Tonneau + AMP extender
Discussion in 'Tonneau Covers, Caps and Shells' started by SebasJeppsson, Jan 2, 2020.
  1. Jan 2, 2020 at 10:47 PM
    SebasJeppsson
    SebasJeppsson [OP] New Member
    Sebastian
    2020 Tundra SR5
    Hey guys I’m new here to the Tundra forums (came from ram). Just got a 2020 Tundra TRD sport CrewMax!
    I’ve been on here reading for a few days now and I’ve set my sights on the AMP Research bed extender. I was going to pair it with a Bak Revolver x2/x4 however it seems that they are not compatible with the amp extender?
    Now I’m left with the truxedo sentry or bak mx4/g2, does any of you guys know if these will in fact work with the bed extender? Any other suggestions are appreciated as well.
    Going to be using the truck to haul motorcycles so a cover with full bed access OR easy removal and storage in the bed with 2 motorcycles is a must.
    Thanks!
    PFA
    GPJoeyD likes this.
  2. Jan 2, 2020 at 10:50 PM
    SebasJeppsson
    Sebastian
    2020 Tundra SR5
    Here’s a pic of the truck
  3. Jan 3, 2020 at 1:14 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Welcome aboard! Nice rides! I do not have a cover, but I can’t see why it would interfere with the amp bed extender. I have the extended and it mounts just using the low bolts in the inner bedside near the tailgate where the tie down hook is.
  4. Jan 3, 2020 at 1:22 AM
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    I have the MX4 and a OEM Toyota bed extender. Not sure why your combination will not work together. As long as the rear of the bed is clear, it should work. I also have the "no drill" brackets for my extender.
    This was the best combination I came up with that works for me.
    Boerseun and ZappBrannigan like this.
  5. Jan 3, 2020 at 7:01 AM
    SebasJeppsson
    Sebastian
    2020 Tundra SR5
    Boerseun likes this.
  6. Jan 3, 2020 at 7:49 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Boerseun, r1-superstar and GPJoeyD like this.
  7. Jan 3, 2020 at 11:01 AM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    From what I have read the Revolver X2/4 and AMP combo work together but the AMP Bed Extender cannot be flipped while in the mounting brackets. You will have to take the extender off, flip it around, and lock it in place. You’ll lose some of the connivence but if you’re putting a bike in the bed, it has to be removed anyway.
    SebasJeppsson[OP] likes this.
  8. Jan 6, 2020 at 12:41 PM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I have had a Bak Flip G2 and Amp Research extender for a couple years on my Crewmax. They work together with no problems. One good investment I made was the quick release brackets with the little levers to release the extender. It can be removed from either position without rotating. Makes use under a bed cover more convenient and also makes it much less of a pain to use the thing with cargo that's too tall to slide it over in the vertical position and then fold it down onto the tailgate.
  9. Mar 10, 2020 at 11:53 AM
    102dalz
    102dalz New Member
    Andy
    2017 Tundra CrewMax White
    None
    Does the ReadyRamp mount under the tonneau?
    Does it "flip" into the bed when not extended?
  10. Mar 10, 2020 at 12:01 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    More interested in the motorcycle at this point :muscleflexing:. That you on the RR?
    As for a cover, I really like my Lomax Trifold. Easy install and takes about 20 seconds for your average person to take on and off. Bought it with the intent of hauling my CBR1000RR to the track this summer.
  11. Mar 10, 2020 at 3:00 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I'm getting confused there are two threads going on this subject..
    https://www.tundras.com/threads/tri-folds-and-motorcycles.57285/#post-1561125
    I didn't know we were posting TD pics :)
    Ckatz53[QUOTED] likes this.
  12. Mar 10, 2020 at 3:10 PM
    Ckatz53
    Ckatz53 Newish
    MD
    RollTide82 likes this.
  13. Mar 10, 2020 at 3:17 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Fine..
  14. Mar 10, 2020 at 3:28 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Wish my balls were big enough to do that .
  15. Mar 10, 2020 at 3:33 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Why not go with a Diamondback?[​IMG]
    Tchase likes this.
