Tongue Weight Capacity?
Discussion in 'Towing & Hauling' started by Firefiter236, Jan 14, 2021.
  1. Jan 15, 2021 at 7:03 PM
    #61
    timsp8
    NY
    Maybe. But he joined yesterday and didn’t seem to agree with the answer he was getting. Pretty sure he would’ve bailed way before my post. I wasn’t as harsh as other posts in this thread.
    There are also a lot of people who join, make 1 thread, then are never seen again.
  2. Jan 15, 2021 at 8:27 PM
    #62
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    He’s busy explaining to his wife why he now needs to buy a bigger truck
  3. Jan 16, 2021 at 2:00 AM
    #63
    18" TRD Off Road Wheels
    Entirely possible that you are correct.
    timsp8[QUOTED] likes this.
  4. Jan 16, 2021 at 4:32 AM
    #64
    Damn that’s impressive capacities on the new 3/4 tons these days.
    Funny, out of curiosity I had to look at my 1 ton diesel and if I could even tow the OP’s trailer. I was pretty sure I couldn’t, but had to verify.
    That’s a big nope if at 1600 lbs tongue weight.
    Notice the pin weight of the 5th wheel/GN rating. 4000 lbs.
    Trailers like this are designed to be pulled behind dually equipped trucks.
    GODZILLA, Cpl_Punishment and timsp8 like this.
  5. Dec 17, 2022 at 9:29 AM
    #65
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    A few thoughts.
    1. What is the dry weight of the trailer and tongue weight? Will you load it to max? You CAN tow 10K but pushing your safety and reliability limits. I'd stick to 7500-8000 as a gross weight for any long distance towing. Knowing dry weight and what you load will vary.
    2. Heavier tires and airbags will NOT effect load/carrying capacity. The bags generally sit on the axle, and the tires effect the weight but not carrying/load capacity. It DOES effect the tire load capacity though.
    3. A weight distributing hitch will help with tongue weight. The gross trailer weight should be distributed so that the tongue weight is 9% to 11%. You should shoot for a 1000lb tongue weight if you are at you 10K max, and down accordingly based on your load.
    4. 40' trailer is WAY to big for a 1/2 ton truck IMO.
    Cpl_Punishment likes this.
  6. Dec 17, 2022 at 12:15 PM
    #66
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    wow.. thread resurrection :p
    Actually, heavier tires will add to your vehicle's curb weight which will lower your payload.
    GVWR - curb weight = payload
    GODZILLA, timsp8 and Cpl_Punishment like this.
  7. Dec 17, 2022 at 4:49 PM
    #67
    Bulldog9
    NOVA
    LOL, it showed up in the 'newest posts' section, or came up as I was doing a search for tongue weight. I never looked at the dates. I guess the OP never circled back.
    I get what you are saying, and am by no means an expert, but the tires are not 'on or in' the vehicle, the vehicle is 'on' the tires. I wouldn't give wheel/tire weights a second thought on GVWR. Then again, I rarely pay attention to payload numbers and other than an occasional huge load of mulch or concrete bags that goes way over the stated limit rarely come close. Even then, with 2000+ pounds the truck was fine. I just wouldn't do it every day. The figures are ridiculously low..........
  8. Dec 17, 2022 at 9:12 PM
    #68
    Netmonkey
    Georgetown, TX
    Everything attached to the vehicle contributes to curb weight; including tires. A set of larger tires and wheels could add an additional 100 pounds to the curb weight which would lower your payload by 100 pounds.
    Think about placing the truck on a scale. The tires will be included in that weight.
  9. Dec 18, 2022 at 2:20 PM
    #69
    Bulldog9
    NOVA
    Meh, I'm not buying it. Curb (total) weight increase from tires? YES...... Payload? I say NO.
    You do understand that PAYLOAD is determined by what is carried by the suspension and chassis of the truck right? Think of it this way..... If you can deadlift 500 pounds in normal gym shoes, and then strap on 100 pound shoes, will you now only be able to lift 400 pounds? Of course not. What is on your feet will not effect what you can lift/carry. Same principle on tires......
    But hey, YMMV. CIAO!
  10. Dec 18, 2022 at 2:27 PM
    #70
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Unless you're the automotive engineer responsible for designing the Tundra, how do you know that its payload is dictated/determined by the suspension? There are a lot of other components at play, including the frame, brakes, cooling system, etc....
  11. Dec 18, 2022 at 2:35 PM
    #71
    Bulldog9
    NOVA
    OK, I'll try to be clear.......... Tires are UNSPRUNG weight and their 'weight' do NOT effect payload...... If anything, a higher load class of a tire (AKA heavier) will help with payload, at least from a safety perspective being able to safely carry whatever weight you have IN the truck. Good points on cooling and brake systems, but again, tires are UNSPRUNG weight, and will not effect payload. YMMV
  12. Dec 18, 2022 at 2:40 PM
    #72
    timsp8
    NY
    Payload = GVWR - actual weight. Heavier tires increase actual weight. GVWR doesn’t change. So payload is reduced. No other way around it.
    In your weightlifting example, the weightlifter isn’t lifting that weight while running 55 mph. Heavier tires plus max payload greatly increase stopping distance. There is more to it than just what your suspension can hold.
  13. Dec 18, 2022 at 4:09 PM
    #73
    You're as confident as you are wrong.
  14. Dec 18, 2022 at 4:18 PM
    #74
    Netmonkey
    Georgetown, TX
    payload is NOT determined by what is carried by the suspension and chassis.
    Payload is a calculation.
    payload = GVWR - curb weight.
    There is no other way about it.
    Curb weight includes everything on or in a vehicle; including the tires and all the suspension. “Unsprung weight” is irrelevant. if you increase the curb weight, then you lower the payload.
    edit: you admit that heavier tires increases curb weight. Plug that curb weight into the calculation and see how the payload decreases.
    Cpl_Punishment, timsp8 and GODZILLA like this.
  15. Dec 18, 2022 at 4:27 PM
    #75
    Please read. Thank you.
    https://www.readingtruck.com/calculating-your-trucks-maximum-payload-and-towing-capacity/
  16. Dec 18, 2022 at 5:26 PM
    #76
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Since this tread was just brought back from dead, where was your friend fined? I’m local to Philly.
    Tundrarayray86 likes this.
  17. Dec 18, 2022 at 5:40 PM
    #77
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
  18. Jun 17, 2023 at 7:09 PM
    #78
    Tundrarayray86
    Tundrarayray86 New Member
    Ray
    4x4 2012 5.7FFV Tundra Sr5
    3in lift
    Agreed on mine they even have the updated weight reduction by 193lbs for a crewmax even when I had the 4runner before i believe it caps at 5k or 6800 but even if I couldn't I wouldn't go over 4k for the sake of having that safety buffer
