retain the those factory cargo rails so I could put hold downs in between the tonneau rail clamps.
  10. May 6, 2023 at 12:02 PM
    #1360
    Breathing Borla
    AZ
    the factory tie downs are too big and you can use them even if you did mount with the cargo system brackets
    the four tie down spots on the bed are plenty for me
  11. May 6, 2023 at 12:04 PM
    #1361
    Breathing Borla
    AZ
    This is really nice , much better and also cheaper than the factory one anyways
    aligns and fits perfect
    Jacen1794 and G3ardnut like this.
  12. May 6, 2023 at 12:05 PM
    #1362
    G3ardnut
    Joe
    Canada
    There are after market tie downs that are smaller than the factory ones that will fit.
  13. May 6, 2023 at 12:06 PM
    #1363
    Breathing Borla
    AZ
    Off to Menards to find an adapter for the drain tube , not really wanting to drill out the holes more
  14. May 6, 2023 at 12:09 PM
    #1364
    G3ardnut
    Joe
    Canada
    Undercover does make a nice cover. I think it's better than the OEM or BAKflip but having never buying either I can only go by what others say.
  15. May 6, 2023 at 12:13 PM
    #1365
    Breathing Borla
    AZ
    I have had a lot of trucks and covers over the years, this one seems really high quality and tight, doubt I’ll have much water at all
    I have a tailgate gasket going on still and I hose test and silicon spot seal if I get any trickles but I don’t think there will be much if any with this one
    G3ardnut[QUOTED] likes this.
  16. May 6, 2023 at 12:13 PM
    #1366
    G3ardnut
    Joe
    Canada
    Let me know how that goes, interested in the adapters you choose and how you intend to secure them through the bed. I might be concerned in hitting them and snapping off.
  17. May 6, 2023 at 1:20 PM
    #1367
    Woocawachie
    Dickens
    Philadelphia
    So if my truck didn’t come with factory rails, I can install this cover without them? Just need the factory bolts ?
  18. May 6, 2023 at 1:27 PM
    #1368
    G3ardnut
    Joe
    Canada
    Yup.
  19. May 6, 2023 at 1:28 PM
    #1369
    Breathing Borla
    AZ
    I took out my cargo system and used the standard brackets it came with, works perfect
    I left the cargo rail in the front
  20. May 6, 2023 at 1:53 PM
    #1370
    Breathing Borla
    AZ
    Ok drains done , used 90 hose barb . I did wind up having to make the hole slightly larger but it was a breeze and with the 90 degree it lays flat and out of the way and works perfect with bed mat. Here’s pics with sizes
    I used a 21/64 drill bit and that size barb fits perfect
  21. May 6, 2023 at 2:17 PM
    #1371
    G3ardnut
    Joe
    Canada
    Looks great, never thought of using a 90 deg fitting so the bed mat covers them. I have seen some people use tie mounts on the drain tubes on the back of the bed so they don't rattle and some others don't trust the barbs on the fittings so added metal hose clamps. I think your install is very clean, thanks for sharing.:cheers:
  22. May 6, 2023 at 2:20 PM
    #1372
    Breathing Borla
    AZ
    thanks , appreciate that, anything I do has to be super clean otherwise my ocd goes nuts lol
    I counted and this is my 9th tonneau install on my rigs lol. Wow I’m getting old
  23. May 6, 2023 at 2:25 PM
    #1373
    G3ardnut
    Joe
    Canada
    Funny, I am OCD too. 9 covers, we should start a poll on that I am sure you will up near the top.:rofl:
  24. May 6, 2023 at 2:30 PM
    #1374
    Woocawachie
    Dickens
    Philadelphia
    Is this the model number for the cover? #UX42017
  25. May 6, 2023 at 2:32 PM
    #1375
    Breathing Borla
    AZ
    It’s the undercover ultra flex, it has the nice carpet stuff underneath, looks really nice
    I got it from a vendor of this site for a good price, service and speed was awesome
    @SantanaRealtruck
    SC4333 and RealTruck like this.
  26. May 6, 2023 at 3:51 PM
    #1376
    NickyF25
    NickyF25 New Member
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    That was always the issue I had and dont like about undercover covers.
  27. May 6, 2023 at 4:00 PM
    #1377
    G3ardnut
    Joe
    Canada
    I'll figure it out. Might need some spacers and longer hardware. Where there is a will, there is a way.
  28. May 6, 2023 at 4:01 PM
    #1378
    Breathing Borla
    AZ
    your not supposed to lose the rails but I had to take mine out to use the standard mounting
    That said if you use the tundra specific brackets that came with it and it worked, you would only not be able to use the oem sliding tie downs
    Eitherway, the cargo bed rail system isn’t rated for much anyways , so to secure something of any kind of weight the bed mount ones would be needed .
    anyways so far so good and it didn’t fly off yet lol
  29. May 6, 2023 at 4:03 PM
    #1379
    Breathing Borla
    AZ
    If you can get the mount with the cargo rail system brackets to work, you wouldn’t need much more room at all to use the oem sliding tie downs, they are just a bit to tall, you could easily still use something aftermarket
    I don’t really care about the cargo system that much so I didn’t mind having to remove the stock rails and just standard mount to the truck bed rails
    anyways , good luck!
  30. May 8, 2023 at 1:32 PM
    #1380
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    Id like to see some pics if you dont mind. Thanks!
